Official Freewing 90mm F-16 Falcon Thread
  • Pheonix
    • Aug 2013
    • 670
    RE: Anyone else chompin' at the bit for the FW 90mm SUPER SCALE F-16?
    Really nice flying. I might have to get one of these soon:)
    • urrl
      • Oct 2013
      • 493
      Some frown on trying to glide the F-16 in and although it is certainly not advisable for a beginner what would you do in an apparent F-16 dead stick situation? Looks like Doug is getting in the practice and handling it pretty well. I need to practice some of these myself although I've done one or two of these before.
      https://www.youtube.com/watch?v=9pKz9-Jj8Qo
      • urrl
        • Oct 2013
        • 493
        https://www.youtube.com/watch?v=LbBggR9UGOc&feature=youtu.be
        • XF-15DCC
          • May 2015
          • 164
          • Bristol CT
          Gravity is a mo-fo, ouch!
          And that is one reason we F-15 crew chiefs referred to the F-16 as a "lawn dart".
          Off with one helluva roar!
          AMA 1085465
          • urrl
            • Oct 2013
            • 493
            Repeat of the failed maneuver.
            https://www.youtube.com/watch?v=6wZjTIIH3CE
            • urrl
              • Oct 2013
              • 493
              Kissed the runway :D
              https://www.youtube.com/watch?v=Gg1vN7OP5HA
              • Rocketeer
                • Feb 2014
                • 1356
                Greetings URRL,
                Sweet Video!!! and Flight!!!
                I especially enjoyed the shots of your observers!!
                Thanks for sharing......
                Clear Skies
                Bill L.
                In OKla.
                • XF-15DCC
                  • May 2015
                  • 164
                  • Bristol CT
                  "Pucker factor" was high there!
                  AMA 1085465
                  • urrl
                    • Oct 2013
                    • 493
                    Thanks guys, much appreciated.
                    Here's another flight
                    https://www.youtube.com/watch?v=mzM2Qyf4Q0I
                    • XF-15DCC
                      • May 2015
                      • 164
                      • Bristol CT
                      Watching the horizontal stabs deflect is awesome!
                      Great stuff!
                      Kevin
                      AMA 1085465
                      • urrl
                        • Oct 2013
                        • 493
                        Some more acrobatics
                        • Loneflier
                          • Aug 2013
                          • 603
                          • Huntsville, AL
                          Originally posted by urrl
                          Wow, very nice! So how does this one compare to the F-104 Starfighter? Is one easier to fly than the other?
                          • urrl
                            • Oct 2013
                            • 493
                            The F-16 is heavier and that seems to translate to more stability. She has a tendency to float on landing and drop to the ground unless balanced correctly. I began my flights nose heavy to curb this behavior until my landing experience with the jet improved. For me electric brakes are necessary for worry free landings.
                            • USAJetLover.DJ
                              • Oct 2015
                              • 6
                              I am so chompin!!! I love this bird and anyone see the new flight video?? Here it is: https://youtu.be/CZMwCrU01S0
                              I'm soooo hyped!!!
                              Because I was Inverted... :)
                              HOO-AH!!
                              • urrl
                                • Oct 2013
                                • 493
                                Yesterday's morning flight
                                [hr]
                                IMO the F-16 has a better thrust to weight ratio, looping easier than the F-15 and probably faster, however the F-15 is easier to fly and land, and is now my preferred jet.
                                • urrl
                                  • Oct 2013
                                  • 493
                                  • Glenn
                                    • 15
                                    F-16 with missiles look stunning.
                                    • bradl4648
                                      Your Motion RC CS Team Rep
                                      • 369
                                      Hi Guys
                                          Just thought I would post what I use for my settings on the DX9 radio. Please note the flap and elevator position and speed delay.
                                      here are the radio settings that I use on my F-16.
                                      dual rates on all surfaces
                                      med 75%
                                      high 125%
                                      expo 50% on all settings
                                      I use the following switches for the dual rates
                                      aileron is F switch
                                      elevator is C switch
                                      rudder is G swithch
                                      Flaps are as follows
                                      0 position happens to be 0 for me
                                      1 take of flap -52 elevator+19
                                      2 landing flap -100 elevator +28
                                      switch D
                                      speed 4 second delay
                                      Remember when coming in for a landing have your throttle at 1/2 as your deploying half flaps. If you have the throttle any more it will pitch the nose down that's bad. Once you are on final have your throttle to 1/4 and drop landing flaps. You will be able to turn the jet left and right just fine but it is sluggish if you try and make a turn in the air like your turn on final is not a good idea. You are looking for the nose to go to high alpha (or nose high attitude) this is correct and come in at a good 45% glide slope. Use power to correct for pitch for altitude to keep it on the 45% attitude. Pretty much once the plane is about to touch down then cut the throttle and hold some up elevator if needed.
                                      If you have other questions please ask or anything else you would like to know.
                                      Hope this helps,
                                      Brad
                                      • Shirty
                                        Hobby Squawk Water Boy
                                        • 1067
                                        • Perth, Australia
                                        G'day fellas, just new to the forum, finding my way around.
                                        Figured I'd share one of my f16 vids. Nice to see some familiar electronic signatures. :)
                                        http://youtu.be/TvEhfSYS3y4
                                        Sorry. Like I said new to the forum and not sure how to post the vid so it shows up in the thread here like urrls.
                                        Edit: found it. :)
                                        • Flygirl
                                          • 969
                                          • Glen Burnie, Maryland USA
                                          Nice vid Shirty!!!! Dramatic!! And you guys have an INCREDIBLE FIELD TO FLY FROM!! Where is that?
                                          Lauren
