Luckily the 90mm F-22 has a huge presence in the sky
You should have no trouble with this one (aside from the coloration).
It seems huge and on 6S visually slow when you first fly it. My first thoughts when I first got mine was "this thing is huge" (it was my first 90mm) and "why is it going so slow". It's deceptive.Comment
Depends on too many variables. What 8S set up, your style of flying and throttle usage are the main ones but altitude, wind and other things can effect it too. I have a JF/ HET 8s and run 5200's for 4:30.
That it's 4+4 doesn't matter.
There was a question on brakes. This plane can land very slow and I don't have brakes on mine but many have put them on theirs. Maybe ask on RCG too?Comment
Hi I’m new to this forum and love your center burner. Where can I get one for my F-22? And is there a install video to see how it’s done. ThanksThe way that this balance adapter is wired will pull 2s voltage from your 6s pack. Connect this to your balance lead on your battery and it will give your Centerburner the power it need to operate. No need to connect to anything else. Just the balance lead on your battery. My LED Afterburner set up works the same way by getting voltage through the adapter but it operates off of 3s voltage. Its really simple and easy.Comment
Thanks for the info on the breaks I’ll check RCGDepends on too many variables. What 8S set up, your style of flying and throttle usage are the main ones but altitude, wind and other things can effect it too. I have a JF/ HET 8s and run 5200's for 4:30.
Got my F-22 today two days early thanks Motion RC. This plane is beautiful can’t wait to build and fly it. Ordered my afterburner today also. Still waiting for gyro should have ordered it at the same time as the plane but was on the fence about it. Well let the fun begin.Comment
The UBEC lead plugs directly into the RX, either into a spare channel, or the bind port, or Y'd into a channel (like throttle). Personally, I'd cut the wires on the switch and connect them together. You lose some weight and eliminate a potential failure point.PatComment
