  • ggillila
    • Feb 2023
    • 14
    I was trying to find answer to this in the feed but its so dang long lol. I'm trying to set it up and am very unsure about what to do regarding the gyro. By default, it's in attitude hold(red flashing). Since that's the default mode and doesn't give us a card, I assume it's what is recommended? Basic gain sounded better but I could be wrong. Have you guys used attitude hold for it? Also, I hope there is a way to turn it off in case it craps the bed in flight.
      • 5389
      I have Red solid- Basic Gain, Red Flashing Attitude lock and Blue and Purple on trainer mode. Basic gain is default without the mode plugged in.
        • 8763
        Please look carefully at the red light. There are 2 ways it can flash. One is a fast flash and the other is a slow flash. The quick flashing means it is trying to initialize and once it does, the light should turn to whatever your switch is set to. The plane must be held perfectly still until the flashing stops. The slow flashing means it's in attitude hold. This would be the same as "heading hold" and is not recommended for this plane.
        Do you have the gyro on a 3-position switch? It should not default to "attitude". Without the switch, it should default to "basic gain" mode. And yes, a programming card is needed to alter things. It is recommended that you incorporate a 3-pos switch so you can have a choice of basic gain, gyro OFF and one other choice based on your own preference. It is also useful to have "master gain" on a knob so you can change the gains based on flight conditions. However, failing to assign a switch or a knob for master gain, this plane should be quite flyable in stock form - Basic gain and max gain dialed in. I can't understand why yours has defaulted to "attitude". It is very possible that it will "crap the bed" in flight in attitude mode. Double check the flashing type. After you plug in the battery and don't touch the plane for several seconds, is it still flashing? (Table on page 6 of E52 manual.)
        • RudyD54
          • Aug 2020
          • 104
          • Miami, FL
          Not sure anyone's seen this yet but it looks like motion put together a grass ops retract kit....I put an order in for a set. I'll post pics of what they look like when they arrive next week.
            • 8763
            Nice find, Rudy. I do have a grass field that I'd like to fly this plane from. I would very interested to see what these new wheels look like and how tough it would be to swap them in and out as desired.
              • 8763
              Rudy, they look like this:
              They are rotating retracts, much like on a Corsair. The whole retract would need to be swapped out. It may even be possible to increase the size of the tire a bit to make it that much better for rolling on grass.
              • RudyD54
                • Aug 2020
                • 104
                • Miami, FL
                Sweet...Luckily the rear retracts are pretty easy to remove. 5 minute swap at most.
                  • 8763
                  I don't recall where the first connector is. If it's near the wheel well bay, then yes, it'll be easy.
                  • Al Martinez
                    • Dec 2022
                    • 2
                    Hello. Does anyone have any pictures of how they replaced the front landing gear once it was ripped out due to a rough landing? My front gear broke off along with a couple of pieces of foam. I’m not sure if I want to glue it all back together and possibly have loose landing gear or try light ply. Ideas? Pics? Thanks.
                      • 8763
                      I've never had a front retract pull right out on the B2, but I have on many, many other planes. Keep all the foam that's stuck to the retract base and leave the foam on the plane's nose. Don't cut it away or throw any of it out. Use something like FoamTac and spread it on ALL the mating surfaces on one side of the other and press it all in place. With FoamTac, you need to pull it apart again, let the air get at it for about 20 seconds, put it back, pull it apart again for another 20 seconds, put it back and hold it in place for a few minutes. FoamTac will actually make the break a stronger bond than the unbroken part of the solid foam. Don't be tempted to use epoxy or CA. Those will simply break again just beside the bonded areas.
                      • GliderGuy
                        • 1408
                        Adding to Xviper’s excellent advice above…..
                        Since the torn foam may expand a bit from fractures, it may take quite a bit of compression pressure to seat the glued assembly in place and ensure proper alignment for retraction. The AL37 mains are a prime example of critical alignment. FoamTac will creep during cure and allow misalignments, if you release the compression pressure before the glue sets hard. And getting a clamp on the assembly may be problematic.
                        So…What’s a solution?
                        While holding pressure on the assembly and proper alignment, secure it with a UV cure glue like Bondic. Strategically “weld” the assembly as you apply the pressure/compression with sufficient UV curing glue which sets instantly and maintains the correct assembly position permanently while the primary repair glue like FoamTac cures.
                        Note: UV glue is too brittle to work for a landing gear assembly repair all by itself, but it is perfectly suited to hold parts in place while the primary glue cures.
                        Spot welding with UV glue to hold parts in place while a primary glue sets….Now there’s a trick to add to your foamy repair toolkit! Try it, you’ll like it. AND NO CLAMPS REQUIRED!
                        PS - The UV glue curing process is very EXOTHERMIC. Don’t shine UV light on any thick glue bead on your skin. The heat generated is unpleasant and may even produce a blister.
                        • SanExup
                          • 912
                          • Western Wy.
                          Thanks GliderGuy! I've never heard of Bondic and am highly intrigued and will pick some up. I've been using CA for spot welding but the Bondic sounds worthy.
                          • GliderGuy
                            • 1408
                            The big advantages over CA glue are:
                            - Near Instantaneous cure…no molecular surface moisture is needed as with CA glue types.UV glue isn’t picky.
                            - You can make the glue bead as thick as you want. Building up in several thin layers is suggested.
                            Several online stores sell Bondic and other brands, but I have experience only with Bondic brand. You may want to consider ordering additional glue. I find myself using it in a lot of applications.
                            Note: Field repairs can be a bit tricky because the UV in sunlight cures it. Best get in a shady spot.
                            • SanExup
                              • 912
                              • Western Wy.
                              I just ordered a kit and spares!
                              • kallend
                                • 1870
                                I've been using it for a while and it's great for tacking parts in place whlle waiting for stronger adhesives to set up. Especilly good for parts with shapes that make them hard or impossible to clamp. It's also good for making fillets. It allows almost unlimited time to make adjustments before instantly setting up when the UV is applied. It's basically the same as dentists use nowadays for attaching crowns to teeth.
                                I find it not strong enough in tension by itself for repairs to highly loaded parts.
                                • SanExup
                                  • 912
                                  • Western Wy.
                                  Right, thanks for the insight. Yeah, it seems every glue has it's best uses and not always interchangeable. I've found that out the hard way. Foam tac seemed like an odd glue initially when I started assembling foam models, coming from a mostly balsa and CA background. But I think I like it more than any other now, being a full foamy convert.
                                  • GliderGuy
                                    • 1408
                                    Yep FoamTac = great stuff
                                    Cool but beautiful day in north Texas. Waited for 45F and calmer winds then took the B-2 out for 10 flights.
                                    Such a fun bird to see driving around the sky. And there’s the ever present “must make good B-2 no-bounce landings” challenge to keep things interesting.
                                    Got in some P-38 and F-4 flights too
                                    • Quax
                                      • Jun 2019
                                      • 77
                                      • Bergisch Gladbach, Germany
                                      Hello everyone,
                                      I had a successful maiden flight with my B-2 this morning. Thanks for all the tips about setups (especially drag rudders although I can't get them open enough for the amount as stated in the manual) and warnings about landing this beauty. She flies just nicely and as from my impression very stable.
                                      Landing is kind of difficult (at least for me): As it was mentioned it tends to bounce and even a light bounce will increase from bounce to bounce. I decided on a go around each time and saved the plane but it took me five (!) attempts on the last flight (the next one would have been a belly landing as my battery ran out of power). I am not sure yet about the best technique with some speed and just fly it down to the runway and let it settle or low speed and flare in time (as good as I can).
                                      Best regards and thanks again everyone!
                                      • GliderGuy
                                        • 1408
                                        Hi Quax - Congratulations!
                                        My drag rudders are 25 mm open top to bottom at the outer rear edges. That is the closest I can get. It is not critical.
                                        Energy management and winds 5 mph (8 kph) or less are the keys. She’s a “special day” plane. Why? Gusts will cause a bounced landing = disaster! Early morning and late afternoon when there are no thermals is a good time. Thermals cause gusts.
                                        Don’t get slow 3 ft (1 m) up, she may drop a wing = disaster
                                        Get down about 6 inches (15 cm) up and do everything you can do to SLOW her down. Touch down with as little energy as possible. She won’t drop a wing if you are slow and in ground effect. I often touch with full up elevator just like a Piper Cub landing. NO ENERGY = NO BOUNCE
                                        While in ground effect you need to be at ZERO throttle. MINIMIZE YOUR ENERGY. NO ENERGY = NO BOUNCE
                                        Mostly I get on final in a full glide (no throttle), but depending on conditions, a touch of power helps avoid a sinking vertical velocity.
                                        You need to touch with as small a vertical velocity as possible…..make every landing your best EVER!
                                        Enjoy her longer….follow the advice above.
                                        But nobody can be perfect every time, so order some spare parts for a nose gear repair. You will need them…especially have a spare retract servo handy. Then go back up a few posts and learn about how to make the repair when the nose gear assembly rips out of the foam.
                                        It has been many, many months, now, since my last botched landing that required a nose gear repair and hundreds of successful and fun flights. Take the above techniques seriously! They work!
                                          • 8763
                                          Drag rudder opening amount is adjusted and set via multiple routes - look at servo travel, servo subtrim and manually adjusting the rods inside the wing tips. If you're happy with rudder authority, just go with what you've got.
                                          I've got mine to also act as drag brakes where they both open up as wide as possible for shorter landing roll. This involves some fiddling with mixes, switches and other electronic bits.
