    • Nov 2013
    • 2783
    • Cody, WY
    I'm going to say you are okay. You could tape a weight to the front of your battery if worried.
    I agree with Evan. You should be able to tape a little weight onto the battery to ensure it is within CG limits, and give you some comfort knowing that CG won't be an issue with this plane. On my Corsair, I've always just shoved it forward to the stop (Admiral 5000 6S) and it has never been an issue.Of course, I don't have all the wonderful additions that you have added on your plane, but I would think it would be fine with this adjustment to be within the CG envelope.
    With my F/A-18C when flying with the Deluxe Elbee Cockpit, I had to move the battery forward close to an inch to accommodate the additional weight of that cockpit over the stock one. Whatever it takes, there is a way, I'm sure!
    davegee
      • 4869
      Evan D davegee
      She weighs in at 11.75 lbs 'wet' with the correct CG of 100mm aft of the LE.
Name:	pngtree-animated-pig-in-helmet-flying small.jpg
      That's 38+ ounces per square foot of wing loading using a trapezoid equation for the wing shape. +/- for the rounded tip (700sq in).
      Feel free to check my math. :flushed:
      I've flown heavier but not at this wingspan.
      Same calculations for OEM equals an 8+lb airframe and 26.3+ oz/sq, roughly 44% lighter :astonished:
      Whoa, this'll be fun.
      Taxi test today in the driveway to avoid any temptation.
      Lighter winds forecasted for tomorrow, so "God willin' and the creek don't rise," first flight test on Sunday somewhere.
      Best, Steve
        • Nov 2013
        • 2783
        • Cody, WY
        Originally posted by Elbee
        Evan D davegee
        Best, Steve
        Hi Steve: I just weighed my Corsair. With an Admiral 6S inside, the "all up" weight for mine is 9 pounds, 13 ounces, the same weight I have been flying it for years. Add another 5 ounces for the "Authentic Elbee Brewster bomb rack and bomb" that I have flown several times which puts it over 10 pounds.So you're only about a pound and a three quarters more than my standard flying weight, without all the details you have added on yours. I've never had any issues with mine when I've flown it in a scale manner, which I always do.I never attempt any maneuver that the full sized plane would not have tried or was unable to accomplish.
        I don't think you'll have an issue with your plane at your weight provided you don't get too slow in turns or pull too many g's in maneuvers. You should be fine.
        Good Luck!!!
        Dave
          • 5416
          That seems excessively heavy to me.
            • 4869
            Plane weighs 9.55 lbs dry with the extra OEM weights in the Cowl; an unmodified airframe is 6.3 lbs, a 51% increase over a stock airframe.
            Add the 35c/6250Mah + 6 volt LiFe to run the lights at 2.1 lbs puts her at a chunky 11.5+.at suggested CG versus a <9 lb airframe at CG.
            Considering the heaviest mods, Robart Wheels/Tires, 85% Cockpit with full pilot, Pratt&Whitney faux motor, Main Gear mods, primer & paint I figured she'd beef up some.
            But she's so pretty.
            Best, Steve
            • jetfool
              • Nov 2022
              • 1362
              • Crawfordsville, Indiana
              Elbee,
              Mine weighs 8.5 with your cockpit, struts, tw and Robart wheels. Good luck on first flight. Will be waiting to hear of successiveful flight
              Best Regards, Rex
                • 4869
                Originally posted by jetfool
                Elbee,
                Best Regards, Rex
                Whoa, that's light. Is that dry weight or with battery?
                That only leaves the primer and paint, faux P&W, cowl flap mechanism with micro servo, Canopy mechanism with 2 micro servos, and pilot figure.:grimacing:
                But that weight adds up quickly.:astonished:
                Where is your rudder servo?
                Best, LB
                • f4u ausie
                  • 1242
                  • Melbourne
                  Or some epoxy inside the nose cone with the weights. Futher forward it is u will need less
                    • 4869
                    Or some epoxy inside the nose cone with the weights. Further forward it is u will need less
                    :face_with_monocle:
                    Craig,
                    Great minds think alike, as they say (who are "they" I wonder).
                    I remembered there was sufficient foam in the lower front fuselage when I had chopped the nose off to add the cowl flaps and faux P&W R2800.
                    I used a 5/8th inch sharpened brass tube to cut 4 round holes 2 inches deep into the fuse, designed and printed some tubes, and ran over to Wal-Mart to get some 1 oz fishing sinkers (paks-o-3).
                    I dipped the sinkers in 30 minute epoxy and dropped 2 each into the 2 inch long one ended tubes. Overall weight average 2.12+ oz.
                    These slip nicely into the lower fuselage front behind the cowl.
                    I will lightly glue each tube in place to avoid egging out the foam over time from strafing runs and low-level bomb drops.
                    I can easily add up to 8+ oz and can always cut holes in other portions of the fuse front if I need more counter balance.
                    I had reinforced the nose section with carbon fiber tube when adding the cowl flap mod, so there is plenty of added structure to support the 2-8 oz I can add.
                    Also, I should lose some overall weight as these weights are much further forward than the battery compartment, so better leverage.
                    I'll do CG checks again tomorrow and let you know how it goes.
                    Best, Steve
                      • Nov 2013
                      • 2783
                      • Cody, WY
                      :face_with_monocle:
                      Craig,
                      Best, Steve
                      I LIke your plan!!👍👍👍
                        • 2716
                        Evan D davegee
                        Best, Steve
                        I have no idea how much mine weighs in at, nor do I plan on putting it on the scale. I won't get on a scale either, nor will my CO, so we just go with it. With that said, I'm sure my Corsair is quite heavy, fully loaded weights in cowl and a few more chunks of lead to get 5mm behind manual (no more to be safe-and I'm one who flies all my jets at least 25-35mm behind manual, but not the Corsair or Spitty).
                        I do have modified engine cowls (not the LB ones), a modified cockpit, full body warbirds.com moving head pilot, sound card and 2 transducers, a ton of paint, 4 coats of clear spar varnish, robart wheels, etc. And I'm using a SMC 5900 HiV. So I got some weight.
                        My only recommendation is don't let it take off too soon, as it desperately wants to lift off before you have enough ground speed. Keep the nose level or even slightly down on your take off run till you're ready. On landing approach, I come in at a whopping 45% throttle, then land level at 35% throttle. So dont get too slow.
                          • 4869
                          Hugh Wiedman
                          Thank you, Hugh for the advice, I have been reading your Corsair posts for all your helpful tips.
                          Back in the "Days of Yore" flaps were a scale feature for the 'big boys', so I had no knowledge of the benefits in my model aircraft.
                          We were happy in our ignorance and just marched on like we knew what we were doin' trying to keep the wing-loading below 40 oz/sq ft/
                          That said, no take off flaps for me, let her rise to the occasion on her own.
                          As for landing, flaps there, but 'fly her home' has been your 'modus operandi' and I will certainly follow your sage advice.
                          I am excited about this flying this one, it's been awhile since I could say that.
                          Thanks again, Hugh.
                          Best, Steve
                          • f4u ausie
                            • 1242
                            • Melbourne
                            Will be like flying one of rembrants best... they all need to come off the wall just once... not to much quick throttle either. On launch..Biiigg prop.. put mine on its back twice as a learner.. tuff as nailes no damage.. flip it over go again bout half throttle.. so when the time comes.. u wont need it but(good luck) skill always outways that
                              Elbee commented
                              Editing a comment
                              Thanks Craig, will do...err...won't do...err...ya know what I mean.
                            • 4869
                            Hey y'all,
                            Taxi test done, needed about a 1/4" of right rudder trim to straighten the tail wheel.
                            Adjusted the tail wheel steering linkage and all is well.
                            Tamms took some vid and pics of a 'proud papa'.
                            With some luck, first check flight nearer the end of the week, as lawn maintenance, fall chores, and higher winds than I like are imminent for a few days.
                            Best, LB
                            Click image for larger version  Name:	Corsair and Steve Sept 2024.jpg Views:	10 Size:	109.5 KB ID:	411209 Click image for larger version  Name:	Stevie_Corsair_Sept_2204.jpg Views:	8 Size:	133.2 KB ID:	411210
                            • jetfool
                              • Nov 2022
                              • 1362
                              Elbee,
                              Getting closer and closer to test flight day. Corsair looks really great in the sunshine. We both have the same color of hair LOL
                                Elbee commented
                                Editing a comment
                                My 'change' of hair color started in my early 40's. I asked my Mom, "what is up with this?" She replied that I will be grateful in the years to come. Mothers are never wrong about such things. LOL.
                              Hair? My hair color is bald! Lucky sons of guns with hair color to talk about, lol!
                              My goodness Elbee what a museum piece. :corair1::corair1::corair1::corair1::corair1::cora ir1::corair1:
                                Elbee commented
                                Editing a comment
                                Thank you again my friend. Means a great deal to me. I've been smiling for hours and hours. It took a lot of will power 'not' to go looking for a flat spot in an empty parking lot. Woo-hoo, Daddio!
                            • f4u ausie
                              • 1242
                              • Melbourne
                              Yes 1 heck of a smile. The smile on your face is big too,,, looks stunning:stuck_out_tongue:
                                Elbee commented
                                Editing a comment
                                Craig, thank you, as you've been an inspiration without knowing it. Your 'call-sign' pretty well covers it, Sir. Best, Steve
                            • Fast N Light
                              • Apr 2021
                              • 118
                              Hey y'all,
                              Best, LB
                              Great looking bird. Love the open canopy and weathering...
                                • 4869
                                Fast N Light,
                                Thank you.
                                I am happy how it finished out.
                                Learned a lot on this build, weathering was a challenge as I had not done anything like this.
                                The shades of blue were the thing. Opposite sides of the color wheel worked well.
                                I must have recalled that from the single day I was in a high school art class.
                                Pastels in yellows, some purples, gray, graphite, even some pale blue, browns.and a bit-o-black.
                                I'd do a section, wing top for example, wait and look at it the next day, add some, remove some and move on.
                                Even did a wet wash of pale yellow-brown which didn't end well, but provided a great base.
                                The two base blues are Mig-Ammo acrylic (ANA 608 & 606), so any addition of pastels doesn't wash off completely, but ended up working in my favor.
                                Another happy accident.
                                Water is really all you can use on the finish w/o lifting the colors, so I just added more of the pastels and rubbed it in, changing colors as I progressed.
                                Simple once you take the prescribed medicines (gin&tonic in my case) and begin again.
                                In any case, perseverance is the thing, just keep goin' till it looks decent.
                                Thank again for the kind words, Sir.
                                Best, Steve
                                  • Nov 2013
                                  • 2783
                                  • Cody, WY
                                  Great pics of you and the new "baby!" Best of luck for an awesome maiden flight and safe return to mother Earth!
                                  davegee
