If I remember, you have a Castle ESC in it. After I programmed mine (although it is a 6S) it removed the low voltage cutoff (actually not removed, just reduced as per their chart). Originally, when I plugged the 6S HiV batteries in, fully charged, I got 7 beeps, so it thought it was a 7S battery and used that cutoff point, which ended up around 50-60% battery charge. At that point (tested it out on the bench before flying it), when the batteries got down after maybe 2 minutes, the motor began to pulse and loose power. After letting it sit for a bit, the batteries rebounded enough to get full throttle, but only for a short time before loosing power and pulsing. After I changed the low voltage cutoff, it doesn't exactly beep the number of cells anymore, just allows you to drain the battery to that new point before loosing power and pulsing. You can still use standard 4.2 volt batteries, but again, it will not beep the indicated number of cells.
I'm not sure why you lost power so quickly, after 1 minute, would have expected it to go 2 min, but maybe being 8S and thinking it was 9S the cutoff voltage is much higher. And not sure why the ESC would not start the EDF again. Is the Castle ESC for 8S?
Should work fine after changing the the low voltage for an 8S as per the Castle website chart. Suggest you first test it out on the bench and do a 3-4 minute simulated flight adjusting the throttle for take-off, cruising, etc.(or whatever you're timer is set for). Let me know how it comes out.
BTW, on the Freewing ESC's that I had to remove the low voltage cutoff (1 F-18 &1 F-4), with a HiV battery it gives no beeps. With a standard 6S at 4.2 volts it still gives 6 beeps even after removing the low voltage cutoff. I reprogrammed 5 other Castle ESC's in my Extreme Flight 3D planes and one in a Beast BiPlane and another in an Aces High FW 190, and they work perfect, either HiV or regular, and the ESC does not beep at all.
for landings.
can happen at anytime!
Maybe we will revisit her again next year since all I need is a new fuse to get her back in the air.......
