    Got mine fully assembled, decaled and programmed last night. The good news is that the blue box seems to play nice with my Graupner RX! No jittery rudders or loss of function with gear up like on my L-39 and F-22. I will continue to test that out before the maiden on Saturday.
    All that's left to do is pull the gear and paint the struts white, as well as the wheel wells, then add a gloss coat.
    • bill34207
      Jet Junkie
      • 455
      • Bradenton, Florida
      I used one of the new Turnigy Plush 32 120A 8S ESC/BEC. It’s smaller than the stock PNP ESC so no...
      Thanks for that info Evan. I just ordered one myself after finding out it would require some major butchering to get the CC Talon 120 I had put away for use in this one to fit into the channel.
      • DCORSAIR
        • 1918
        • Selma, Ca.
        Originally posted by Lcacing
        Why not instead of buying new esc just solder some extra wire to the esc you have or if you don’t want to solder just get a extension.
        Thanks, yeah I thought of that and extend the wires, just checking if someone might have one before I cut my other one or make an extension. Thank you.
        • janmb
          Slow and low
          • 729
          Originally posted by fordster39
          I don’t use a BEC, I use a 2 cell 2100 mah Lipo battery to supply power to the receiver.
          Unregulated 2S lipo is way too much voltage for most of the noname China components. Even a lot of good brand HV servos won't be specced for that much.
          • gooniac33
            The Original Gooniac
            • Jun 2016
            • 1047
            Agreed... nothing wrong with using the battery but use a regulator...
            • Dustman
              • 81
              Where can I find the file to print the 3d wheel covers and cockpit instrument panel for the F-18?
                • 8207
                Wow, talk about a No Fuss Build! Went together, got her CG'd, rates/throws all on my lunch break. The wait for a quality large F/A-18C Blue Angel is finally over. The wait was worth it! I can't wait to maiden this weekend!
                • Dustman
                  • 81
                  This is the livery shim I'm going to do on my F-18.
                    • 4822
                    Originally posted by Dustman
                    This is the livery I'm I'm going to do on my F-18.
                    Gorgeous DM, Pictures please. Best, LB
                      See post 553 of this thread.
                      • Dustman
                        • 81
                        What page would post 553 be on? ....Never mine I found it.
                        • mr.frankenjet
                          Eat, sleep, FLY FLY FLY !
                          • 448
                          • Virginia, USA
                          good luck Aros, she looks sweet ! Happy landings
                          rc flyin addict
                          • Bobaroo
                            If it Ain't Right on the Ground...
                            • Dec 2017
                            • 327
                            • Newburgh, IN
                            WellNow,.. Mixed emotions here.
                            The FW F/A-18C came through and survived the new FedEx Shipping Process without a flaw !!! The Yard up there by the driveway however !!! Not so much. Never had a problem with UPS Driver (Preferred). This is the second time with FedEx. Bummer,... I've got a complaint started with them in their system.
                            This one will most likely be done up as a BlueAngel. First thing to be done was to remove that silly little 4th Grader in the Flight Helmet from the cockpit. Next will be getting rid of that Light up there on the Dorsal Spine ...I will spare all of you the details of the rest of the process of converting this Base Gray into a proper looking BlueJet. Here are a few more Reference Photos for your enjoyment. Cheers !!
                              • 8207
                              Thanks man! Hopefully I can maiden this Friday or Saturday...
                              • EA-6B Geek
                                EW Misfit
                                • 485
                                • South Central Ohio
                                I may need to rethink the VMFA-232 paint scheme I'm putting on my Hornet. O Canada!
ID:	201333Click image for larger version
                                • John_53_70
                                  Pilot
                                  • 41
                                  Originally posted by Alpha
                                  Keep your repaint photos and early setup/maiden reports coming, guys and gals! Call the tech team for any hiccups along the way, as usual for any purchase. Callie mentioned her F-18 decals sales have been off the charts, so I know there are so many more customized Grays out there. Thanks for supporting her!
                                  I'm taking my VFC-12 out later this week, hopefully with good weather. Just need to finish some finishing touches before our announcement..
                                  Click image for larger version  Name:	IMG_20190613_172221.jpg Views:	219 Size:	107.4 KB ID:	200871
                                  Hold the phone!!!! Whats this annoucement you speak of???? 🧐 do I detect Another guessing game 😁
                                  • Dannythiessen2@gmail.com
                                    • Jun 2019
                                    • 26
                                    Anyone else have this?
                                    FREEWINY MODEL
                                    • RichJ53
                                      • Nov 2018
                                      • 342
                                      • Southern Oregon
                                      Looking good!!
                                        • 8207
                                        Originally posted by Dannythiessen2@gmail.com
                                        Anyone else have this? FREEWINY MODEL
                                        Yes I got a good chuckle at that today. Not sure if it was a misprint or purposeful for some odd reason. Either way it made me LOL
                                          • Jun 2019
                                          • 26
                                          What size Battery did everything get just curious?
