  • downwindleg
    • 1279
    • Friday Harbor, Washington
    Originally posted by RCAV8R
    Missed that one Brad...bummer! But we did go to the Eagle Tavern where all the air crews burned their tail numbers on the ceiling with their cigarette lighters! Now it is a museum of photos of reunions and testimonies...and of course a pint of ale! Rob
    Yeah, years ago I got this book with the names and places and details of every Air Museum around the world so whenever we travel, inside or outside the U.S., I check to see if there are any cool museums in the area. Since my wife and uncle wanted to take the train up to Cambridge from London, I took the opertunity and left them on the bridge over the Cam River (hence the name Cambridge) and took a short bus ride to Duxford for the day. We're even, I missed the Eagle Tavern and the pint..... Brad
    • Shirty
      Hobby Squawk Water Boy
      • 1067
      • Perth, Australia
      Ok boys... who glued my ordinance stickers to the backing sheet? lol, are these waterslide or peel n stick? Don't feel like they are waterslide but I can't get them off....
      • TomPatton
        XNitroJunkie
        • 279
        • Elida Ohio
        I believe those were water slide sir...
        • Shirty
          • 1067
          • Perth, Australia
          Ok, I'll give that a go. Cheers tom. ;)
            They are indeed waterslide. Had a good chuckle picturing you trying to peel those chunky buggers off. Cheers mate:Cool:
              • 8748
              Are they all water slide or are they like the A-10, some water slide, some peel and stick?
              • Shirty
                • 1067
                • Perth, Australia
                Hahaha... well, I'm sure I'm not the only one who's done it lol :)
                • Dewey H Lee
                  WARBIRD JUNKIE
                  • Apr 2015
                  • 919
                  • Fayetteville NC. US
                  Yea i feel your frustration shirty. Im haveing the same problem figureing out which is which on my new spitfire. Thats probably why callie is getting a good living off of us. But thats all good her work is impeccable.:):Cool:
                  Dewey l
                  • dahawk
                    Augermeister
                    • Jun 2013
                    • 1006
                    • Keller,Texas
                    Xviper,
                    Remember Caddy Shack ? Sounds like you need a Bill Murray plan. C4 would work well.
                    • downwindleg
                      • 1279
                      "Just a harmless squirrel.....not any plastic explosives or anything." Also, I keep a couple of five gallon buckets of sand around for filling holes. After one season the grass grows right through it. The big hump at the end of the runway might take a little more workLOLNever seen a banked turn while taxiing before. Brad
                        Here's pics of the reversed struts (bounce fix)...
                        • gravityworks
                          • 21
                          • Nashua nh
                          Hey tired iron thanks for the pics I started to copy your idea but noticed when the retract is up u would need to grind off a lot of metal to make it fit nice did u grind down the forward facing part of the retract? Open the whole for the pin or does the retract just stop once it senses resestiance ?
                            It stops, but there's no resistance.
                              Thanx :Cool:
                              • ColtPilot
                                Hobby Squawk Advanced Pilot
                                • Jun 2015
                                • 538
                                • Saint Clair Shores, Mi
                                Originally posted by MANFRED
                                Ok after a few perfect flights and landings with this ship, I had a power failure of some sort and did not make it over a hill. Fuse broke on half and she sustained other damage and is under repair right now. One of the biggest issues was some brush took out one of the 80mm fans. Just wondering if anyone has an extra fan or perhaps the remains of their encounter with gravity. Thanks!
                                Dang dude, sorry to hear this.
                                • ColtPilot
                                  • Jun 2015
                                  • 538
                                  Centerline drop tank is on it's way. Pylon held in place with earth magnets to the tank. I also placed a plastic coupling piece for the fuse connection which are from MRC. I bought extras just in case.
                                  • Shirty
                                    • 1067
                                    • Perth, Australia
                                    Hey fellas, anyone got a pic handy of their ordinance with the stickers on it? Thanks!!! ;)
                                    • ColtPilot
                                      • Jun 2015
                                      • 538
                                      This is the correct load out as told to me by an A-10 pilot at Selfridge ANG for the weapons I have.
                                      • Shirty
                                        • 1067
                                        • Perth, Australia
                                        Very cool.
                                        Last question hopefully, where's the white stripe one go? Cheers
                                          I never figured that one out completely. It might go on the rocket pod but I ended up not even using it.
