    • 5424
    No gyro/ stab on mine but many will tell you all planes fly better with them.
    • InTheTubeDeep
      • Jun 2022
      • 80
      Ok good to know- should be an interesting maiden!
      • InTheTubeDeep
        • Jun 2022
        • 80
        Just applied the decals - my wingtip rails are dialed in printing production rails now- anyone need a set LMK! Also tweaking my Burners to fit the 36mm can, hopefully get that installed this weekend- low tides are coming next week I should be ready! I made Blue Burners on Su30 Alenka, these will be Amber
        • InTheTubeDeep
          • Jun 2022
          • 80
          More rails final version
            • 2716
            Excellent job on the printing, you're really dialed in with that printer, a worthy skill. Nice to know a source for the rails, something that's easily broken (at least in my case) and almost impossible to replace without getting the entire wing. Your on "Source List". Bravo!
              Nice work on those rails InTheTubeDeep! Like Hugh said, they break easily and I still can't believe FW didn't make those as separate spare parts. They could have made a fortune on those alone, lol.
              • Eagleflight47
                • Apr 2020
                • 3
                Thinking about buying an F-18 to eventually do a turbine conversion with and have a couple questions for the group. Before putting in a turbine, I want to fly it as electric to get used to the airplane. I am considering buying the ARF+ and dropping in an 80mm FMS Predator 3280-KV2100 that I already have on the shelf at home. Will this be sufficient power or should I stick the the 90mm HP? TIA
                  • 5424
                  Get the PNP and sell anything you don’t want later. The PNP is always a better deal financially than the kit+.
                  • InTheTubeDeep
                    • Jun 2022
                    • 80
                    Working on a Amber Burner now 2 versions
                    • jasmith41
                      EDF-obsessed
                      • Sep 2021
                      • 317
                      • AZ and NE Ohio
                      Sorry for this, but I'm thinking there are a lot of other people like me - have / fly both FW and Eflites...
                      Anyway, this pertains to the Eflite Viper 90. I crashed mine and i'm in the process of putting her back together, but i wasn't smart enough to take pics of the nose gear linkage / set-up when i took her apart, so if any of you have one of these birds and would help a brother out, please send me a pic of the nose gear down inside the gear bay so i can see what i should have photographed... and how the linkage all goes back together...
                      many thanks in advance if there's anyone that can assist...
                      • InTheTubeDeep
                        • Jun 2022
                        • 80
                        I finalized the Burner after 3 print versions
                        • InTheTubeDeep
                          • Jun 2022
                          • 80
                          Whats in the Box
                          • InTheTubeDeep
                            • Jun 2022
                            • 80
                            Finalized the Burner, making 3 will sell 2 here if any F18 pilots interested please PM me!
                              Elbee commented
                              Editing a comment
                              ITTD, ask anyone interested in purchasing these to send you a Private Message (PM) and/or post the offer in the Classifieds (bottom of Home Menu Page)/ Respectfully, LB
                          • InTheTubeDeep
                            • Jun 2022
                            • 80
                            LB noted ⬆︎. Pilots where are you setting ELE- lined up with the Fusi seam line?
                            • The swede
                              Bulten10
                              • Dec 2018
                              • 15
                              Hi all!
                              My F18 is done and ready for maiden.
                              • InTheTubeDeep
                                • Jun 2022
                                • 80
                                Originally posted by The swede
                                Hi all!
                                Meget bra! Looks cool the Viking on vert stab is sick! What CG will you maiden??
                                • InTheTubeDeep
                                  • Jun 2022
                                  • 80
                                  The blue box is screwed in! Luckily I unscrewed the batt tray and noticed before I broke something trying to cut it out- I designed an extended tray stock is 228mm, if I measured correctly its another 62mm to back wall, so made a single tray 290mm, but that came out to 11hr print so I just designed a shortcut to glue to original tray added 62mm, should be functional and allow the SMC 6200s or other LiPos to be pushed further aft
                                    • 4873
                                    ...I designed an extended tray ..
                                    TD, Nicely done. Best, LB
                                    • InTheTubeDeep
                                      • Jun 2022
                                      • 80
                                      Ha I didn't have the patience to wait 11 hours this will do just fine! Here's the STL for those interested- simply glue to existing tray (just tweaked it)
                                      FW 90mm Batt Tray Short 62mm v2 (1).stl
                                      • The swede
                                        Bulten10
                                        • Dec 2018
                                        • 15
                                        InTheTubeDeep Tack😁
                                        I think I go around 95 on the CG, en work from there if I need. And I have some up elevator mixed to the flaps, I hope that will work as a starting point.
                                        And for the Gyro (Spektrum AR8360T) I really don’t know. Three position switch with off, 35/35/35 and 40/50/60 maybe?! if anyone has a good tip, it is gratefully received. :-) I don’t want to mess with a knob when Im flying 😅
