Definite buy! This is my best flying EDF (and I have almost all that Freewing offers), and is my all-time favorite bird to fly.
Where in AZ are you? If you are in the Phoenix area, come check out the Arizona Electric Festival happening this weekend in East Mesa:
There will be four or five A-10s flying throughout the weekend.PatComment
Most definitely buy it. Out of all the scale jets that Freewing has made (and other manufacturers), this is my favorite one so far. That says a lot. It’ also happens that Freewing has made my all time favorite sport jet as well, the Avanti. This has nothing to do with brand favoritism, but Freewing has won me over as a fan time and time again because of the combination of their quality, design (thanks Alpha et al.), availability (thanks to MotionRC), and cost. At this point, and for a while now, Freewing has been my manufacturer of choice.Comment
Pete:Hello pilots.
My maiden went great ! Not one click of trim was needed....lol.
I took my sweet time with the flaps and approaches . Thanks so much to everyone
involved here. Its truly a Cadilac dressed up like a Wart hog.
Many Kudos to Motion RC. Freewing. And of course the factory.
Pete
Congrats on the successful maiden!!! Can't wait to maiden mine - hopefully in the next couple of weeks if it warms up a bit. Enjoy!
Regards,
JimComment
+1 with T-Cat's recommendation on both the A-10 and The Avanti.
Congrats Pete! I've been waiting to see"Old Yeller" fly! She looks great in the sky. I'm a fan of yellow on planes. They're much easier for my "you're not 25 anymore" eyes to see.Comment
Looks great! Who said, don't cut the throttle,AT ALL!
Keep the fuselage level and establish and control you're descent with throttle.
Your slight back pressure on the elevator was perfect and the landing was sweet
BTW, if you didn't cut the throttle, at all, you'd still be flying, 'til the battery died that isLOL
Land it like you own it!
Grossman56Team Gross!Comment
Rabid Models foamies, including my 8' B17 & 9' B36... and my Mud Ducks! www.rabidmodels.comComment
After flying with Hobbyking Oleos for a while, I finally decided to swap out for the FMS A-10 struts to get a bit better scale appearance. They were a bit short, so I had to fabricate a longer pin and used a strut collar as a spacer. Gear doors will be the next step..2 PhotosComment
I've been wondering for 6 months if anyone was going to try them or had done that mod.After flying with Hobbyking Oleos for a while, I finally decided to swap out for the FMS A-10 struts to get a bit better scale appearance. They were a bit short, so I had to fabricate a longer pin and used a strut collar as a spacer. Gear doors will be the next step..
I'm still waiting on the A-10 main gear oleo upgrades for use on a 93" A-26 Invader.;)Warbird Charlie
They have probably been sitting on the bench for 6 months, waiting for me to get the proper tools.. Finally got around to picking up a tap and die set and some metric drills. The axles on the FMS gear were smaller and were threaded into the strut, so I drilled it out to 5mm, and added a set screw to get it working with the Freewing wheels and axles.
Can't wait to see the big A-26, will be quite the impressive beast!Comment
So I've placed all the water slide decals on my plane today, but the text color seems to get lost over any euro gray sections. Anyone else with a euro green scheme encounter this too? Am I better off ordering callie graphics since those are black?
Will the haze go away if I do a matte clear?
debating wetting and removing these all and just using the dry transfers from callie.2 PhotosComment
That is what I ended up doing. The water slides were intended for a light gray color scheme so they disappear on the European dark gray. The haze won't go away. My guess is the paint is too flat for the decals to stick completely.Comment
