Mine were close enough... enough for a Russian bird. If it was US it would be in the hanger. :)
New Avios Mig 17 ?
I think this happens more than one thinks. Yes, I had an ELE and a Flap servo that was "off" but more importantly, was different than the other side. I tried to remove the servo arm and clock it one tooth over but this made it sit too far the other way, so still no joy. I ended up putting it back the way it was and set it up the best I could. The plane seems to fly OK. The time this will present a problem is if you use full servo travel on full rate. Then one servo could deflect the control surface more or less that the other at full stick. In that case, reduce the servo travel in the direction enough to prevent travel too close to the end point. In the case of elevators and/or AIL, you could play a bit with differential to see if that helps to even out the surfaces travel. Otherwise, you'll just learn to NOT bang the sticks all the way to the ends if it causes a problem.Comment
More than half of my servo arms were off center, easy to recenter them except for the elevator servos that are glued in. I made a small channel in the foam so I could get to the screw, it's on the bottom and no one can see it.I think this happens more than one thinks. Yes, I had an ELE and a Flap servo that was "off" but more importantly, was different than the other side. I tried to remove the servo arm and clock it one tooth over but this made it sit too far the other way, so still no joy. I ended up putting it back the way it was and set it up the best I could. The plane seems to fly OK. The time this will present a problem is if you use full servo travel on full rate. Then one servo could deflect the control surface more or less that the other at full stick. In that case, reduce the servo travel in the direction enough to prevent travel too close to the end point. In the case of elevators and/or AIL, you could play a bit with differential to see if that helps to even out the surfaces travel. Otherwise, you'll just learn to NOT bang the sticks all the way to the ends if it causes a problem.
Definitely not like freewing or fms where they actually took the time to center them (mostly)Comment
I've had the problem with quite a few FreeWing, Flight Line and FMS... This plane was okay. In fact it's bee okay about everything. It all works, nothing has failed and none of my servos even buzz. Four more flights today on 6200 and 8000 packs.
Mine works great (after I replaced the non functional flap servo), but some of the servos buzz most of the time, even when there's no stress on them. Usually I can make it stop buzzing by just tapping the servo with my finger
A lot of people on the Avios Albatros and C-130 threads said their servos buzzed and then would die. I'm keeping my fingers crossed.
WOW what a journey this has been!! Nothing was easy about this plane aside from getting the clear coat put on... Everything went wrong!!! Sequencer went out which meant I needed to bypass it and removed the inner gear doors which were a real pain for transporting with wings off. Then one of the ports on the Gear Controller board failed which meant I needed a Y (that I actually made at the field) cable to make it work. I didn't have any at the field so had to make on myself. Then while doing a preflight the nose gear and rudder servo stopped working... i didn't want to take any risks with the flap servos so I just glued the flaps in place and left them disconnected. Oh and then to top it off I forgot the LED afterburner controller at home!!! Needless to say it was a pain... but I did get it done! The plane flew great even with the issues noted above. Now I just need to figure out what servos to change out... battery for this flight was a 6s 50c 6200 Hobby Star pack that has bee very well used but still in good shape. After all the set up and the 3 min flight battery was at 3.85v per cell. I hope that this fan holds up because it is very efficient!!Check me out on youtube at https://www.youtube.com/user/gooniac33
I am an RC addict and innovator that loves to share my knowledge with those that need help. Ask me anything via PM if you need help! Check out my Website here https://www.gooniac33.me/Comment
Two more flights on mine this morning. Both were great and I'm starting to get the hang of the landings - only a couple of small, light bounces and one landing was near perfect. I think I may move the battery forward a bit to see if that will improve the landings even more. It's balanced just at the point where if I put it on its tail, it will just stand itself back up on its own. It teeters almost perfectly. I think I'd like a little more weight on the front wheel.Comment
Rabid Models foamies, including my 8' B17 & 9' B36... and my Mud Ducks! www.rabidmodels.comComment
Wow.... Congrats bro! What a job.
