I printed them on waterslide and applied them. It was a slow process but it made a huge difference. I'm working on the lettering for the bombs and missiles now. I hope they turn out as good as the others. Thanks for the lettering I was looking for it when you posted yours.Comment
Ready to rain "blue death" down from above! Painted the bombs to represent inert practice bombs and painted the Maverick to reflect a captive training round.
I wanted to add a little splash of color to this subdued scheme. I also plan on making the old ALQ-119 Pod to add to one of the outboard stations. That will also be painted white and should really help with orientation while flying.2 PhotosComment
Looks great! Very well done. Adding color to the ordnance definitely helps.Ready to rain "blue death" down from above! Painted the bombs to represent inert practice bombs and painted the Maverick to reflect a captive training round.
I wanted to add a little splash of color to this subdued scheme. I also plan on making the old ALQ-119 Pod to add to one of the outboard stations. That will also be painted white and should really help with orientation while flying.Comment
Well I figured vents should be vents so here they are. When the paint dries (a good colour match from Home Depot) I'll go in again with some fine paper and remove the fuzzies. I don't think the added airflow will make much difference but of course won't hurt either.
Tom3 PhotosComment
i also started making simple servo covers today, cut from some thin ABS plastic leftover from a ParkFlier Plastics sheet. Held on with double-sided Scotch tape, this first one seems secure but will come off without trouble if it needs to. Painted with that same matched sample from HD. I'll probably paint the servo arms and linkages too. :Cool:
Tom1 PhotoComment
I plan on doing a detailed cockpit and opening canopy this winter but just couldn't fly the season with the provided pilot figure so got the JHH guy done up and installed. I didn't want to pry up the canopy, only to glue it back down again so cut out the little guy from the bottom- the new figure also goes in from the bottom, the base just held with tape. I'm using RT 5000 batteries and there is just barely room, height wise, but it worked out (hence the recess for the base).3 PhotosComment
I took out my F-18 pilot of a smaller scale and also put in my JHH 1/10 full body pilot today. Looks like we had the same thought on the same day :Cool:. Since my batteries are one on top of another in the rear compartment of the bay, I kept the pilot legs fully in tact. It looks hysterical with the canopy off because they hang down like he's on a ride at Six Flags. LOL
Flintstones...I took out my F-18 pilot of a smaller scale and also put in my JHH 1/10 full body pilot today. Looks like we had the same thought on the same day :Cool:. Since my batteries are one on top of another in the rear compartment of the bay, I kept the pilot legs fully in tact. It looks hysterical with the canopy off because they hang down like he's on a ride at Six Flags. LOL
Good idea Tom, every bit helps and I am sure they add up.Comment
Nice, looks very clean. :Cool:i also started making simple servo covers today, cut from some thin ABS plastic leftover from a ParkFlier Plastics sheet. Held on with double-sided Scotch tape, this first one seems secure but will come off without trouble if it needs to. Painted with that same matched sample from HD. I'll probably paint the servo arms and linkages too. :Cool:
TomComment
hi Steve,
are you using Qty 2 2inch speakers? Did you fit those before you joined the 2 fuse halves together? I am looking to move my Shockwave 2 sound card over.
Thanks
BrentComment
Hey Brent, I used two of the TT-25 speakers in series to make 8 ohms. The Shockwave2 requires 8 ohms on 6S. I did take advantage of trial fitting the speakers before gluing the fuselage together but I don't think it is necessary. I cut a hatch in the bottom and framed it with strips of 1/8" plywood. Not having the back of the fuse glued on did help with knowing where to cut though.
