    Hey Brad, I will get to that tomorrow. Tonight I am trying to do some subtle rivet detail and weathering. I still have to weather the bottom and after I re-do some of the decals on the nose (Callie is making them based on my artwork) I will finish weathering the nose.
    Click image for larger version  Name:	20170607_223941.jpg Views:	1 Size:	53.4 KB ID:	80037
    Click image for larger version  Name:	20170607_224046.jpg Views:	1 Size:	41.0 KB ID:	80038
    Click image for larger version  Name:	20170607_224002.jpg Views:	1 Size:	52.8 KB ID:	80039
    Click image for larger version  Name:	20170607_224056.jpg Views:	1 Size:	43.9 KB ID:	80040
    • downwindleg
      • 1279
      • Friday Harbor, Washington
      Nice rivet work. Did you use Alpha's technique or something else? I tried his technique on a spare cockpit I got for mods and found that it is really easy to push to hard and actually puncture the skin of the plane ......DOH ! A very fine line between a depression and a puncture for sure. Brad
        • 8211
        That was my thinking too Brad...
          I just used the tip of a blunt pencil. Most did not go through but some did. No big deal.
          • downwindleg
            • 1279
            By the way, your plane looks awesome in general. I love the way your markings look with that color scheme. I've been toying with the idea of dry transfers instead of the usual vinyl.......far less shiny and no clear around the edges on the nomenclature. Wonder if Callie would be interested in producing dry transfers for these planes. The cost was always the hurdle in the past but nowadays it might be worth investigating. Brad
              If there is any shine to them I just give then a matte clear coat and they are good to go.
              • Jpahemi1
                • Oct 2016
                • 68
                • Washington Michigan
                Rcjetdude
                did you us a wash on the panel lines they look real good
                john
                • petefoss
                  • 105
                  I know I saw a picture on one of the 4 squawk and rcgroups of a typical elevator trim position but I'll be switched if I can find it! HELP!
                    Originally posted by Jpahemi1
                    Rcjetdude
                    john
                    Yes, just a wash of black and burnt number acrylic paints that I watered down. I brushed it on the panel lines and rivets then wiped it off in a backwards direction with a dry paper towel that I had folded several times to make it more rigid. I kept using a dry part of the towel. Tonight I applied some in a more vertical manner on the fuse and vertical fins.
                    Click image for larger version  Name:	14969715925111887630703.jpg Views:	1 Size:	48.1 KB ID:	80244
                    Click image for larger version  Name:	14969716405271287755439.jpg Views:	1 Size:	55.9 KB ID:	80245
                    • e4dragongunner
                      Living the dream!
                      • 876
                      • Arlington Heights Il.
                      Good Lord.... well done. really really spectacular work sir!
                        Thanks. It's not really that difficult to do. Hopefully I will have my custom graphics from Callie soon and I can get this finished.
                        I also blackened around the gun.
                          So after my flights yesterday I noticed my lipos were extremely warm (like has been posted by a few pilots already), and I decided to mod the air cooling ducts a bit. I'm using the cheater grate from a Freewing F-5 for the exit air, and I cut some spoons to put over the forward NACA ducts to help draw air through.
                          Still need to glue everything in place, and touch up with paint, but I hope this helps get more cooling air over the batteries. Of course, it was 103° when I flew yesterday, so that might have contributed.
                            Using that F5 grate is a good idea Pat. I had one until I cleaned out my basement and I may fave gotten rid of it. I will have to double check. Let us know if you think it helps.
                              Will do. All glued in and painted up.
                                OK, I think they came out pretty good! Got a few more things I want to do, especially to my AN/ALQ131. I trimmed off all the mold flashing, and then had to repaint. I wanted to repaint it anyway because I wanted it a light shade of gray to give it a little contrast as everything else is the same color as the plane. I also want to add some panel and rivet detail as well, but that will be done by hand. No decals for those.
                                I just need to get a quick application guide done, and these should be ready to start shipping out. But I won't be able to get back to it until late tomorrow afternoon.
                                I will also provide the raw file for anyone who wants to print them themselves.
                                Word of caution. If you didn't like putting on the decals from the kit, you're not going to like doing these! There are 58 individual decals, and most of them are TINY!
                                  Looks fantastic Pat. Bring 'em on.... I am a glutton for punishment... :Silly:I would love to try yours and am happy paying you for a set. I have only ever used the decal papers from Micro Mark for inkjet printers. The white stick great but the clear I am still trying to find my grove on them. :Confused: Let me know when you are ready to go and I will send you the $$.
                                    AN/ALQ131 detail complete!
                                    • vduniec
                                      Hobby Squawk Pilot
                                      • 314
                                      The progress is slow but I'm enjoying the experience.
                                      • Fast Eddie
                                        • Oct 2016
                                        • 119
                                        • So.Cal
                                        Here are some size shots of mine against a ruler.
                                        Click image for larger version Name:	20170523_130226.jpg Views:	1 Size:	19.1 KB ID:	77299
                                        Click image for larger version Name:	20170523_130134.jpg Views:	1 Size:	51.0 KB ID:	77300
                                        Click image for larger version Name:	20170523_130052.jpg Views:	1 Size:	24.4 KB ID:	77301
                                        If you cut some of the bottom of their seat off you could set it lower. Notice that my seat is not full depth.
                                        Could you provide a link or name where you picked up your pilot? Was it complete with seat?
                                        I picked up spare cockpit to get started on detailing while I wait for 2nd shipment of Hogs.
                                        Thanks
                                          Looks great vduniec! I like all of the camo schemes but my favorite is the Euro green. I am enjoying seeing everyone's creativity come to life on this awesome plane. I just finished mine with the exception of Pat's ordnance decals. At least I can't think of anything else I want to do on it at the moment. LOLMaybe some TER's, maybe paint the wheels to match the struts... blast! now I gotta paint the wheels.
