If you set up the plane as it comes out of the box I suggest THIS. It is a very good simple to set up and use gyro with individual adjustments for the three axis'.
If you fly a radio that has receivers with built in gyros (AS3X or SAFE, etc) it may be good to go with them.
If you want to have tailerons or flaperons they will require a gyro with more than one input/ output per axis like THIS. The newer FreeWing EG01 and some others are good but need a separate programmer unless you buy a plane with them already in them and preprogrammed. Some may be programmed through a downloadable computer app, the one I suggested for tailerons or flaperons is like that. They are more difficult to program.
I suggest a simple one that does not need a separate programmer or computer and has separate adjustments for each axis. If you want auto level like SAFE or REFLEX then that will take a more complex gyro.
