Originally posted by Aros
View Post
Mar 20th, 2019, 06:04 PM
New 1835KV upgrade! I upgraded my F-16 from the stock edf to the new FW 6S 1835KV EDF. What a difference! The model came to life and the thrust to weight ratio is perfect. I was thinking of going to 8S but I am glad I did not - the 6S setup is lighter and this plane does not need any more wing loading.
I had to add 30g of weight in the nose and move the battery forward as far as it would go. The new FW inrunner is 107g heavier than the old outrunner. I highly recommend this upgrade and the EDF unit is a drop-in replacement with no foam cutting needed.
Doesn't anyone out there fly the 90mm F-16 anymore?
Trying to get some info on the elevator compensation when using take-off and landing flaperons, but nothing yet. I would guess it's similar to the Stinger 90 and maybe the F-4, a certain amount of up elevator with the flaps, however, the only post I could find in this entire thread was from 2016 and he stated "PLUS 19 with take-off and PLUS 28 with landing". Now I'm not the sharpest tack in the box, but to me that means DOWN elevator, and that just seems to be counter intuitive, but what do I know, just plugging in a battery takes all my brain power.
Could this be the only plane in my fleet that uses down elevator with more flaps? If I program some up elevator and it really is down, I'll probably go into a stall before I know it. Someone of all you brainiacs
out there must know.
Had to also do some additional painting to help me with orientation (and cause I just can't leave well enough alone). If HP can do 4in1 printers, then I can do 4in1 planes. The upside is I only have to maiden 1 for all 4 to be set and the cost, averaged out over 4 jets bring it to less than $200 per jet, thereby saving me a total of $2,200 on 4 jets
(that's the logic I used on my wife, and she can't argue cause that's the type of logic she uses on me when she returns from shopping). Of course the down side is if I lawn dart 1, they all go down.
