    Center burner test.
    Got it masked tonight.
      • 8205
      LOVE the afterburner! Can't wait to add that when I get mine...
      • Boots Whirlygig
        • 560
        • Granville Ohio USA
        Looks great Steve! Questions:
        What masking tape are you using?
        What paint, rattle can or airbrush, if airbrush what gun for large coverage?
        Are you doing an overall primer coat first, if so, what?
          Hey Boots, I am using green and yellow frog tape. Green on the canopy and LED lenses. Yellow on any painted surface applied after sticking it to my shirt first. Next I will be giving it a light sanding with some 220 grit sandpaper and then wiping it with denatured alcohol. After that I will wipe it down with a Tac Cloth. I will then spray it with light coats of Rust-Oleum white primer until the original SEA camo is covered. Finally, I will airbrush it with Model Master's acrylics that are thinned as necessary with Createx reducer. The airbrush I have is a Master SB80 and works very well.
            • 8205
            I like the trigger airbrush style much better then my traditional one...I will have to pick one up.
              Me too. I would love to have a GREX but those things are spensive!
              • Boots Whirlygig
                • 560
                Thanks for the info, I may order that airbrush. Is the Rustoleum white primer a “filling or sandable” primer? I know the finish on my Freewing F-16 and A-4 are beautiful and wouldn’t require filling and sanding, but the finish on my FMS P-40B is not so nice, and I wondered if a primer could help smooth out the foam cells prior to a repaint?
                    Primer going on...finally getting to paint this bird. After a light sanding with 220 grit and a good wipe down with denatured alcohol followed by a tac cloth this is where it's at. I should have everything primed by the end of the day.
                    • PikeStaff
                      Happy.
                      • 74
                      • St. Augustine, FL and Perkasie, PA
                      Has anybody done a good calc of wing area of this plane? I’’’ve done a quick and dirty run at it, but think the result (of area) is too low. I’m coming up with 485 sq in area; my AUW is right at 4240 grams (149.5 oz). 485 / 144 = 3.37 sf; 149.5 / 3.37 = 44.4 oz/sf. Pretty hefty, and considering how well everybody feels they fly, Alpha and Crew picked a mighty good wing profile.
                      I’m no expert at determining lifting body area contributions, hence my skepticism regarding accuracy of my calcs. Anybody else take a run at it?
                      • Dirty Dee
                        • 768
                        • Northern Illinois
                        Manual calls out 26 dm^2 (403 sq in) but measuring in CAD gives me 573 sq. in.
                        Rather than calculating standard wing loading, try cubic wing loading. It gives a better representation, as larger planes can handle weight better.
                        • Itgordon00
                          • 36
                          Freewing F-4 Phantom II 90mm 6S flight vids.
                          For those who are not subscribed to my youtube channel, here are a few videos showing the flight characteristics. This jet is easy to fly and fairly forgiving.
                            Primer is done. Painting tomorrow.
                            • Itgordon00
                              • 36
                              Second video.
                                I know it will be a masterpiece!
                                  • 8205
                                  Looks great Steve...Remind me, what is the livery choice?
                                    VF-84 Jolly Roger's
                                    • PikeStaff
                                      Happy.
                                      • 74
                                      http://www.ef-uk.net/data/wcl.htm
                                      Thanks, Dee. Wasn’t aware the manual had that info....when all else fails, then....:Cool:
                                        Two more sorties today on the 8S JF90 Phantom. I'm really digging the power on this setup!
                                        • Sky Wolf
                                          Flying Ant
                                          • Sep 2013
                                          • 731
                                          • Irving, Texas
                                          Steve, that is going to be one AWESOME machine. Can't wait to see her in action!!
