Official Freewing 90mm F-16 Falcon Thread
  • Donu
    Old School Pattern
    • 27
    DCorsair, are you setting your battery per the MRC flight video for correct CG and are you flying it with expo on high rate? Thanks By the way I use a Sony Professional HD camera from the ground and a Möbius 2 on the planes. Once I get it dialed in I'll put out a video.
    • urrl
      • Oct 2013
      • 508
      Originally posted by Donu
      Urrl, looks like you have the F-16 dialed in great, what kinda of setup are you using? Flapperons with elevator mix or something different?
      No flaperons, just stock set up. No elevator mix but considering that since it likes to jump into the air on take off.
      • urrl
        • Oct 2013
        • 508
        Originally posted by DCORSAIR
        I need to get a video one of the these days, what camera do you guys use for this type of filming????
        I'm using the Canon G20. I was thinking of selling it for a G30 or G40 since it only has 10x zoom
        • DCORSAIR
          • 1918
          • Selma, Ca.
          I haven't watched the MRC video so I don't know what they are setting the CG at, this jet needs to be right to enjoy it's flight envelope that it has, I think that is why some people buy it and then don't like it, you have to fly it, set the CG, fly it some more, move the CG forward or back and fly it some more, it has a wide range for the CG so that is a good thing but if your off on the maiden flight, that could be not so good when trying to land it for the first time, nose heavy is way better for landing but it takes longer to rotate, rear CG rotates smoother but can be a handful trying to land if you fall behind on power and use to much elevator.
          My settings for the CG are 110mm-112mm or 4 1/4 to 4 1/2 inches measured as per the manual, I measure with the gear down and upright, it comes out to about where the first carbon rod goes through the wing, you should be able to see the slots on the bottom side. I have flown at the stock setting 118mm and it works too after you have several flights on it, if it's your maiden I wouldn't use the 118mm CG, better to keep it around 112mm.
          Elevator 25mm up/down.......no expo or dual rates
          Aileron 30mm up/down........no expo or dual rates
          Rudder is whatever you like, don't need much for steering.
          Less aileron is okay but when you slow this jet down to turn final the ailerons tend to get mushy so if you run them at 30mm it helps, anything less and you feel like your running out of aileron. By the way I have well over a hundred + flights on the F-16 so I can tell you it flies great once you figure it out.
          • Angelo r
            • 4
            Can someone help me out? I have a freewing f 22 w/60 amp speed control and a3500 motor and I am getting an admiral 2500 50c battery, should it go all the way forward or all the way back?the 2200 work ed fine all the way up front.
            • dusmmdb
              Flaky hobbyist
              • 144
              • Central Louisiana
              The grey is difficult to make out at a distance so I decided to add color.... I was searching for a good scheme when I saw the new Air Force aggressor splinter type....
              so, I copied this....
              • dusmmdb
                Flaky hobbyist
                • 144
                • Central Louisiana
                This is how it came out...
                i left the bottom grey... with some patches of another grey to break it up a bit ... just really want to be able to tell top from bottom
                • Shirty
                  Hobby Squawk Water Boy
                  • 1067
                  • Perth, Australia
                  Very nice.
                  • urrl
                    • Oct 2013
                    • 508
                    Very cool; reminds me of the SU35.
                    • racerx600rr
                      Herky Bird Pilot
                      • 58
                      • Marietta, GA (Atlanta)
                      Like it :Cool: Super good looking!
                      Models current and qualified on!: Freewing; 90mm F-16, 80mm Mig-21, A-4, F-14, F-5, L-39, P-51 / Flexinnovation flexjet / HSD; 105mm F-16 / Flightline 1600mm Spitfire, B-24 / FMS; P-40b, F4U Corsair, Beaver (painted as an Army U-6), /Eflite; Carbon Z T-28, V900, P2 Prometheus, Pitts S1, umx Pitts, Champ, umx B-17, and a bunch of other small bits and bobs from hobbyking.
                      • EDFjetpilot
                        Serving EDF jet enthusiasts.
                        • 224
                        • USA (Union Springs Alabama)
                        Looks great! I like your idea of being a little off scale by leaving the bottom grey...best for safe flight orientation.
                        Sean
                        • dusmmdb
                          Flaky hobbyist
                          • 144
                          • Central Louisiana
                          Thanks.... yeah full scale would have basically been the same..... needed some contrast between top and bottom
                          • urrl
                            • Oct 2013
                            • 508
                            It was a nice day for a crash...or two.
                            • urrl
                              • Oct 2013
                              • 508
                              • gooniac33
                                The Original Gooniac
                                • Jun 2016
                                • 1047
                                I maidened a friends 90mm Thunderbird today...Very pleasant plane to fly!!
                                • kscobey10
                                  just ordered the 8s power upgrade for a new F16 90mm, Is there enough room under the canopy for 2 4s batteries to power it and still balance ok for it? If anyone can help with this question I would very much appreciate the info. Thanks, Kevin
                                  • DCORSAIR
                                    • 1918
                                    • Selma, Ca.
                                    My buddy runs his on 8s, I will ask him about what he had to do to get the batteries to fit, I know it's a tight fit, CG is fine if you can get them jammed to the back as much as possible. I did the maiden on it and I had his CG set about 110-112mm which is where I run mine at on 6S. I can tell you this much, he said it wasn't worth it, he wishes he would have kept it on 6s, didn't gain much, maybe a little more thrust is all, but the weight is more, of course he is running brakes and another small lipo plus the two large 4S lipos. I do all of his test flights right now until he gets more jet time and figures out how to land it. I feel the difference in power but it's not a huge difference to me. He was able to get the two 4S batteries side by side in there though and still adjust the CG.
                                    • gooniac33
                                      • Jun 2016
                                      • 1047
                                      According to Motion RC they should fit just fine. But as mentioned above it may not get you much more than you already have. The plane is going to gain weight and this plane doesn't care much for higher weight.
                                      I am planning on getting an ARF plus here pretty soon and will be dropping in my 4082 1600kv inrunner set up. It worked great on my F-15 and since the F-16 is a cleaner air frame I am thinking it will do even better.
                                      • Shearer-Dave
                                        • Aug 2017
                                        Guys,
                                        I'm new to this forum and I have a query. Tried to remove my f16 wheels for brake conversion. Got grub screws out OK but the wheels are stuck tight Possibly loctiite in axle? Any help would be appreciated
                                        • MANFRED
                                          Any Warbird, any time
                                          • 299
                                          • San Diego, Ca
                                          In everyone's humble opinion, are the Flaperons necessary or helpful on this ship?
