  • Lnye22
    • Feb 2020
    • 8
    • Lochgilphead Scotland
    Thank you for the help. 👍👍
    • radfordc
      • 375
      • Lansing, KS
      First flights today. All went great.
      • Airguardian
        Post Stall Svengali
        • Aug 2020
        • 1676
        • Catalonia
        Congrats Charles!
        The second landing was very smooth, looks like you have her dialed in! :)
        • Airguardian
          Post Stall Svengali
          • Aug 2020
          • 1676
          • Catalonia
          FPV action begins on the second flight!
          • T- Elbert
            • Sep 2020
            • 98
            • Helena, Montana
            Here are some nice shots of the su-35’s from my local club.
            • Airguardian
              Post Stall Svengali
              • Aug 2020
              • 1676
              • Catalonia
              Enjoy! ^^
              • Airguardian
                Post Stall Svengali
                • Aug 2020
                • 1676
                • Catalonia
                Happy Friday y'all!
                • Airguardian
                  Post Stall Svengali
                  • Aug 2020
                  • 1676
                  • Catalonia
                  Still my favourite foamy... just can't beat it!
                  • aamz13
                    • Jan 2021
                    • 22
                    https://youtu.be/2GXn0copBzM
                    Good to see it operate on grass. The field I am comfortable for maidens is a grass field. My yak 130 is put together, F-22 is next then its time for some vectored thrust on the SU-35. I will have lots of questions for sure
                    Thanks again
                    • Airguardian
                      Post Stall Svengali
                      • Aug 2020
                      • 1676
                      • Catalonia
                      It is grass capable but it may require some tweaking on your end to operate from grass.
                      Test as is, and if you have problems, come here again... it's been covered extensively in RCGroups and I suppose here too...
                      • Airguardian
                        Post Stall Svengali
                        • Aug 2020
                        • 1676
                        • Catalonia
                        And remember to reinforce the nose gear as suggested! ;)
                        • radfordc
                          • 375
                          • Lansing, KS
                          Thanks again
                          I made several modifications to accommodate grass ops: larger nose wheel (58mm vs 45mm original), 3mm plywood spacer under the nose gear retract unit, gear strut braces to help prevent strut bending.
                          • Airguardian
                            Post Stall Svengali
                            • Aug 2020
                            • 1676
                            • Catalonia
                            Most importantly, need to glue a balsa wood planck to the front of the battery compartment so the foam that houses the nose gear doesn't break as easily.
                            It may even break after this mod, but if you then glue the thing back in with epoxy, it's not ever going anywhere again :)
                            • radfordc
                              • 375
                              • Lansing, KS
                              This is what I did. Click image for larger version
                              • Airguardian
                                Post Stall Svengali
                                • Aug 2020
                                • 1676
                                • Catalonia
                                That's quite overkill... but whatever floats your boat. ( :
                                (With the planck on the front end I think it's more than enough)
                                Also a good idea to install a velcro more to the rear so you can secure heavy batteries (which need to go aft) properly.
                                • kallend
                                  • 1877
                                  I epoxied a layer of glass cloth over the foam at the weak spot.
                                  • Airguardian
                                    Post Stall Svengali
                                    • Aug 2020
                                    • 1676
                                    • Catalonia
                                    That would do it too... but balsa may be more user friendly for most :)
                                    • TangoVector
                                      High alpha wannabe
                                      • Feb 2019
                                      • 142
                                      • Leksand, Sweden
                                      Finally had some time to start fixing my planes... I have upgraded the elevon-servos to Turnigy DMC809. They are quite small, but very quiet and with good precision. 3D-printed an insert to keep the servo snuggly in place. Nice to have the printer around, took me 10min to draw one and mirror it, and 1hr to print both.
                                      The new FMS 70mm 12b PRO's are also in place with 80A ESC:s. All that is left now is the nose-gear changed to Avanti version. Not scale but I prefer good grass capability since the grass is a little tall at the club sometimes.
                                      • Airguardian
                                        Post Stall Svengali
                                        • Aug 2020
                                        • 1676
                                        • Catalonia
                                        Have a few of those DMC809 but never got to try them in flight yet... they should be quite an improvement over the stock ones! ;)
                                        • TangoVector
                                          High alpha wannabe
                                          • Feb 2019
                                          • 142
                                          • Leksand, Sweden
ID:	315600 It ain’t gonna be pretty…
