That's some amazing printing. You certainly get what you pay for. :Cool:
I added all the files I'm using to my account on Shapeways, you can choose a different material if you want but I set the default to the "Frosted Ultra Detail".Comment
I had some made up at Lowes.....The grey was a good match, but the green was off. So I mixed my own up from Tamiya colors khaki drab and added buff until it matched. I think someone had theirs posted a page or two back. They used Home Depot. Here's the photo they had. His looked real good in the post. Yeah post 641 and 652. Hope this helps.1 PhotoComment
Thanks, I can work with this.
I had some made up at Lowes.....The grey was a good match, but the green was off. So I mixed my own up from Tamiya colors khaki drab and added buff until it matched. I think someone had theirs posted a page or two back. They used Home Depot. Here's the photo they had. His looked real good in the post. Yeah post 641 and 652. Hope this helps.Comment
Nice addition, TI! One question for you or anyone else, not a big deal, but does it look like the stock pilots are overly large, especially if you compare them to the 1/18 scale P-51 pilots? I also added one (of the 1/18 scale pilots) to the nose turret and the head of one in the top turret. But they seem significantly smaller than the pilot figures in the cockpit. I probably won't change anything, but was thinking if I get the upgraded cockpit interior, I might put a couple more 1/18 scale pilots in there for consistency.Comment
Today, Success with the maiden flight on my B-24! Had my friend Shaq do the maiden to be sure nothing crazy happened, but it flew beautifully in the cold, windy morning. My dad, who flew a plane looking just like this in WWII, would have been 100 years old tomorrow had he lived.
I did a number of changes on this airplane so far: repainting the plane to one flown by my dad with the 446th BG, 705th BS, in December 1943 when they started their combat tour out of England. Converted the nose turret from a Consolidated to Emerson (Emerson turrets were more cylindrical versus the angled glass Consolidated turrets that come with the model). Redid windows in nose area per a H model that this depicts. Added scale (ish) main gear doors, redid waist windows and added wind screen in front of the hatch. Replaced nose wheel with 2.25" dia. nose wheel for more scale appearance, no problem using this on hard surface, by the way. Also added movable top and nose turrets (inspired by Tired Iron!).
Still to do: add nose gear doors, and looking into adding a ball turret maybe with some printed parts, not sure yet. Great start for this airplane and its first flight! Happy New Year, everyone!!7 PhotosComment
Bomb bay doors...
Posted this in rcgroups, since I am having some success thought I would cross post here...there's a bit more detail in the rcgroups listing, and those interested in how I cut the fuselage should go here: https://www.rcgroups.com/forums/show...postcount=1127
This is build #2, #1 had some design flaws (if interested in #1, details at rcgroups). I decided to redo the tracks in order to have deeper channels to hopefully reduce binding. I also went to 1/8" balsa for all main formers for same reason. Pics pretty well show what I did. Some notes:
1. The 1/8" former is carefully sanded down a bit to allow for the 1/64" ply that will be glued around it to allow track channels to be made.
2. The Depron copy is ultimately used to support one side of the track channel. It is first used to push the 1/64" ply against the spacer. The three ply layers on the front and back sections are 1/2", 3/8", and 1/2" wide, respectively.
3. If you think the former looks a little odd, it is. Turns out the fuselage sides are not symmetrical, one side is bit rounder than the other. You don't notice it unless doing something like this.
4. The spacer is 3mm depron, which I happen to have a supply of, but could easily be 1/8" balsa.
5. The back former is done the same as the front. The middle former is different in that you have to do channels on both sides, and ply widths are changed accordingly. It is still a 1/2" wide of ply around the middle former (former is in the middle of the ply width), then 3/16" wide ply, then 5/16" wide around the Depron matching formers.
6. The torque rod holes and spar holes followed the patterns from Take one, they don't change.
7. The front and back formers are glued so that they are flush against the fuselage. The middle former is glued in place, measuring to be sure the side and top distances between formers are the same. On mine, the front bay is 5 3/4" long, the rear is 5 7/8" long.
Next the doors, where I have made some changes from design 1 as well...Pete M8 PhotosComment
