    • 8205
    I am going to spray the polycrylic...Satin finish...I don't like gloss...Shows too many surface imperfections. Satin gives it a nice sheen without being overstated. As for the armament I am just going to add yellow tips to compliment the tail trim yellow.
    • thisguy65
      • 509
      Curious the different outcome with spray vs foam brush
      Planes
      • gravity tester
        Hobby Squawk Pilot
        • 70
        • Westfield, IN
        [QUOTE]I replaced the nose wheel with a smaller version, still has knocked the little trangle piece off the gear door twice now. got two more flights in on it yesterday and Turned the DR down to about 80 and 30 for expo, seemed to be be better. I also flew with all the ordinance on and a run cam on my outer pylon.[QUOTE]
        @P51 - For what it is worth, a lot of fliers on here (me included) have taken to using small screws to hold that triangle piece to the door. I used a couple of #2's top and bottom, glued the nuts in place and cut off the excess length. I lost mine on takeoff on my second flight and realized that it could have been disaster. Without that triangle, the gear can get hung up on the door and won't extend fully. I guess I was lucky to have just enough air pressure on the door during extension to clear the gear.
          • 8205
          I've never used brush for things like that...I am always afraid it's going to show streaks.
            • 4819
            TG65, Quick pic of my A-10, the only thing airbrushed on this was in the cockpit. The Polycrylic flows well with a foam brush and dries to a very thin coat (I used 2 coats) and the HD latex flows decent, and smoothes out when I appied a little water with a clean foam brush in about 6-inch square patches just as it was tacky. Slow going, but worked well. I shot rattle can Krylon Matte to kill the shine last. Best, LB
            Click image for larger version  Name:	IMG_0003a.jpg Views:	0 Size:	108.0 KB ID:	190584Click image for larger version  Name:	IMG_0014.JPG Views:	0 Size:	140.4 KB ID:	190585
            • themudduck
              -TMD- Foaming at the Mouth!
              • 1041
              • Burton OH (near Cleveland)
              LB I love spotting the small details that you put into your models, like the flag in the cockpit, and the little red label on the nose wheel. Really nice touches. :Win:
                • 4819
                TMD, Thanks. I enjoy it. Just like 'em to be a bit different, I suppose. Appreciatively, LB
                  • 8205
                  Just a beautiful model Elbee! Thanks for the info on the foam brush method as well.
                  Painted the ordnance to match the livery. She's all but done!
                  Click image for larger version  Name:	done1.jpg Views:	0 Size:	312.8 KB ID:	190607
                  Click image for larger version  Name:	done.jpg Views:	0 Size:	174.0 KB ID:	190609
                  • p51mustangman
                    • Feb 2019
                    • 63
                    What surface did you set to 80%, elevator?
                    ails and elevator, whatever it said in the manual, 80 or 85 can't remember now lol
                    • p51mustangman
                      • Feb 2019
                      • 63
                      [QUOTE=gravity tester;n190563][QUOTE]I replaced the nose wheel with a smaller version, still has knocked the little trangle piece off the gear door twice now. got two more flights in on it yesterday and Turned the DR down to about 80 and 30 for expo, seemed to be be better. I also flew with all the ordinance on and a run cam on my outer pylon.
                      I had to glue my light on today and was looking into what to do, thanks! I will be dong this when I get a chance to clean off the excess glue that didn't hold it on...lol
                      • p51mustangman
                        • Feb 2019
                        • 63
                        I painted a few coats on mine, then now I added a few with the spray on semi gloss. Both appeared to be the same, not reacting with much either. I also just sprayed my L-39 with gloss and it is looking real good! Click image for larger version
                        • bbolz
                          • Mar 2019
                          • 154
                          I found Polycrylic "Matte" at Ace and intended to spray it on. I think I'll try brushing the bottom of the wing to see the difference. Anyway what a beautiful plane. Motion really outdid themselves with this one. I don't know what I will put together next but it's like Robert Petrincic says "just push the button, what are you waiting for hey?" Love those guys.
                            • 8205
                            I've been meaning to ask...Does anyone have the paint match numbers for the stock grey?
                            EDIT: Disregard, the search feature worked great this time. :Silly:
                            • RCAV8R
                              Certified Plane Nut
                              • 355
                              • Medford, Oregon
                              Hi Guys...it's been a while since I was on this thread! I had some time and the airbrush was calling so I painted more on my A-10 canvas! Here's a photo I took in Reno a couple years ago that is what I was shooting for next to some shots in back yard. I'll do some sexier shots at the field with full ordinance later...that is, unless I find some more things to paint on her! RobLOL
                                • 8205
                                Looks great! Nice job man...
                                  Very nice Rob!
                                  • Lon
                                    • Jul 2014
                                    • 1201
                                    • Miles, Iowa
                                    Great detail Rob :Cool:
                                    Lon
                                    • Grover54
                                      Going Weightless
                                      • Jan 2019
                                      • 319
                                      • Seattle Area (Redmond)
                                      Now that bird is Awesome! :Cool::Cool::Cool:
                                        Looking better and better... Happy Easter!!! :Cool:
                                        • RCAV8R
                                          Certified Plane Nut
                                          • 355
                                          • Medford, Oregon
                                          Thanks guys and a blessed Easter to all of you! Rob
