    • 2708
    Originally posted by radfordc
    No asphalt here...just a not so smooth grass field. I'm flying a 70mm BAE Hawk, twin 70 Me-262, 80mm Gripen, and twin 80 Mig-29 and they are all doing OK.
    A buddy of mine has both the Gripen and the Mig-29 and they get off our grass field with no problem in 100' or less. The SU-30 on the same field, not so much, more like 150' with no wind, but a decent 10 mph head wind helps quite a bit. My 90 mm F-4 (with the original 1750 Kv outrunner), the F-18 (with the same older fan as the F-4) and my F-16 with the 12 blade 1835 Kv inrunner also get off in less than 100', just for a few comparisons to the SU-30 on the same grass field. I'm sure you'll be able to get it off OK, just don't expect it to take off as quick as the Gripen or Mig. Can't wait to hear about your maiden, I'm sure you'll do great!
    • Wild Man
      • 526
      • Rapid City, S.D.
      I have the FMS BEA Hawk Red Arrow 80mm and the twin 70mm Me-262 and many more The BAE Hawk from FMS is a great Flier. I really like to relax while I am flying I still have two JR 10 X's that I still use out here in fly over Country LOL!!!!
ID:	296426Click image for larger version
Name:	test flight hawk.jpg
      • JeremySean
        • Mar 2020
        • 31
        Just finished this Royal Malaysian Air Force scheme! Now just need decals.
          • 2708
          Very Nice! Post some final photos with the decals, Callie's no doubt.
          • Rcfiddy1
            Professional Crash Test Dummy
            • Aug 2015
            • 186
            • Manalapan, NJ
            Originally posted by Wild Man
            Sounds like a bad receiver. One other think to check, Have you tried to rebind it ? I have not had any problems with mine
            Receiver works. Tested gear and they don’t work. I ordered a new set and installed only to see them fail after cycling them a few times. It seems to be something in this gear door sequencer. I’m out $120 and have 2 sets of faulty landing gear. Plus the new airbrake uses a different size aluminum brace tube than what was originally used. So that needs to be fixed. Starting to think this plane is a 1st batch lemon. May just cut my losses and part her out or sell airframe. I’ve only flown it a half dozen times and always had issues. Bad steering servo right out of box, airbrake doesn’t sit flush with fuse, wing to fuse joint wasn’t right. Never again will I jump on a preorder.
            • radfordc
              • 375
              • Lansing, KS
              Flew mine for the first time yesterday. The day was nice...light breeze down the runway and about 65 degrees. With the larger nosewheel and extended strut the plane flew off the grass strip with no problem. My impression of the jet is much like others....flys heavy, rolls very slow, short flight time. First three flights went well but disaster on the fourth flight. The plane stopped responding to my control and hit the ground hard. I suspect that the BEC may have come unplugged....whatever it was it happened quick. Plane is rebuildable.
                • 2708
                https://youtu.be/Nq_OfvGNfYk
                Sorry to hear that. For me, this is one aircraft that every 10 flights or so, I'm repairing / rebuilding something. So far all doable but who knows what it's lifespan is.
                radfordc I replaced the stock AR636 with an older 7 channel AS3X for flaperons (grass ops as well) and keeping the airbrake, but also to hook up a satellite remote. Didn't like the stock RX placement cause I felt it could lead to issues being between the battery and ESC. Also added as many RF chokes I could, maybe at least 6, as per GliderGuy. Sounds like you may have lost signal. This is one aircraft that's tough enough to get a decent flight out of without having to worry about signal loss.
                  • 2708
                  BTW, radfordc, your initial take offs, flight and landing all looked great, so you definitely got the "right stuff" to fly this. Seems you lost signal when it was coming at you, meaning the battery was probably blocking the signal to the RX behind it. 1 of my remotes is in the very front of the nose.
                  • radfordc
                    • 375
                    • Lansing, KS
                    I use Frsky so no remotes. It's possible the battery blocked the signal, but I haven't had any problems in other jets that have the battery in front of the Rx. I'll make sure the antennas are oriented as well as possible next time.
                      • 2708
                      radfordc As long as you're rebuilding/repairing, a couple things to consider.
                      1) I put some reinforcement behind the nose gear brace rod (or whatever it's called). In the Stock setup, it goes into a piece of plastic that's glued into foam between the air intakes, no real bracing. After about 50 flights noticed mine was pancaking the foam and causing the rod to be loose. 90 degreed some carbon tubing and other pieces to take and spread the load of my "bull in a china shop" landings.
                      2) Carbon fiber tubes in the fuselage end just behind the battery bay, real clever engineering. Again happening after some 60 flights the fuselage started developing stress cracks just behind the battery where the nose wheel folds in. But being stupid, I disregarded the stress cracks and in an effort to get more flight time, I tried my Hobbystar 8000 mah that flies outstanding in my F16 and gives me over 5 minutes of flight time. Well, it barely got off the grass, had almost 0 vertical and required almost 80 to 90 % throttle to keep it up, resulting in almost no additional flight time. Upon landing, even with the nose up, when the front wheel came down, the entire front section with the battery dropped off.
                      I now only fly it on a 5000, at least it performs better than on a 6000 and I still get about the same flight time. Maybe it's just me or my flying, so just some food for thought.
                      • Wild Man
                        • 526
                        • Rapid City, S.D.
                        I have flown mine many times. I have done more damage to it moving it in and out of the house and or garage last thing I did to it was set it on a table out side between the house and garage, it fell off the table and before I could catch it it wriggled the left wing when it hit the floor Ouch.
                        • radfordc
                          • 375
                          • Lansing, KS
                          The repairs are coming along. I used strips of CF on the outside of the fuse to hold the broken parts together while being glued. I had some areas with no foam and I used some expanding spray foam to fill in the holes. My bigger issue is trying to find a replacement for the wing spar. HH doesn't have one in stock. They may have them in April. I measured the original and it is 9.65mm (.380) which isn't a standard size. I can find 10mm or .375". Will try one of those and see if it works.
                          Click image for larger version  Name:	IMG_20210305_142948.jpg Views:	0 Size:	115.3 KB ID:	302649
                          • Chrisi f-18
                            • Feb 2020
                            • 4
                            • Saarburg Rheinland-Pfalz Germany
                            Hi I have also the su30. I made a turbine conversation with a lambert Kolibri t30. The plane is soo amazing with this combo. The complete su has a semi scale Weathering, Afterburner simulation and the gun isolation replicate with flite metal. Greets chris
                            • radfordc
                              • 375
                              • Lansing, KS
                              Sehr gut!
                              • Chrisi f-18
                                • Feb 2020
                                • 4
                                Thanks 😊👍
                                • hcew
                                  • Nov 2020
                                  • 10
                                  Hi Su30 flyers,
                                  Saturday I made the maiden out of gras. The speedbrake stops working during the second flight. My question, how many lead do you have in the rear? When I use 6000er LiPo with 840g I need nearly 400g in the tail by using CG of 150mm.
                                  Christian
                                    • 2708
                                    Originally posted by hcew
                                    Hi Su30 flyers,
                                    Christian
                                    Christian, that sounds about right for a 6000 mah LiPo. I've tried several different batteries in mine to try and get longer flight times and optimum performance and it's a tough puzzle to figure out. IMO, this is a very heavy EDF and underpowered. I've used RT 5500, HRB 6000's and even a HobbyStar 8000 but with the weight of those batteries (794g/825g/890g) nothing seemed to really help. I added about 100 g of lead in the tail but was only able to get the CG back to 130mm with RT 5500 (794g). Still didn't fly all that well and with the 8000 mah barely got off the grass and had no vertical. Just as bad, to keep it going, with the higher capacity batteries I had to use more throttle, thus reducing flight time. In the end, about all I could get was just over 3 minutes no matter what battery I used. Lately I've been flying it on a 5000 mah battery with a weight of 754 g. This offers the best flight characteristics and ends up giving just about the same amount of flight time, 3 minutes (with a reserve for a go-around). With that set-up and the 3 ounces of lead in the tail (also have some extra weight there from 2 LED afterburners), it flies about as well as it's going to and my CG is close to 150mm. This is a great looking jet on the ground and in the air, but it is just not the best flying EDF, always a challenge.
                                    I even use flaperons to help grass take-offs and changed the front nose wheel from the stock 1 7/8th to a Hangar Nine Pro-Lite 2 1/4", all of which helped get it's fat arse off the deck. Not sure what's up with your speed brake though. To get it to work, you need the travel to go from -100 to +100 (or vice versa). If the travel from your TX switch is only -100 to 0, it won't work properly.
                                    • radfordc
                                      • 375
                                      • Lansing, KS
                                      Hi Su30 flyers,
                                      Christian
                                      400g!! Wow. I'm using batteries that weight 770g and added about 70g to the tail. My CG is 145mm. I also added a larger nosewheel and extended the nose strut by 5mm. Grass takeoffs and landings went well.
                                      • hcew
                                        • Nov 2020
                                        • 10
                                        Hi,
                                        sorry, sorry, I did a wrong measurement with my new digital CG libra.
                                        Now I need 150g in the tail with a 6000er LiPo with 885g weight. The CG is 150mm.
                                        Thats looks more better.
                                        I will also try a FLOUREON 6200er 30C with 850g.
                                        The SU is not a fast EDF, but it looks pretty good on ground and in the air.
                                        The next maiden will be the Freewing AL 37.
                                        Thanks for the infos.
                                        Christian
                                          • 8814
                                          I'm using an 890g Revo 70C, 5000mah battery with NO weights in the tail. This plane has a huge range of CG and as long as it's between the 2 marks, I fly it and it flies fine. By "fine", I don't mean it's fast or nimble. It's still slow and sluggish on the sticks.
