Was the guy on the bottom row, right side a big Chuck Norris fan? Other than being a little small he sure does bear a heavy resemblance with his hair and beard style.My YouTube Videos https://www.youtube.com/channel/UCrz...4Q-xrOOtP2C-8wComment
Not sure if he was Bill, but he was my supervisor on the team. Thinking back, I’m not sure I even saw a Chuck Norris movie until 1980, 1981?? But I can tell you that the guy on the top row - sixth one from the left - was a black belt. I bought a pair of nun-chuks (spelling?) from him back then.Comment
Looking good! I was too conservative when I put on the color coat over the shading underneath...if I had it to do over, I would have put the final coat on light and checked it out after it dried, and in the light. You will love how realistic it is going to look! Keep us posted. RobComment
Thanks! I'll keep that in mind when I'm putting down the colors. Any chance you have a photo of your plane after painting? The sites media search feature doesn't seem to be working since I can only see 4 of your recent picturesComment
I understand! I chose to do the fuse and for the canopy I used a fine point sharpie. Again, if I had it to do over, I did the rivots with the back of a Dremmel drill bit. I understand now the logic of using a bamboo skewer, as recommended. The bamboo is much finer, and as Alpha originally said, it is not about puncturing the foam, but the goal is just to create a recess that will trap the paint. Then when you airbrush, you come at it from the side angle, allowing the accent black to show through. I ended up pushing through the foam, and it was too much. It takes a light touch! Rob1 PhotoComment
I might consider doing the canopy rivets with a sharpie at the least.
Some progress pics. Medium green finished and halfway through the dark green. Use 3 testor 1/2 oz jars for the medium green, and it looks like the dark green will be about the same.3 PhotosComment
Nice! And belly tanks too? Those shades look really good. Are you going to do a clear coat? Another reason I should have errored on the side of leaving more under-colors showing...the clear coat softened that effect. I discovered a product this time for Dull Coat that I thought was really good...Alclad II, Klear Kote Flat (at 20 psi per directions). The guys at my hobby shop recommended it and I thought it was really "military" flat IMHO. RobComment
Yea, I made some station 5/6/7 pylons. Personally, I think the hog doesn't look right with those 3 missing:
https://www.thingiverse.com/thing:2744129
I do plan on giving it a flat clear coat after decals and weathering. For simplicity, I might try this rattle can TiredIron recommended, though I might give the alclad II a try.
Our nose gear has arrived. :Cool: Thank you MotionRCYep, welcome to the squawk Jim.
Hope my mate kurt ordered that nose gear in time... looks like it's pretty popular. Hate to say it, but any idea when the next batch would come through? I haven't dinged my a10 yet, (apart from scraping the rudders a touch getting a bit too high alpha in a landing) - but given how much I love my raaf scheme one, any insurance is good insurance in my case lol. :)
DCS A10 is awesome but its time for the DCS F18C and Wags is going the whole hog. YouTube...Comment
Hey A10 Hogs. Have a problem. Was setting up my servo arms and plug in second batterie and it started to smoke at connection. Never had that happen. Used same batteries yesterday to bind receiver. First batterie to ESC and then second batterie to ESC with BEC. Any ideas. Thanks. Kevin.Comment
