    • 8814
    Keep the mains and swap to the upgrade TL nose strut.
    This is what I did. For the nose strut, there is no switching or cutting involved unless you want to for very specific and personal reasons. I've flown this plane strictly off grass to date. This year, I may join a field that has the GeoTex runway. Time will tell if the gear will work OK on that. If it doesn't, I just won't fly this plane there.
      Thanks Steve. Do I need to switch sides and/or cut the spring like George did?
      I'm with Steve on this one. Went TL all around and no mods to the mains. Another A-10 at my field went oleos all around and it seems fine too. Either way, just slow her down and keep the nose up and you'll be fine.
      • p51mustangman
        • Feb 2019
        • 63
        This plane is very very heavy up front. The best way to land it is keep the speed up with full flaps and correct flare. I am strictly flying off a nice cement runway, but with the new upgraded gear it would still be fine as it has the trailing link up front. Definitely see where guys are getting in trouble coming in too slow with or without the use of flaps on this plane. Flaps are there for a reason and can only help make a landing better!
          • 8228
          Started the process of painting her Arctic Camo. Have the black done, next up is the white and then finish her off with Callie's decal set...Anyone with the Arctic Camo, did you paint the underside as well or just the top? I can't for the life of me recall what I did with my first one a couple years back.
            • 2137
            • On planet earth....right
            I highly recommend not painting the underside for easier orientation. If you're more interested in achieving a look that resembles closer to full scale, then painting underside will be best :). I chose not to paint the underside.
            • p51mustangman
              • Feb 2019
              • 63
              I did the same type of scheme on the bottom as well. It feels good to finish painting planes as involved as this was haha. Good luck!
                • 8228
                T-CAT I am siding with you...If I had money in the game I would say I didn't paint the underside for that very reason (orientation). I realize that the Arctic Camo is a fantasy livery so there would never be a way to verify, just curious what folks would do.
                • Dirty Dee
                  • 768
                  • Northern Illinois
                  Aros, assuming the arctic followed a similar pattern as the euro and peanut, it probably is a full wraparound. Though I agree keeping the bottom a solid color would help with orientation. My arctic aggressor FW F16 can be a bit hard to see at times.
                  • p51mustangman
                    • Feb 2019
                    • 63
                    That is where the yellow tips on the tail come in
                      • 4857
                      51MM, Absolutely gorgeous, Sir. :Cool: Bravo Zulu. Best, LB
                      • p51mustangman
                        • Feb 2019
                        • 63
                        thanks! appreciate all the tips and tricks from everyone on this forum, helped a lot!
                          • 8228
                          Looks fantastic!! Thanks guys for the feedback. I am going to keep the bottom unpainted.
                            • 2137
                            Good call Aros! For me, it made for of a difference for orientation than I anticipated.
                              • 8228
                              It may have a little bit to do with laziness too, I ain't gonna lie. LOL
                              • p51mustangman
                                • Feb 2019
                                • 63
                                definitely takes a bit of time! ha!
                                  :Silly:I try not to be lazy, but my naps get in the way!
                                    • 8228
                                    LOL LOL LOL
                                      • 8228
                                      Here she is...I can't believe the amount of work that goes into this scheme...Masking galore! Next stop, Callie decals! :Cool:
                                        • 4857
                                        Aros, Nicely done. Best, LB
                                        • p51mustangman
                                          • Feb 2019
                                          • 63
                                          looks real good! nice work!
