Not out of the box...that I know of.
I'm going to try a 2250kv motor with a Jetfan 80mm fan, which might do a little bit better than the FMS in another of my 80mms, but it comes at a penalty of ~20% higher amps.
At >=$250 for a setup like that vs. $86, it's a trade off in cost vs. benefit.
I'm going 8S on the Gripen as it's the only real way to get the added power without going sky high on the amps.Comment
I have the FMS PRO on order. I'm getting 2.8kg from that in my Avanti and Mirage 2000, for much the same amp draw.Comment
How do you measure the thrust? Do you put the model on its nose on a household scale or use a fish scale horizontally or something else? I haven't done any of it, but I need to test a few of my models to find out if it will be worth upgrades. So any suggestions are welcome
I've done it both ways. They pretty well agree. And it's easy to check the accuracy of the scale using a known weight.
When you do it horizontally make sure the wheels can move easily on the surface so as to avoid friction losses.Comment
Afraid we are not far behind in Norway. Hoping for a few more weekends (already completely dark when I get off work, so weekdays are out)
Seeing Evan's paint job makes it very obvious that this model deserves it. I do feel a little bit cheated in terms of the demo model vs the production colors.Freewing A-10 turbine conversion: http://fb.me/FreewingA10TurbineConversionComment
Just be pleased that there aren't a bunch of lawndart reports with the Gripen.
Seeing Evan's paint job makes it very obvious that this model deserves it. I do feel a little bit cheated in terms of the demo model vs the production colors.Comment
