Aros, I found the perfect combination for this bird...here is a quote from my earlier post:
Mar 20th, 2019, 06:04 PM
New 1835KV upgrade! I upgraded my F-16 from the stock edf to the new FW 6S 1835KV EDF. What a difference! The model came to life and the thrust to weight ratio is perfect. I was thinking of going to 8S but I am glad I did not - the 6S setup is lighter and this plane does not need any more wing loading.
I had to add 30g of weight in the nose and move the battery forward as far as it would go. The new FW inrunner is 107g heavier than the old outrunner. I highly recommend this upgrade and the EDF unit is a drop-in replacement with no foam cutting needed.
out there must know.:pray:
(that's the logic I used on my wife, and she can't argue cause that's the type of logic she uses on me when she returns from shopping). Of course the down side is if I lawn dart 1, they all go down.:sob:
