Originally posted by Hardway
View Post
Wing tips;
2x 14"x2" electroluminescent strip lights and 1x 12"x2" vertically mounted electroluminescent strip light.
Green or red (wing tip depending) and it has both solid and flash modes.
Strobe light
2x covert lights (tiny LED's only visible to certain night vis systems.)
Station 2 and 10 both have flood light to illuminate the nose of the aircraft.
Tail;
1x Strobe
1x flash/steady white position light.
Both top and bottom of the empenage, between horizontal halves have 2x long (like 18"x2") long electroluminescent strip lights top and bottom. (4 in total)
Outboard vertical stabilizers have a small low powered flood to illuminate the tail and tail #
Fuselage;
One bottom formation light, right in front of the "pull up bar" antenna
One top formation light aft of the top UHF antennas that points rearward toward engine inlets
On the top of the fuse there are 2 x long electroluminescent in an arrow formation <
One each side there a long electroluminescent light as well.
Then of course on the nose gear there are two floodlights, taxi and landing light.
