  • jthenry8
    • Apr 2018
    • 19
    Originally posted by Bobaroo
    Used a Click image for larger version  Name:	66-7709.jpg Views:	661 Size:	44.6 KB ID:	182117 FreeWing attachment to the Rail !! As Good a place as any, considering the Pylons are Multi-Use anyway !!
    Here are a couple of more pictures of "709" in the air when it was assigned to the 13th TFS (circa 1969-1970). That's my Dad in the back seat.
Name:	F-4D Aug 27 1970 Over North Viet Nam.jpg
ID:	362692Click image for larger version
Name:	F-4D Over Viet Nam (August 1970).jpg
    • jthenry8
      • Apr 2018
      • 19
      Yes,... I put a Drop on the No.1 F-4D Nozzles and used a Plastic Drinking Cup for the Nozzles. Extended them to the Later E-Model Length.
      Click image for larger version Name:	IMG_20190424_141432.jpg Views:	0 Size:	81.7 KB ID:	191598
      No.2 F-4E (Early) has the FW 3DP Nozzles shown here before the Drop and Chop !!! This Extraordinarily Wide Exit Lip was unacceptable to me. This is what you get when you just stick them onto the Foam after removing the stock plastic cones. Most guys just leave it like this.
      Click image for larger version Name:	IMG_20190424_141433.jpg Views:	0 Size:	84.1 KB ID:	191599
      The No.3 F-4F will be getting the RCGeek LongNose F-4E/F 3DP Nozzles. They are 'Longer' and have a very nice Exit Lip on them and are already at a nice Thickness. No need for Chopping back the Foam as they are already extended past the Inner Nozzle Boundary. Depending on which Aircraft you are modeling, there is a nice set of Nozzles to be added for someone who desires a more realistic F-4C/D/E/F look on their Foamie !! Cheers
      Click image for larger version Name:	IMG_20190424_141548.jpg Views:	0 Size:	73.4 KB ID:	191600
      Click image for larger version Name:	-8 vs -10 Annotated Pictures.jpg Views:	1 Size:	135.7 KB ID:	191601
      This is some great work. I really like the "dash 10" nozzles. Of the research I have done and the pictures I have from my Dad's planes - those seem to be the right ones. Love the attention to detail. Awesome stuff.
      • jthenry8
        • Apr 2018
        • 19
        I think I am going to correct myself. It looks like the "turkey feathers" nozzle may be the right one for a 1968 produced F-4D. The definitive picture I have is of F-4D 68-709 on a low power setting and you can clearly see the collar. I mistook the constricted nozzle to be more representative of the "dash 10." Looks like upon closer inspection that the nozzle has a collar. Would love some feedback on this one.
        • jthenry8
          • Apr 2018
          • 19
          :)Waiting for the fog to burn off this morning, got a few photos of the Phantom out on the runway. Can't say enough about how sweet flying this airplane is.
ID:	192732Click image for larger version
          Holy Crud, Batman! What great pictures. The sky is perfectly matched to the paint scheme!
          • jthenry8
            • Apr 2018
            • 19
            Originally posted by Elbee
            Hey Y'all, She's on her own feet for the first time. Some soft weathering on the upper fuselage, light touch up, airbrushing the tailhook, and a matte finish coat yet to do. Ordinance is a work in progress. :Whew:Best, LB
ID:	192907Click image for larger version
ID:	192908Click image for larger version
ID:	192909Click image for larger version
ID:	192910Click image for larger version
ID:	192911Click image for larger version
ID:	192912Click image for larger version
ID:	192913Click image for larger version
            Love the intake ramps and the pilot figures. in the first picture it seems like he is looking directly at ground crew directing him to the catapult. I commented previously on the nozzles. Great work. Looks like you did some work on the chin air intakes. Would like to hear some details about if you made the parts or if they are available somewhere else. Overall, exceptional craftmanship.
            • jthenry8
              • Apr 2018
              • 19
              The G nose (Wild Weasel) is different than the E nose. I only know of two sources for the E nose and that is Tom Mansel and Chris Wolfe. Chris's is more scale. The small door on mine was hinged with a standard Dubro hinge.
              I want to build a G variant, but the "E" nose variant looks a little bit off - too thick? Has anyone else noticed this? Is it because the base of the nose from the kit to round and a difficult transition? Thoughts? Please don't think this is a criticism of the work of those who developed the E nose - it is not. Those who developed that mod are amazing craftsman. Just trying to understand the build and the dimensions affecting the nose adaptation. Humbly submitted.
                • 4817
                Would like to hear some details about if you made the parts...
                JT, I thank you for the kind words. The parts you mentioned are 3D printed mods of my design. Mostly, I took the OEM piece parameters and changed the profiles. The VIRs need to look sharp and thinned in my opinion, that was a given, the A/C intakes should look cleaner, and so on.
                The pilots are JHH 1/12th scale from "The RC Geek" as are the "B" Nozzles (I did not have my printer when I bought all the parts for this build). The Cockpit is the Freewing version offered by Motion RC. It is a resin 3D print and fits perfectly.
                I built the "B" variant the best I could without changing any fuselage profiles and you wrote about doing an "E" or "G". The fuselage is wide on this model, though I have seen others in this thread that have squared the cockpit section to better represent the "E". I do not know if there are other 3D printable designs for modding the Freewing "D" to an "E" or "G".
                This was an early project in design for me, but all the parts turned out quite good, I think. Each design change I made was a compromise to the OEM and I did not want to stray to far from what is a very detailed and flyable model.
                If you have a 3D printer or access to one, I can send G-codes of those parts. I would need to know the printer manufacturer, filament, and nozzle size you are using. The parts print nicely.
                Best, LB
                Click image for larger version  Name:	IMG_0002 PS 1 Cropped Blow Up Contrast.jpg Views:	2 Size:	137.8 KB ID:	362747
                Click image for larger version  Name:	..and kill MIGs.jpg Views:	2 Size:	113.9 KB ID:	362748
                • jthenry8
                  • Apr 2018
                  • 19
                  Originally posted by Radar-Guy
                  Yep, crewed by JHH pilots. Visors covered with Future floor finish....
                  Click image for larger version Name:	A62CD2B4-584F-4210-A160-7F8DF2034D15.jpeg Views:	0 Size:	85.4 KB ID:	235164
                  Did you raise the WSO up towards the canopy? I have always thought they looked like there were sitting really low in the cockpit. From this angle it looks just about right.
                  • jthenry8
                    • Apr 2018
                    • 19
                    Originally posted by vduniec
                    Ready for inspection! Here's the final product. Weapons, "E" nose, cockpit, pilots, TIESO and centerline tank are 3D printed. Only one flight on it so far. It has survived the maiden but was pretty nose heavy and I bounced the landing shearing the nose gear pin. Already repaired and ready for the next sortie.
ID:	252899Click image for larger version
                    Absolutely fantastic. My Dad was the Ops Officer and later the squadron commander of the 3rd TFS at Clark. Your Rhino looks great.
                    • jthenry8
                      • Apr 2018
                      • 19
                      Originally posted by heisteff
                      hi just wanted to show some pics of my rhino. maiden still to come
                      Looks absolutely fantastic. Is that the RC Geek "E" conversion kit?
                      • jthenry8
                        • Apr 2018
                        • 19
                        Also, did you create the Standard ARM and AN/ALQ-184 pod? I am trying to pull together everything I would need to build a "G" variant, and these pieces would really help.
                        • Radar-Guy
                          AirBorn Jetworkx
                          • 364
                          Yes, I did. These are JHH pilot busts raised with some balsa. The GIB deserves his view of the outside world.
                          Regarding the printed ‚long nose‘ conversions. After some trials and looking at ‚good‘ drawings‘, I decided to make another design starting right in front of the wind screen including the different air scoops.
                          • Radar-Guy
                            AirBorn Jetworkx
                            • 364
                            I want to build a G variant ...
                            Also, make sure to add the outer wing slats then!
ID:	363215Click image for larger version
ID:	363216Click image for larger version
                              • 4817
                              Radar-Guy That's just beautiful work, Sir. Outstanding. Best, LB
                              • heisteff
                                • Jun 2019
                                • 16
                                • Neuburg Germany
                                hi, no it´s the F-nose posted on thingivers
                                • spook
                                  • Jun 2019
                                  • 15
                                  • Germany
                                  Awesome job! Is this nose printed or hand made with wood or foam?
                                  • Radar-Guy
                                    AirBorn Jetworkx
                                    • 364
                                    Thanks! The entire nose section is printed (ASA filament) and reinforced with carbon tow.
                                    Click image for larger version  Name:	IMG_4233.jpg Views:	0 Size:	96.2 KB ID:	363300
                                    • vduniec
                                      Hobby Squawk Pilot
                                      • 314
                                      I obtained the 3D files from Thingiverse. I printed out both the "E" and "F" versions. The "E" didn't look right to me so I went with the "F" version. Dirty_Dee is a great 3D designer and had the "G" version up on Cults3D.com a while ago but I don't see it there anymore. Maybe you can reach out to him to inquire about the "G."
                                      • vduniec
                                        Hobby Squawk Pilot
                                        • 314
                                        Those look great! Have you flown it yet? How did you address ensuring that they're at the same angle to each other? I was nervous I wouldn't be able to do a good job on that so I kept mine a "Hard-wing" version. Technically inaccurate but the plane is at least still in one piece.
                                        Thanks.
                                        • vduniec
                                          Hobby Squawk Pilot
                                          • 314
                                          Here's the link for the Standard missile:
                                          This is a 1/11.5 scale AGM-78 Standard ARM missile. It I scaled for the Freewing F-4 Phantom. I downloaded a two piece version and a four piece version. Both will assemble into the same missile. The four piece version can be printed with only a 150mm height printer. The longest piece of the two piece missile is 260mm tall. When I test printed the four piece missile with one piece at a time it took 12:19 minutes to print. There is a slot for using the Freewing F-16 male weapons attachment hardware. The final painted missile ended up weighing 99 grams.
                                          I added the ALQ-119(slightly different from the ALQ-184):
                                          1/10th scale ECM Pod specifically made for the Freewing A-10 Thunderbolt II. Body has a slot to fit attachment hardware: https://www.motionrc.com/products/freewing-f-16c-90mm-weapons-attachment-hardware. There is a variant of the bodies "w support" which help prevent wobble of the parts during printing. They are fairly tall and skinny so the nozzle may cause the parts to wiggle as it lays down the upper layers.
                                          I don't recall if I had to resize it for the F-4.
                                          There is an ALQ-184 on Cults3D, but it's 1/72 scale and I don't know how well it will scale up so much to the fit the FW F-4.
