  • e4dragongunner
    Living the dream!
    • 876
    • Arlington Heights Il.
    Originally posted by Visva11
    Hey pal, have u completed the full gear door mod?
    Would love to see it.
    thanks
    Simply amazing work Steve! LOVE IT . The Speed /Accuracy and Consistency with which you produce these wonderful modifications is truly astounding.! Thanks for living on the BLEEDING edge and showing us all what's possible !!!!
      thanks
      Here you go.
        Here you go.
        *#*#34872#*#*
        IE 11 says:
        This page can’t be displayed
          • 5416
          The MCB-E or whatever blue box in the F-22 and L-39 is very different than the other blue boxes such as in the Mig. The older ones had a lot of reported issues. The new one has had one specific one about the steering and landing light not working. An odd but specific complaint.
          I dont use the rubber battery matt, I still prefer Velcro. But those that I have seen use it do not glue it down.
          I’m up to about 40 flights on mine and no issues. I did find a JF 8S system to try in it.
            Originally posted by OV10
            IE 11 says:
            You got to it before I could get it updated....I had a connectivity issue on the first attempt so it copied the link wrong.
            • e4dragongunner
              Living the dream!
              • 876
              FYI... Upgrading my 6S f-22 to My F4's 8S system..... Ordered JP Hobby fan 6S for my F4. :-)
              Specifications Special high grade aluminum quality Motor Kv: 1750 Motor type: JP 4250-Ⅵ-1750kv (5mm axe) 12 poles (outrunner) Rotor: 90mm 12 blades aluminium External diameter: 94.5mm Internal diameter: 90.5mm Ejection diameter: nc Combo max thrust: 4.32kg Weight: 459g (combo EDF + lip + motor ) Max efficiency: 90 % Recommended max. rotation speed: 75,600 RPM Speed Control Advanced Timing Setting: 15° Connections: Banana / PK 5mm (in place)
                Steve, you are the King of Mods brother, well done!
                • e4dragongunner
                  Living the dream!
                  • 876
                  Sho NUFF!!!
                    More Texan slang here.... I AM FIX'N TO do the mods on mine!! :P
                      I can't paint my cockpit, but I USTA COULD when I was younger!! :Silly:
                        Also, I am having a difficult time finding the neutral point for the elevator. I have looked over the diagram at the manual but it's finding the precise centerpoint as the base to measure up 5.5mm to is which I am having trouble with. I *think* I have it but I was wondering if someone had a photo of where the TRAILING EDGE of the elevator lines up with the aft section of the fuse. This will tell me how close or how far off I am. I appreciate the help. Here's a photo of where I have mine at the moment...
                        Click image for larger version  Name:	Capture1.JPG Views:	2 Size:	47.1 KB ID:	172765
                          I see Steve mentioned that it's waaaay too much down which is what I expected. I would assume the trailing edge of the elevator should match up with the trailing edge of the fuse. Clearly I measured from the wrong location.
                            See mine? Mine is only slightly down elevator. Half a trailing edge thickness of down in relation to the trailing edge of the fuse. Roughly 5.5 mm from the bottom edge of the fuse to the center of the stab.
                            Click image for larger version  Name:	IMG_20181228_230732.jpg Views:	2 Size:	233.0 KB ID:	172768
                              Perfecto Steve, just what I needed. Thank you!
                              • tengarang
                                Banned
                                • 382
                                • Yay Area, California, USA
                                Originally posted by C17loadmaster
                                Oh sorry... I should have been more specific. I have the FMS 12b outrunner 1900kv with a YEP 150a ESC. I have all of the motor/fan options you listed but I havent flown with them yet. The newer FW 12b 6s is in one of my F-15s to replace the Inrunner it came with. Also, I haven’t flown the FW 8s yet, it’s in my Raptor that was ordered an hour after the plane became available. I’ve been modifying it slowly, but I’m going to have to get it in the air soon. I have way too many projects going on. I’m adding slime lights, navy lights, 3D cockpit?upgrading the BEC, and swapping the receiver and gyro for AS3X. I ordered the centerburner the day I ordered the plane to beat the rush.
                                The F-16 had the older version 12 blade outrunner in it when I swapped it out for the FMS. It was a great upgrade for the stock 6s setup but I think anything is haha. I don’t think I have heard anyone complain about the FMS and YeP in any plane. The only issue is that the shroud is bigger than the Freewings so I had to remove foam to get it installed. It wasn’t that big of a deal though.
                                Really appreciate the info was an interesting read.
                                So you are using the fms 90mm 19blade 1900KV. I hear this setup is really good, one of my friends is using it and seems like its a promising setup as well. Also the cheapest fan out there.
                                The only reason i am not going with this fan is because of the fact that i dont want to bother with the foam removal to get it installed since the footprint of the F22 hull does not 100percent match the fms outer shroud.
                                Glad its all working well for you. THis will be my second big edf aside from the mig
                                • tengarang
                                  Banned
                                  • 382
                                  good to know glad they got it resolved....
                                  • bill34207
                                    Jet Junkie
                                    • 455
                                    • Bradenton, Florida
                                    Here you go.
                                    If you plug he main doors into the other "double stage" port would the outer doors close after the gear is extended?
                                    • Flash Jorden
                                      • 77
                                      Here is what you need. Make sure you get it right, or otherwise if it's set too high, you will run out of up elevator, and have major issues flying ... ask me how I know.
                                      • Flash Jorden
                                        • 77
                                        Any idea when the ARF or ARF plus versions will be in stock?
                                          :Scared:
                                          Copy that...From the bottom of the fuse side up to 5.5mm. Appreciate it!
