    Originally posted by Sky Wolf
    Much thanks Mike! I'll go back into the radio and check other throttle settings to see if a difference can be made. I changed the rx out for both an AR6210 and an AR8000, and they both wok just fine. But those receivers are taken out of my other planes. Wanted to see if the rx was maybe faulty. Horizon says it's fine if it binds with the radio.
    It's just not activating the ESC's after it binds to the radio, so they think it's a problem with the ESC's.
    Thanks for the ideas. Will check that this week. Hoping to finally getting her ready for maiden in the next couple of weeks. Work and travels have kept me grounded...and I'm part of the first group. Yikes!!
    Yikes is right! You need some time to build and fly....
    • Sky Wolf
      Flying Ant
      • Sep 2013
      • 731
      • Irving, Texas
      Originally posted by HellHathNoFury
      I see you still have the bond plug still in the Rx after you have binded.. That could be your issue.. Remove after bind otherwise Tx won't respond..
      Long-time-no-hear from HHNF!! Good seeing you again.
      The bind plug stays in during the bind process until it actually binds everything. Sorry for the inaccurate video report, but I get that fast beep even when the bind plug is out.
      I tried an AR6210 and AR8000, and they both work fine. I'm beginning to think it has to be the receiver. Now I just have to convince Horizon of that. Per "CrashMaster's" idea, I'm going to check other throttle settings in the TX.
      Thanks for for chiming In!
      • Sky Wolf
        Flying Ant
        • Sep 2013
        • 731
        • Irving, Texas
        Thanks Steve! Man, I just wish I had your time and your skills! You've inspired th entire Freewing A-10 audience. Sorry I couldn't make NEFI to meet you and see her up close. Maybe next time.
        • MikeT
          Here......Hold my beer.
          • 1060
          Something else I've found always start with a clean model do a reset. Another gremlin I've run across is something not working on one model than set up on another model works. No clue why.
          Mike
            Thanks. Yeah I wish you could have made it too, we had an excellent time. Very laid back and neat to meet others from the Squawk.
              • 2137
              • On planet earth....right
              I have ordered an ARF+ which will be here today but does anyone know if it comes with the battery to ESC leads and BEC? If not I guess I will find out later today.
              Unfortunately I can't give a straight answer as I don't have an ARF.....yet :). I would imagine it likely won't come with the leads and/or BEC since the other Freewing ARF Pluses (even in the same price range) do not come with one or the other either. I can't remember if they at least provided the connector in the parts package (I thought I had some ARF + planes that did). I would reallyyyyyy love if they did include the leads and BEC though :Cool:. I sure as heck hope I'm wrong.
                UPS truck left a giant box at the door!!! What could it be?????
                  I will find out soon enough and let you know.
                    • 8747
                    The big box came this afternoon and I gotta say, this is second largest box that an airplane has ever come in, only surpassed by my Eflite 2000mm CZ T-28. It was also encouraging to note that all the foam cross braces were cut and removed once. I suspect that someone at Motion did this to do a cursory inspection before sending it off to me. Good job! It'll sit for 2 or 3 more weeks till I get 2 other planes finished.
                    • DrDeath
                      • 91
                      Originally posted by Mike_Then
                      Here are a few pics from today. Got all three of them in the air at the same time!
                      Click image for larger version  Name:	20170625_150948.jpg Views:	1 Size:	225.1 KB ID:	83087Click image for larger version  Name:	20170625_151004.jpg Views:	1 Size:	170.4 KB ID:	83088Click image for larger version  Name:	20170625_151043.jpg Views:	1 Size:	163.5 KB ID:	83089
                      Looks like you guys had a trio of hawgs playing in the play pen too. I have to say, it was fun having our three in the air at the same time. Motion RC, you guys I hope are enjoying all of these planes in the air. You should be proud to bring so much joy to so many old children. LOL
                      • ColtPilot
                        Hobby Squawk Advanced Pilot
                        • Jun 2015
                        • 538
                        • Saint Clair Shores, Mi
                        Well Callie out did herself on the graphics for the MI 107th Red Devils. Now I can really start to go to work on the paint then graph it all up. :Cool:
                          Excellent! I am looking forward to seeing how this one turns out. Did she do the big red devil as well?
                            Well, here is the answer. The ARF+ does not come with the battery to ESC cables or BEC so I will be making a trip to my LHS tomorrow to hopefully get a Castle Creations 10A BEC. In the mean time I have one side done. I am very curious to see how this works out. I believe I can essentially run on 5S or 6S so it will be interesting to play with and see how they compare. I can't be the only or first person to drop some 90's in one of these... someone outside of the designers has to have done this already.
                              • 2137
                              Bummer, that's what I figured, but was hoping they changed it. You may want to get the new Castle BEC that has better headroom than the old 10A, or just get the HV BEC for even greater headroom. The old 10A I believe is only about 5A maximum on 6S voltage.
                              • ColtPilot
                                • Jun 2015
                                • 538
                                Excellenta I am looking forward to seeing how this one turns out. Did she do the big red devil as well?
                                Yes indeed. I even have the pilots name who will be flying the full size B1RD with his tail number. Can't wait.
                                • 1horse59
                                  Don't shake much anymore
                                  • 71
                                  • Huntsville, AL
                                  Try calibrating your ESC, my friend's edf was doing that and after trying everything we knew, we did a calibration, then all was good.
                                  • HellHathNoFury
                                    • 247
                                    Looks like you're the CTD on the 90mm install..:)
                                      • 8747
                                      Don't know if anyone has mentioned this before ...................... Not all RXs look at sub-trim the same. Is your throttle trim tab on the TX all the way to the bottom? The RX that doesn't seem to work may see it as too much throttle and won't arm. Make sure you didn't alter the throttle sub-trim menu by accident. Once those are confirmed, then do the throttle calibration.
                                        • 8202
                                        Calliefied!! :)
                                        • HellHathNoFury
                                          • 247
                                          Super nice Aros..:Cool:..Those dark areas wouldn't be agreeing with some of the Hot days some guys are experiencing especially in SoCal over the weekend.. Apparently got up to 117 degrees...
