I'm right along with you there, sometimes my fingers shake so much I almost drop the TX (a combination of age and outright fear). Expo helps in that case and keeps the aircraft from flying like it has epilepsy. I can also use high rates all of the time along with expos in the 30% range. With minor stick deflection, it acts like it's in low rates, but as I increase deflection, it's like it automatically transitions into mid and high rates. And on my Extreme Flight 60" planes, high rates with deflections in the 70 degree ranges, I'm using what Chris Hansen recommends for expo in the rates: 70% or more. If it's good enough for guys like Jase Dusia, who am I to differ.
We had a guy at our field flying a new Avanti, set up by the books. He was not an advanced or even a seasoned EDF pilot, but the Avanti is the perfect EDF trainer to go to. I tried to help him as he flew because he was using just way too much stick movement and completely over-controlling the aircraft. He had 0 expo, and I told him to land and we'd dial down the rates and add in some expo, but wouldn't you know it, he over banked the final turn and spiraled into the ground.
