The current version of 3DPUP for the B-24-J Nose Turret is very simple to install.
First, slice out the foam in the center to match the width of the 3DPUP part.
Test fit to verify everything is snug.
Then, paint the 3DPUP as desired.
Glue the 3DPUP onto the foam with an appropriate glue. Do not use high temp hot glue. Slide the clear plastic parts back over the turret, and tack glue into place.
