  • sfmadmax
    • Jan 2019
    • 105
    • New Hampshire
    Hey all,
    ​​​​​​Got a retract question , I was showing my dad the features , and one of the retracts simply stopped going up and down, is there anythink I can do to check them or are these pretty much a throw away if they stop functioning. ??
    It's locked in the downward deployed position.
    After he left I unscrewed the retract from the housing took off the lock screws to the strut , but I can't get the strut off. It's like the factory lock tighted them. I really don't want to mess with it anymore and may just be s.o.l and will call them on Monday. No big deal, just wondering if there is any trouble shooting , off that it failed if it did. This was the same strut that gave me a hard time to get the wheel off too. :Confused:
      • 8795
      Originally posted by sfmadmax
      Hey all,
      The better idea would have been to trace all the wiring from retract to the control board. Pay particular attention to the wing connector board. Some of my connectors were not fully seated. Remove them one by one and test with a servo tester but DO NOT test the light circuit. A servo tester will burn the light out. Through the process of elimination, you can find the one for the retract and test it by itself. Also, on mine the plugs were mixed up and one was even plugged in with the wrong polarity. Brand new retracts don't usually just quit at the end of one cycle. There has to be a bad connection somewhere.
      • RichJ53
        • Nov 2018
        • 342
        • Southern Oregon
        Hey all,
        you can disconnect the gear servo at the mini connector board on the wing. try powering it up with a servo tester bypassing the multipin ribbon wire and blue box
        Rich
          • 2696
          Originally posted by Brandon Moon
          Doing a little work on the F4U-1D Click image for larger version
ID:	183238Click image for larger version
ID:	183239Click image for larger version
ID:	183240Click image for larger version
ID:	183241Click image for larger version
ID:	183242Click image for larger version
ID:	183243Click image for larger version
ID:	183244Click image for larger version
ID:	183245Click image for larger version
ID:	183246Click image for larger version
ID:	183247Click image for larger version
          Brandon,
          Love the additional cylinders to look more like the double wasp. Did you get these online somewhere, print them or they look a little like the cylinders in the FMS corsair?
            • 8223
            Also, Brandon, tell us some more about your cowl flap mod!
            • Brandon Moon
              Fly, Enjoy, Have fun!!!!
              • Oct 2013
              • 335
ID:	183538Click image for larger version
ID:	183539Click image for larger version
ID:	183540Click image for larger version
ID:	183541Click image for larger version
ID:	183542 The dummy radial is a combination of the Stock FMS Tigercat radial and parts from the Stock FlightlineRC Corsair radial all combined together. if you look at it closely....it's pretty self explanatory.
              The cowl flaps are just simple modeling plastic I cut and glued on the outside at at angle to simulate the open cowl flaps. I did slightly bevel the edges of the existing cowl flaps lines to countersink the plastic
              Brandon Moon
              • downwindleg
                • 1279
                • Friday Harbor, Washington
                Originally posted by Grover54
                For all you "detail" guys out there, I think I found a solution for the missing Pitot tube. I've looked everywhere and can't find the right one for the F4U but came across this one. I may need to modify it a bit but it's a start. If anyone out there knows of where we can get the "real" deal please let me know.
                BTW G54, your picture reminded me that the treads on most bubble top Corsairs including 5 pictures I have taken at Reno are of the solid inline groove type whereas I've seen a number of people on this thread ordering Robart tires with the diamond pattern treads.:Thinking: Just an observation. Going with the solid grooves on mine.:Cool:
                • Brandon Moon
                  • Oct 2013
                  • 335
                  And this is the Pitot tube I added. It's from the LX Corsair. Click image for larger version
ID:	183548Click image for larger version
                  Brandon Moon
                    • 2696
                    Outstanding work Brandon. Finally, something from FMS that's worth having. LOL
                    • theoldALFER
                      Taildragger Pilot
                      • Jun 2017
                      • 163
                      • Cape Coral, Florida
                      Brandon,
                      who’s pilot is that? :Thinking:
                      • Ole-Timer
                        Warbird Enthusiast
                        • Dec 2017
                        • 344
                        • New Brighton, PA
                        Alfer, you can make one. I tossed the plastic sidewinder nose on mine and used brass tubes. Main tube is aluminum with brass pitot on the end. I made a small shark fin from brass and soldered it on.
                        Super rugged and for transport it pulls out of the wing. :Cool:
                        Even has the the ram air opening
                        I have my dear departed Control line and Rc mentor Amos to thank for things like this. He taught us how to custom build soup can fuel tanks to fit any space, landing gear, basically whole models from scratch.
                        Click image for larger version  Name:	0D8E6D3B-258E-47EA-A4A1-003AF86854FA.jpeg Views:	0 Size:	63.3 KB ID:	183567
                        • Grover54
                          Going Weightless
                          • Jan 2019
                          • 319
                          • Seattle Area (Redmond)
                          Quite possible. I've seen both but what's really funny is most of the photos I've seen of the USMC squadrons stationed in the Pacific, their tires are bald! LOLand leave it to the Navy (photo attached) they have one of each!LOLLOL I chose the diamond tread because they were recommended by TI and I found a couple sets on sale. :Cool:
Name:	F4Ub diamond tread.jpg
ID:	183575Click image for larger version
Name:	F4Ud diamond tread.jpg
ID:	183572Click image for larger version
Name:	F4Uc diamond tread.jpg
ID:	183573Click image for larger version
Name:	F4Ua diamond tread.jpg
                            Probably because they determined the diamond on port and straight on stbd helped counter P-factor :PLOL
                            GO NAVY :)
                            • themudduck
                              -TMD- Foaming at the Mouth!
                              • 1041
                              • Burton OH (near Cleveland)
                              Click image for larger version  Name:	F4Ub diamond tread.jpg Views:	6 Size:	128.0 KB ID:	183575Click image for larger version  Name:	F4Ud diamond tread.jpg Views:	8 Size:	117.4 KB ID:	183572Click image for larger version  Name:	F4Uc diamond tread.jpg Views:	6 Size:	53.3 KB ID:	183573Click image for larger version  Name:	F4Ua diamond tread.jpg Views:	6 Size:	102.8 KB ID:	183574
                              I think the last two pictures (on the carrier) are from the Korean War - these are later-model Corsairs with the chin scoop.
                              The first two pics are earlier models (Like our Flightline birds) and you can see they have the diamond treads.
                              (side note - If I remember my history, the Corsairs weren't immediately available because after WWII they had all been mothballed, and they had to dig them out of storage and get them cobbled together to get them ready for service in Korea.) You can see in the pics that they were fitted with rockets and such. Funny how the one has two different tires! Maybe they were using up some spare parts that were lying around on the ship!
                              I just noticed - look how BIG that pilot is in the second pic - his shoulders are all the way up to the headrest and his head is going to hit the canopy. He must be 6'-8" or maybe he's a short guy standing in the cockpit!! LOL
                              • themudduck
                                • 1041
                                That's a really nice scratch-built Pilot- tube, Ol' timer. I remember back in the ol' days, when we all would scratchbuild our models out of balsa and Ambroid. (my brain damage has subsided)
                                Kids these days just don't know about all that, why, back when I was a young'un I used to have to make my own engines out of scraps, tin, spit and bubble gum. Now you just go out and BUY whatever you want, they just don't have the skills no more! :)LOL
                                Seriously, you done good. But this should be super easy for someone to make a 3D file so we can print that "marital aid" on the end and stick it on to a tube. Dirty Dee can you hear me?? Or are you gonna make me drag out my soldering iron and make this darn thing by hand out of brass and what-not.....
                                • Ole-Timer
                                  Warbird Enthusiast
                                  • Dec 2017
                                  • 344
                                  • New Brighton, PA
                                  Thanks MD,
                                  You said it, even at the hobby shop in the days of old there was little to be had other than balsa, monokote, and engines. Airplanes were either scratch built or came as a kit. Much of life was like that then, repurposing so many things to keep homes and farms running. For youngsters today, well, it’s all lost to them. Sad
                                  Anyway, winter is finally ending here in the northeast US and outdoor work season is again upon me. Flying is always second fiddle till I get the big stuff reigned in but I’ll sneak it in here n there.
                                  I will soon be scarce on these boards as priorities are changing, I’m in no hurry to maiden the Corsair , believe I haven’t flown in perhaps four months now so a bit of brush up first, not too big a deal really, happens every year. Plenty of great planes here to get proficient in quickly MotionRc is always in a hurry for reviews but I NEVER review a model until after several flights.
                                  I was able to get a few pictures of the Gopher in actual sunlight, wow, sunlight, it really does exist!
ID:	183629Click image for larger version
ID:	183628Click image for larger version
                                    • 4848
                                    [ATTACH]n183633[/ATTACH]
                                    Ya'll, Quick Corsair Pitot Tube End. Take it and run with it. Dimensions can be changed in your CAD program or "Scale" it in your slic3r. The shape is okay, the lengths should be cut to fit a longer tube that inserts in the wing. If it works for y'all, great, if not, I'll design something else later if someone hasn't already. Gone OoT for a few days. Best, LB
Name:	Corsair Pitot Tube Proto v1.JPG
                                    • Grover54
                                      Going Weightless
                                      • Jan 2019
                                      • 319
                                      Funny you mention the size of the pilot in the second photo. I recall reading somewhere that there were a few TALL 6' 8" pilots out there, one I think was in the 214 Black Sheep. My Dad wasn't tall, maybe 5'10" but he told me he liked to fly his P51 with the seat as high as he could get it. Maybe this guy does the same?LOL
                                      • downwindleg
                                        • 1279
ID:	183676 O.K. Here's a pic of a Corsair I took at Reno last year. It's actually a smart phone pic of a pic. The original was in raw format so it doesn't transfer easily. Got those "groovy" tires!LOL Good details for engine and weathering too perhaps.
                                          • 8223
                                          Is there a more badass-looking warbird?? I think not!
