  • dkalwishky
    Warbird Lover
    • Sep 2015
    • 1382
    • Des Moines, IA
    I opened the Micro Set bottle to pour it in the other bottle and was hit with a powerful odor. Oddly enough, it smells EXACTLY like distilled white vinegar. Hmm, I wonder...
    When I was researching setting solutions I found a lot of people mentioning this, there are some recipes to make your own with vinegar.
    • Ronniehinesh
      • 21
      • Columbia Tn
      I printed them on waterslide and applied them. It was a slow process but it made a huge difference. I'm working on the lettering for the bombs and missiles now. I hope they turn out as good as the others. Thanks for the lettering I was looking for it when you posted yours.
      • vduniec
        Hobby Squawk Pilot
        • 314
        Ready to rain "blue death" down from above! Painted the bombs to represent inert practice bombs and painted the Maverick to reflect a captive training round.
        I wanted to add a little splash of color to this subdued scheme. I also plan on making the old ALQ-119 Pod to add to one of the outboard stations. That will also be painted white and should really help with orientation while flying.
          Looks great! Very well done. Adding color to the ordnance definitely helps.
          • Pogo
            • 452
            • Waterford, Ontario, Canada
            Well I figured vents should be vents so here they are. When the paint dries (a good colour match from Home Depot) I'll go in again with some fine paper and remove the fuzzies. I don't think the added airflow will make much difference but of course won't hurt either.
            Tom
            • Pogo
              • 452
              i also started making simple servo covers today, cut from some thin ABS plastic leftover from a ParkFlier Plastics sheet. Held on with double-sided Scotch tape, this first one seems secure but will come off without trouble if it needs to. Painted with that same matched sample from HD. I'll probably paint the servo arms and linkages too. :Cool:
              Tom
              • Pogo
                • 452
                I plan on doing a detailed cockpit and opening canopy this winter but just couldn't fly the season with the provided pilot figure so got the JHH guy done up and installed. I didn't want to pry up the canopy, only to glue it back down again so cut out the little guy from the bottom- the new figure also goes in from the bottom, the base just held with tape. I'm using RT 5000 batteries and there is just barely room, height wise, but it worked out (hence the recess for the base).
                  • 2137
                  • On planet earth....right
                  I took out my F-18 pilot of a smaller scale and also put in my JHH 1/10 full body pilot today. Looks like we had the same thought on the same day :Cool:. Since my batteries are one on top of another in the rear compartment of the bay, I kept the pilot legs fully in tact. It looks hysterical with the canopy off because they hang down like he's on a ride at Six Flags. LOL
ID:	82782Click image for larger version
ID:	82784Click image for larger version
                    Flintstones...
                      • 2137
                      Hahahaha, he's totally Flinstoning it up. Who needs EDF's when you have legs.
                        Tom
                        Good idea Tom, every bit helps and I am sure they add up.
                          Tom
                          Nice, looks very clean. :Cool:
                            George, thanks for the nose gear mod. Very ingenius. You should throw some pictures of it up here.
                            • slamdance64
                              • 70
                              • Ottawa, Ontario, Canada
                              hi Steve,
                              are you using Qty 2 2inch speakers? Did you fit those before you joined the 2 fuse halves together? I am looking to move my Shockwave 2 sound card over.
                              Thanks
                              Brent
                                Originally posted by slamdance64
                                hi Steve,
                                Thanks
                                Brent
                                Hey Brent, I used two of the TT-25 speakers in series to make 8 ohms. The Shockwave2 requires 8 ohms on 6S. I did take advantage of trial fitting the speakers before gluing the fuselage together but I don't think it is necessary. I cut a hatch in the bottom and framed it with strips of 1/8" plywood. Not having the back of the fuse glued on did help with knowing where to cut though.
                                  • 8228
                                  Your mods are so sick it's creepy. But in a good way. :)
                                  • Pogo
                                    • 452
                                    Feets don't fail me now!:)
                                    Tom
                                    • Pogo
                                      • 452
                                      I've missed this mod- is it to reduce slop in the nose gear?
                                      Tom
                                        Tom
                                        Yes, but I will let George describe it. Didn't I see somewhere that you did a mod to reduce slop or was that someone else?
                                        • Pogo
                                          • 452
                                          Yes, but it didn't work. The little brass shim bonded to the trunion came unbonded- JB Weld let me down.:Angry:
                                          Tom
