Doesn't bother me in the least. I guess whatever a real SU30 can do would be considered "scale" like and herein lies the issue of definition. What does one define as "scale like"? I consider "scale" like to be whatever the real thing can do. Some may interpret "scale" like to be relaxed and lumbering at low throttle. That's not me. I see some people use the term for when a plane is too underpowered to get out of its own shadow or they don't have the skill to fly it to the max, so they fly it slowly and more easily controlled by the skill they have. They call it "flying scale".
I don't think the stock model of this plane can do some of the stuff the real one can do. One example might be the "cobra" maneuver. This plane doesn't have the power to do it smoothly and fly out of it like the real one. It would likely fall like a perforated manhole cover in the middle of it. With no VT and the stock thrust to weight ratio, trying to do what the real one does at airshows would suck up the battery so fast that you might be lucky to get 1.5 minutes out of it.
My SebArt Mig29 (also twin 70mm) can and has plenty of power to do anything the real can. It's only limitation is my skill.
. Once you get them free, it will make installing the battery sooooooooooo much easier!
Can't tell you how often I cursed HH/E-Flight over this simple thing when I first started flying this bird. Of course found a bunch of other reasons,
but done with this one issue.
Sliding a feeler gage between the strap and the ply works well rather then drilling holes in the ply and then poking it with a screw driver, but if there is a lot of glue on the strap an ply drilling holes and using a screw driver to work it loose is also a good way to fix the problem
