Official Freewing 90mm F-16 Falcon Thread
  • urrl
    • Oct 2013
    • 493
    RE: Anyone else chompin' at the bit for the FW 90mm SUPER SCALE F-16?
    This mornings flights from Doug and I.
    https://www.youtube.com/watch?v=eeC31TTuXgY
    https://www.youtube.com/watch?v=zk2gyhskqKg
    • Pheonix
      • Aug 2013
      • 670
      Originally posted by Rocketeer
      Greetings Guys,
      Man, you just gotta love the smell of LiPo's in the morning!!
      Great video!!
      Thanks for sharing.
      Bill L.
      In Okla.
      Yep!  Got out early this morning, but had to deal with the marine layer.  It is a good thing I took out planes with light.  Had a close call even then in the clouds.!  Happy flying all.
        • 8202
        Lookin' good!! Nice video, good flying, love the opening sequence.
        • CT
          • May 2014
          • 294
          Sweet Video guys!!! Well Done
          CT
          • urrl
            • Oct 2013
            • 493
            Some morning touch and go's
            https://www.youtube.com/watch?v=lHUsXd4yP8w
            • urrl
              • Oct 2013
              • 493
              Misty flight before sunrise
              https://www.youtube.com/watch?v=dE62zTISRnY
              • XF-15DCC
                • May 2015
                • 164
                • Bristol CT
                Love the first few seconds of the video when you see the augmenter lit up! Great looking plane in the Thunderbird colors.
                Someday I'll work my way to one of those!
                Off with one helluva roar!
                AMA 1085465
                • Pheonix
                  • Aug 2013
                  • 670
                  Nice flying! Each time I watch one of these videos, I want to buy the plane. This can get costly!
                  • urrl
                    • Oct 2013
                    • 493
                    Thanks guys. Check out my new afterburner mod which costs a buck made out of red hair extensions found in the Dollar store kid's section.
                    Flight testing it tomorrow. Stay tuned.
                    https://www.youtube.com/watch?v=4_1yyrEq-W8&feature=youtu.be
                      • 8202
                      That is AWESOME!
                      • urrl
                        • Oct 2013
                        • 493
                        Thanks :D
                        The braided part of the red hair extension hairpiece used caused a blocked air flow in the thrust tube. I will eliminate the braided hair portion or cut foam inside the tube to install the braided portion recessed inside the tube to permit more air flow. I may also try the more commonly used fiberglass strands next time although I love the bright red color the hair extension piece produced. Work in progress. Stay tuned.
                        https://www.youtube.com/watch?v=AL4fJ6U9cU0&feature=youtu.be
                        https://www.youtube.com/watch?v=Q24epi2zqpU&feature=youtu.be
                        • urrl
                          • Oct 2013
                          • 493
                          The red hairs were replaced with orange and blond hairs for less red color and a brighter flame. Because the LED light ring is red I think there will always be a red color unless I change it out, which I'm not going to do. Hairs were also styled; clipped to produce a narrower flame. I modified the installation process also for less thrust blockage. Next up: Flight Test Number two.
                            • 8202
                            That looks even better!
                            • urrl
                              • Oct 2013
                              • 493
                              Still diminished thrust this test but not as bad. Sorry about the bad resolution; accidentally left my HD cam SD card at home. Used iPhone 6+ instead.
                              Does not do as well in pre-dawn light but Image stabilization is better though.
                              • Flygirl
                                • 969
                                • Glen Burnie, Maryland USA
                                It does look real!! Are they starting to wonder about you down at the Dollar Store yet? LOL! BTW, the iPhone took a pretty good video I thought...?
                                Lauren
                                  • 8202
                                  I am so impressed with that! If the diminished thrust can be somehow negated, this could be a marketable add-on!
                                  • XF-15DCC
                                    • May 2015
                                    • 164
                                    • Bristol CT
                                    Could you rig the AB to the throttle settings so it is not always on. Or maybe use a switch to turn it on and off? This looks great! I wonder what a dual augmentor that is lit up would look like!
                                    AMA 1085465
                                    • urrl
                                      • Oct 2013
                                      • 493
                                      Never let your flying enthusiasm overtake common sense:
                                      https://www.youtube.com/watch?v=ADw9KHxR1O8
                                      • XF-15DCC
                                        • May 2015
                                        • 164
                                        • Bristol CT
                                        Yea the sky didnt look to friendly. But you have it repaired so it could have been worse.
                                        AMA 1085465
                                        • urrl
                                          • Oct 2013
                                          • 493
                                          Three morning flights edited together. Last one took flame piece out and added on board cam for stunts. Enjoy
