  • Originally posted by T-CAT View Post
    Awe man, I'm sorry to hear that. That can be disappointing. It has happened to me before with a different aircraft. I also wanted to fly that plane on the weekend, but contacted Motion to send it back. Hopefully the company helps you out quickly and you can get flying.
    Looks like my only option is to return it at this point.
      Looking at their policy, customers are responsible for shipping it back AND the cost it took to ship it to you the first time. That what happened on yours?
      • Have you talked to them yet? The shipping back and forth are on you for a no reason return. You are returning due to warranty defects...
          I have. I sent in a general customer service form asking my options, but was told this wasn't a warranty issue so I'd have to fill out a RA form if I would like to return it.
          • Originally posted by JamesonC View Post
            Since the aircraft I had (was several years ago) had issues like warped surfaces, etc., if I'm not mistaken, I dont believe I paid for shipping in any way for the return/exchange process. It was a while ago, but I'm going off memory. During that time, I spoke to someone on the phone and they sent me the necessary return label.
              I was on a Deployment when my Jet arrived. I didn't get the box opened for about 4 month after it arrived. I had 'Warpage' on the Stabs, I got the Sorry, ... that out of your Warranty Period... Warranty starts upon receipt of Box, not when you Get around to opening it !!!! Hahahahaha. I explained my particular situation and got No sympathy whatsoever .... Veteran Owned business too !! OhWell... I just deal with it. GL
              • Originally posted by Bobaroo View Post
                I feel for you with that as that is a tough thing to have happen. Thank you for your service.
                • I just received my all grey version last week. I was disappointed to find out that the elevator plates aren't properly glued. I had to put very little pressure on them and they practically popped out. I'm going to have to remove them completely and re glue them. The sticker was on the box warning me to check the service bulletin prior to flying this plane but come on, I paid $479 for this plane and it has a issue that they know about yet are basically telling their customers "you fix the issue"
                  • I ordered mine last week after doing the maiden +1 on a club members new F18. It felt that good in only two flights I knew this could cause my F22 to take the bench for a bit. Stock 6S powertrain is perfectly matched for this aircraft.
                    It’s a bummer about the servos and plates but at least the issue is out in the open and easy enough to fix.
                    John
                    Freewing A10, F4, F22, Sebart Avanti S mini
                    • My flights from this past weekend....
                      I am an RC addict and innovator. Ask me anything via PM if you need help!
                      • Well, I have a gray ARF+ on the way. Hopefully this plane doesn't disappoint as I've wanted one for a long time.
                        • I replaced my elevator servos to all MG, did my due diligence as per the TSB and couldn't be happier! Great jet!!
                            Just do as the service bulletin says... you will be fine!! Plane flies awesome!
                            • Originally posted by john2kx View Post
                              John
                              Pulled the elevator system apart on my new kit and found no issues as listed in TSB.
                              • My replacement didn't have any problems with the elevator setup either, just replaced the servos to MG and slightly dremeled more room for the leads.
                                • Originally posted by gooniac33 View Post
                                  No doubt, man . I'm picky, so I go through things with a fine tooth comb, LOL. After I'm satisfied, then I'll get to painting, and further mods.
                                  • Originally posted by Herman Munster View Post
                                    That’s exactly why I’ve not purchased any more! If your lucky, you won’t have to cut foam to re-glue the plates. Otherwise, there’s two ways to fix it correctly in my book.
                                    1. Split the fuse
                                    2. Cut out the bottom portion around the plate only. (This is what i did)
                                    But back to your point, there’s NO REASON on earth, anyone should pay $500 and have to make repairs before use, PERIOD!!!!!!
                                    • As expected, MRC has taken care of me 100%. I was disappointed to have mine arrive with damage, but MRC's customer service never disappoints!
                                        I replaced all the important servos (aileron, flaps and elevator) and eliminated the blue box. That may have been slight over kill but I wanted to make sure it worked as I wanted. I will be using the blue box to get the LEDs working as they should. I also reglued the servo plates with extra thick CA and it made a huge difference!
                                          It's well worth the effort to make changes you feel will provide added assurance to the longevity of the jet . I know many of us have wanted a large F/A-18 like this for a while now, so it's nice to keep it around for as long as possible.
