  • thisguy65
    • 509
    He’s running a Freewing sequencer
    Planes
      • 8814
      Must have bypassed the control board.
      Didn't someone add rear gear doors to the mains, kinda like the real A-10, but those don't close either when the gear is down because the struts are in the way.
      • Dirty Dee
        • 768
        • Northern Illinois
        bbolz I believe some people have mentioned that A-10s more recently purchased have an updated sequencer to keep the front door open with gear down.
        Topshot19 check out the crude diagram. this is a Cross-section view.
        basically each telescope section is broken out into a tube and the ladder rung. The tube should be hollow to allow the ones below it slide in, and have a small clearance so things don't get seized. The tubes have a flange designed in so when it extends the flange gets caught by the ladder rung. Each ladder rung needs a hole modeled into it to let the tube pass through, but be small enough to catch the flange.
        Edit: also, you cant print everything vertically, make the tubes have a 0.8mm wall thickness and it will work fine.
        Click image for larger version  Name:	Capture.JPG Views:	0 Size:	43.5 KB ID:	191911
          On the initial release, the board sequencer closed the front door after the nose gear deployed. The scale enthusiasts complained that this was not scale (door stays open on the full scale) so Freewing changed the sequencer to keep it open. So some models will close the door, and others will keep it open, depending on when it was purchased.
            • 4857
            BB, Somewhere in this thread this question has been asked and answered. If I recall the answer correctly, on the early A-10s the nose gear door closed after gear extension. Later models the gear door remains open. On my Freewing A-10, the nose gear remains down after gear extension, though MotionRC offers gear door sequencers for sale that can be incorporated for your circumstances, i.e., grass field ops or general 'cool' factor. :Smug: Best, LB
            Shop RC landing gear door sequencers at Motion RC. Explore genuine Freewing landing gear door sequencers for synchronized retract and gear door operation on RC airplanes.
            • Topshot19
              Pilot
              • 189
              • logan utah
              Okay I’ll try that out tonight!
                On my A-10, the nose gear door closed after the gear was down. I wanted it to stay open so I installed an aftermarket sequencer that actually allows for either setting depending on where you plug in the door servo. You just have to make sure the sequencer has a long enough delay so it won't try to close the door too soon. The first one I tried was a standard Freewing sequencer and the delay was not long enough for the door so it would jam as a result.
                • bbolz
                  • Mar 2019
                  • 154
                  Thanks guys! I checked mine last night and the door stays open when the nose gear is down. I like Steve's idea for having it either way. Steve, got a suggestion on a sequencer manufacturer that works as you say? "Freewing not long enough delay".
                    The air quality isn't the best here, but sometimes, every once in a while, it's worth it.
                    • DaleP
                      • Apr 2019
                      • 14
                      What a pic! Must..........resist..............temptation...... .........to has.......................A10!
                      • thisguy65
                        • 509
                        :popWent to the airshow today and saw the Thunderbirds. Got to see some great planes and talk with some great people.
                        The Flying Tigers came
                        Planes
                          It wouldn't be a bad decision per se, DaleP... ... LOL
                            • 4857
                            Alpha, Great Photo Caption!! Super Pic. Best, LB
                              • 8228
                              Baylee enjoyed her chase today... :)
                              • bbolz
                                • Mar 2019
                                • 154
                                • bbolz
                                  • Mar 2019
                                  • 154
                                  So, I think I'm ready for the maiden flight, why am I nervous I've flown pattern for 40 years. 84mm cg and 13.5 lbs total weight. Cg good? Click image for larger version
                                    • 8228
                                    The manual calls for 78mm (3.07") from the wing root LE...Not sure on the MAC...Maybe xviper can weigh in (pun not intended, lol).
                                    • Pogo
                                      • 452
                                      • Waterford, Ontario, Canada
                                      You should be nervous, this jet is horrendous in it's flying attributes!
                                      Just kidding of course- you're going to absolutely love it! The CG on mine is about the same (as are many others) and flies great, so no worries there. Best of luck with the first flights! :Cool:
                                      Tom
                                      • bbolz
                                        • Mar 2019
                                        • 154
                                        So maybe a little tail heavy at 84 I can fix that but I've heard that it's better a bit more back.
                                        • bbolz
                                          • Mar 2019
                                          • 154
                                          Thank you Tom, that's what I'm going with. I've watched this plane fly a hundred times thanks to all of you.
