    • 5401
    No gyro/ stab on mine but many will tell you all planes fly better with them.
    • InTheTubeDeep
      • Jun 2022
      • 80
      Ok good to know- should be an interesting maiden!
      • InTheTubeDeep
        • Jun 2022
        • 80
        Just applied the decals - my wingtip rails are dialed in printing production rails now- anyone need a set LMK! Also tweaking my Burners to fit the 36mm can, hopefully get that installed this weekend- low tides are coming next week I should be ready! I made Blue Burners on Su30 Alenka, these will be Amber
        • InTheTubeDeep
          • Jun 2022
          • 80
          More rails final version
            • 2700
            Excellent job on the printing, you're really dialed in with that printer, a worthy skill. Nice to know a source for the rails, something that's easily broken (at least in my case) and almost impossible to replace without getting the entire wing. Your on "Source List". Bravo!
              • 8225
              Nice work on those rails InTheTubeDeep! Like Hugh said, they break easily and I still can't believe FW didn't make those as separate spare parts. They could have made a fortune on those alone, lol.
              • Eagleflight47
                • Apr 2020
                • 3
                Thinking about buying an F-18 to eventually do a turbine conversion with and have a couple questions for the group. Before putting in a turbine, I want to fly it as electric to get used to the airplane. I am considering buying the ARF+ and dropping in an 80mm FMS Predator 3280-KV2100 that I already have on the shelf at home. Will this be sufficient power or should I stick the the 90mm HP? TIA
                  • 5401
                  Get the PNP and sell anything you don’t want later. The PNP is always a better deal financially than the kit+.
                  • InTheTubeDeep
                    • Jun 2022
                    • 80
                    Working on a Amber Burner now 2 versions
                    • jasmith41
                      EDF-obsessed
                      • Sep 2021
                      • 317
                      • AZ and NE Ohio
                      Sorry for this, but I'm thinking there are a lot of other people like me - have / fly both FW and Eflites...
                      Anyway, this pertains to the Eflite Viper 90. I crashed mine and i'm in the process of putting her back together, but i wasn't smart enough to take pics of the nose gear linkage / set-up when i took her apart, so if any of you have one of these birds and would help a brother out, please send me a pic of the nose gear down inside the gear bay so i can see what i should have photographed... and how the linkage all goes back together...
                      many thanks in advance if there's anyone that can assist...
                      • InTheTubeDeep
                        • Jun 2022
                        • 80
                        I finalized the Burner after 3 print versions
                        • InTheTubeDeep
                          • Jun 2022
                          • 80
                          Whats in the Box
                          • InTheTubeDeep
                            • Jun 2022
                            • 80
                            Finalized the Burner, making 3 will sell 2 here if any F18 pilots interested please PM me!
                              Elbee commented
                              Editing a comment
                              ITTD, ask anyone interested in purchasing these to send you a Private Message (PM) and/or post the offer in the Classifieds (bottom of Home Menu Page)/ Respectfully, LB
                          • InTheTubeDeep
                            • Jun 2022
                            • 80
                            LB noted ⬆︎. Pilots where are you setting ELE- lined up with the Fusi seam line?
                            • The swede
                              Bulten10
                              • Dec 2018
                              • 15
                              Hi all!
                              My F18 is done and ready for maiden.
                              • InTheTubeDeep
                                • Jun 2022
                                • 80
                                Originally posted by The swede
                                Hi all!
                                Meget bra! Looks cool the Viking on vert stab is sick! What CG will you maiden??
                                • InTheTubeDeep
                                  • Jun 2022
                                  • 80
                                  The blue box is screwed in! Luckily I unscrewed the batt tray and noticed before I broke something trying to cut it out- I designed an extended tray stock is 228mm, if I measured correctly its another 62mm to back wall, so made a single tray 290mm, but that came out to 11hr print so I just designed a shortcut to glue to original tray added 62mm, should be functional and allow the SMC 6200s or other LiPos to be pushed further aft
                                    • 4852
                                    ...I designed an extended tray ..
                                    TD, Nicely done. Best, LB
                                    • InTheTubeDeep
                                      • Jun 2022
                                      • 80
                                      Ha I didn't have the patience to wait 11 hours this will do just fine! Here's the STL for those interested- simply glue to existing tray (just tweaked it)
                                      FW 90mm Batt Tray Short 62mm v2 (1).stl
                                      • The swede
                                        Bulten10
                                        • Dec 2018
                                        • 15
                                        InTheTubeDeep Tack😁
                                        I think I go around 95 on the CG, en work from there if I need. And I have some up elevator mixed to the flaps, I hope that will work as a starting point.
                                        And for the Gyro (Spektrum AR8360T) I really don’t know. Three position switch with off, 35/35/35 and 40/50/60 maybe?! if anyone has a good tip, it is gratefully received. :-) I don’t want to mess with a knob when Im flying 😅
