  • Hover
    "Have Fun"
    • Feb 2019
    • 15
    • Giessen /Germany
    Habe seit heute Probleme mit den Flaps.Die machen keinen Mux mehr.
    Hat das auch schon mal einer gehabt?
    Werde alles mal durchmessen:(:Confused:
    Evtl. liegt es am Control-Board.
    • Adrian-M
      • 21
      Has this become a German speaking forum???????
        • 5426
        All are welcome.
          No. I don’t speak German. I use the translator program to speak to Hover to include him in the Squawk conversations. :Cool:
            • 4875
            Same with Didier (French) and Gordon (Brit) LOLLOLLOL Just kidding Gordon. I love ya, Man!
            • Mark 2
              • Oct 2017
              • 83
              Hast du die servos mit dem sender verlangsamt?
              Ich finde, das funktioniert mit Freewing-flugzeugen nicht gut.
              • Axel S.
                Axel S.
                • Dec 2018
                • 14
                • Illinois near Chicago
                How much expo do I use on the Avanti S?
                  • 8835
                  That's different for each person. It also depends on what rate you are applying the expo to. Some don't like any expo regardless of expo. I like more expo the higher the rate. If I'm on 100% rate, I'll go 35 to 40 expo but on low rates of 60%, I might only dial in 15 to 20 expo. As you can see, there is no single answer. You need to pick something and try it. Then change it to suit you.
                    Roger XViper… I use as much throw as comfortable for the mechanics on every plane, but I use 45 on Ailerons, 65 on Elevator, and 20 on Rudder. The 65 is usually a little mushy, and then I dial it down to match the airframe and the CG... However, I have not had a warbird or jet snap roll from an elevator stall from me over-controlling the surface... This is a conservative setup for sure, but it has worked well for me so far!! I dial it down as I go... Some planes, the Aileron goes to zero for roll rate,,, etc...
                    Hope that helps a bit!! Jerry
                      • 5426
                      I'll add that sometimes the pushrod placement in the manual is not the best. If you decide to reduce (or increase) overall surface travel don't do it in the transmitter, move the pushrod to a inner hole on the servo. Keeping it on a outer hole and reducing your travel 60% makes the servo work harder and you have less servo resolution. Also check your servo arms are 90 degrees to the pushrod. Many times the arm is off 1 spline.
                      I like 100/80/60 for D/R's as a starting point with 40/30/20 expo except I use no expo on rudder. These setting get similar feel at the center with increasing travel on the higher rates. But everyone has their own preference.
                      Take care setting up the flaps on the Avanti as using too much travel in the flap up position can cause the servos to fail.
                      • Lipripper
                        • 16
                        My go to plane, especially in 10 to 15mph winds. No gyro in my Red Avanti S. Here is a video of me flying this great EDF
                        If you fly with a Spektrum radio, be sure to use normal speed for flaps. Do not use delayed flaps. If you have any issues with flaps, turn off the delay, see what happens.....
                        I believe they have resolved the nose gear issues with the red version. I've already had a rough landing with the red version without that kind of damage. I did repair that issue on two yellow Avanti S planes, which I've sold. They both continue to fly without that nose gear issue. Use a razor knife, carefully cut out foam above plastic landing gear mount from battery compartment. Fill area with 2hr epoxy, be careful, use just enough to fill the area. Replace foam. All better.
                        Love this jet! Thank you Motion RC!
                        • icepirate3
                          • 214
                          Thanks for the tip with the flaps! Hoping to maiden mine soon now that the snow is gone.
                          • Bill Sanford
                            If it can fly, I can crash it...
                            • Feb 2019
                            • 44
                            • Bemidji, Minnesota
                            Wow! Must be nice to have the snow gone!
                            Here's my reality in northern Minnesota! We won't see green grass this year for at least a few months... The benches you see are 4 feet above the ground... My Avanti is waiting patiently in my workshop for its maiden... :-(
                              Bill!!! God Bless You Brother!!! Man, just get some Avanti floats and give it full throttle!!! Jerry from Texas. It was 16F here two days ago. Now it is 70F!!! :Silly:;):Cool:
                              • SKYITRC
                                • Mar 2019
                                • Wisconsin
                                I am looking for a good looking pilot for my Avanti S , any ideas?
                                Also looking for carbon or 3D printed wing fences.
                                  Welcome to Hobby Squawk, SKYITRC! If you want a prepainted pilot figure, consider pilots from similar sized aircraft, like the Freewing 80mm L-39. If you want a very highly detailed resin pilot bust, which require painting to finish, I recommend the 1/10 scale bust from www.jethangar.com. Chris Wolfe is a member here and he casts each pilot bust himself in California. If you wanted a painting service, see Akuma Zeto, who is also a member here.
                                    As far as those, I don't know of any aftermarket sources for carbon fences or customized 3D files. There are a few members here who draft 3D parts, try contacting them in one of the 3DPUP threads.
                                      • 8835
                                      • dkalwishky
                                        Warbird Lover
                                        • Sep 2015
                                        • 1382
                                        • Des Moines, IA
                                        Here are wing fences for the Avanti that you can 3D print.
                                        https://www.thingiverse.com/thing:2967164
                                        • SKYITRC
                                          • Mar 2019
                                          • Wisconsin
                                          Great help guys
