    • 8211
    Interesting about those chokes! Would love to see a photo of how you place them once you get your A-10. Cheers!
    • GliderGuy
      • 1408
      I still have my V1 power pod from the crashed bird. So, I opened it up to investigate where one could place the RF chokes. Remember, the closer to the ESC, the better.
      Plenty of room and 2 placement options….
      Note, These are not clipped or zip tied. I was simply experimenting with placement options.
      You can bet that my V2 will have these installed. I’ve learn the hard way what happens if you don’t use them.
      Then a small one will be placed by the green ferrite ring choke up by the receiver.
      Three chokes total. Consider adding them to the SR-71, too. There is lots of room in the SR’s motor nacelles. I did…and I am confident the SR-71 is better (less chance of loss of control) for having done it.
      Photos below are from both the topside and bottom side of the power pod. Zoom in and you will see the black chokes around the big main red, big main black and the smaller red/black/white throttle signal wires.
      Only one of 2 power module RF chokes is placed and not closed or zip tied…experimenting only.
      PS…This A-10 VERY likely crashed because the RF chokes were not used. It experienced a total loss of control one day. I was discussing this crash with a Ham Radio guru…he clued me in on the need for using the chokes.
      Click image for larger version  Name:	IMG_3160.jpg Views:	0 Size:	78.0 KB ID:	423354
        • 8211
        Great, what size do you recommend for these EDFs?
        • GliderGuy
          • 1408
          From the variety pack (Amazon), pick what size fits in the room you have. Bigger wires will take bigger chokes to be able to close. Minor foam trimming may be needed. For the UBEC-to-RX wire, use the smallest choke from the variety pack.
          Any choke is better than none.
          • GliderGuy
            • 1408
            Because of the long battery supply wire length, can anyone tell me if the ESCs have the added external capacitor banks like the MiG-29 has that are there to protect each of the ESCs?
            On the MiG-29, the external bank of capacitors are located adjacent to each ESC.
            Thanks,
              • 5395
              Yes. Go to the spare parts and look at the ESCs picture.
              • GliderGuy
                • 1408
                Thanks, Evan!
                  • 8211
                  Ordered! Thanks for the tip!
                  • Alphonso
                    • Aug 2020
                    • 101
                    • Hastings, UK
                    Pretty sure the mig 29 didn't come with extra external cap packs. I removed them and put them in a draw, sought them out earlier today to see if I should get the ARF A10 and they had no extra caps fitted.
                    • GliderGuy
                      • 1408
                      At least the A-10 V2 ESC pictures in the spare parts show the cap packs are present.
                        • 5395
                        Older one before FW started putting reversing ESCs in? The MiG now has the caps.
                        Buy Freewing 80mm EDF MiG-29 100A ESCs with 8A UBEC (Set) online at Motion RC. Order online with fast delivery.
                        • KevinMar
                          • Oct 2020
                          • 67
                          The previous A-10 model could run 90mm fans, can this one as well? Will the old conversions work?
                            • 8211
                            Good question, stay tuned!
                              • 5395
                              The old one could not just run 90's. It was an upgrade that consisted of a lot of parts including the whole foam motor pods. I think you know that but "The previous A-10 model could run 90mm fans" is misleading.
                                • 8211
                                As of this moment, there is no indication that Freewing will be offering the 90mm conversion kit. However, that could change down the road.
                                • Alphonso
                                  • Aug 2020
                                  • 101
                                  • Hastings, UK
                                  Regarding 90mm nacelles, the new nacelles look the same, so possibly just get V1 90mm ones. We'll soon know 😊
                                  • 3D-Seth
                                    • Mar 2023
                                    • 35
                                    Which version is being demo'd in the vids???
                                    I must have missed it...
                                    the inrunners or the outrunners?
                                    It's pretty F**King Cool boys!
                                    I'm reasonably confident Wes flew all the daytime videos with the outrunner setup. I believe he shot a dusk video (a short of this flight was posted on our YouTube channel) and that flight may be with the inrunners, but I'm not 100% certain. I do know he has the inrunners installed now.
                                    • andybuch
                                      • Apr 2025
                                      what are the Gyro setting for the A10? I'm getting the 9 blade version and adding the Freewing EG01 6 Axis Gyro Stabilized Flight Control System. not in the app software yet!​
                                      • TwistedGrin
                                        Hobby Squawk..... CLEAR!!
                                        • 376
                                        I have been lurking and pondering the FMS F-86 Saber or the FW T-33 Shooting Star...but this V2 release of the FW A-10 with upgraded landing gear suspension, 12blade fan, 80mm inrunner motors, LED Slime lights and integrated Gyro in the PNP version pushed me into an over stimulated fog induced purchase. This EDF should do just fine on our grass field. I did not realize the wings are removable which makes storage and transport much better than the F-86/T-33 aircraft.
                                        Incoming!!
                                        TwistedGrin
                                          • 8211
                                          Smart man!
