  • Center burner test.
    Got it masked tonight.
    • LOVE the afterburner! Can't wait to add that when I get mine...
      • Looks great Steve! Questions:
        What masking tape are you using?
        What paint, rattle can or airbrush, if airbrush what gun for large coverage?
        Are you doing an overall primer coat first, if so, what?
        • Hey Boots, I am using green and yellow frog tape. Green on the canopy and LED lenses. Yellow on any painted surface applied after sticking it to my shirt first. Next I will be giving it a light sanding with some 220 grit sandpaper and then wiping it with denatured alcohol. After that I will wipe it down with a Tac Cloth. I will then spray it with light coats of Rust-Oleum white primer until the original SEA camo is covered. Finally, I will airbrush it with Model Master's acrylics that are thinned as necessary with Createx reducer. The airbrush I have is a Master SB80 and works very well.
          • I like the trigger airbrush style much better then my traditional one...I will have to pick one up.
              Me too. I would love to have a GREX but those things are spensive!
                Thanks for the info, I may order that airbrush. Is the Rustoleum white primer a “filling or sandable” primer? I know the finish on my Freewing F-16 and A-4 are beautiful and wouldn’t require filling and sanding, but the finish on my FMS P-40B is not so nice, and I wondered if a primer could help smooth out the foam cells prior to a repaint?
                • Originally posted by Boots Whirlygig View Post
                  • Primer going on...finally getting to paint this bird. After a light sanding with 220 grit and a good wipe down with denatured alcohol followed by a tac cloth this is where it's at. I should have everything primed by the end of the day.
                    • Has anybody done a good calc of wing area of this plane? I’’’ve done a quick and dirty run at it, but think the result (of area) is too low. I’m coming up with 485 sq in area; my AUW is right at 4240 grams (149.5 oz). 485 / 144 = 3.37 sf; 149.5 / 3.37 = 44.4 oz/sf. Pretty hefty, and considering how well everybody feels they fly, Alpha and Crew picked a mighty good wing profile.
                      I’m no expert at determining lifting body area contributions, hence my skepticism regarding accuracy of my calcs. Anybody else take a run at it?
                      • Manual calls out 26 dm^2 (403 sq in) but measuring in CAD gives me 573 sq. in.
                        Rather than calculating standard wing loading, try cubic wing loading. It gives a better representation, as larger planes can handle weight better.
                        • Freewing F-4 Phantom II 90mm 6S flight vids.
                          For those who are not subscribed to my youtube channel, here are a few videos showing the flight characteristics. This jet is easy to fly and fairly forgiving.
                          • Primer is done. Painting tomorrow.
                            • Second video.
                                I know it will be a masterpiece!
                                • Looks great Steve...Remind me, what is the livery choice?
                                    VF-84 Jolly Roger's
                                    • Originally posted by Dirty Dee View Post
                                      http://www.ef-uk.net/data/wcl.htm
                                      Thanks, Dee. Wasn’t aware the manual had that info....when all else fails, then....:Cool:
                                      • Two more sorties today on the 8S JF90 Phantom. I'm really digging the power on this setup!
                                        • Steve, that is going to be one AWESOME machine. Can't wait to see her in action!!
