  • I-fly-rc-aircraft
    Always learning
    • Jan 2019
    • 269
    • North Augusta, SC
    What he ^^^^^ said.
    • e4dragongunner
      Living the dream!
      • 876
      • Arlington Heights Il.
      Plus one on the 4 blade.... what are the details? is it the old sky raider prop or is it the prop off the FMS Corsair? And.... what additional hardware did you need to mount if any?
      Details on amp draw would be a plus, Thanks :-)
      • themudduck
        -TMD- Foaming at the Mouth!
        • 1041
        • Burton OH (near Cleveland)
        Originally posted by I-fly-rc-aircraft
        mudduck, what 4 blade prop you using? cool beans man
        Tom
        Hey Tom,
        TiredIron posted waaaaaaaay back in this thread, that is the 17" 4-blade prop from the old 1700mm FMS P-47. That plane was discontinued but the prop parts are still available if you're lucky to find them (I got mine on ebay) - you need to purchase the hub, spinner, and the props. Don't buy the FMS prop adapter, it will not fit the Corsair's motor, but the prop will fit the original Flightline prop adapter with some very minor modification. Basically you need to enlarge the hex on the adapter a little (I used masking tape) so that the slightly larger FMS hub fits tight. The FL adapter is a little short but with a little fiddling you can make it work. I carefully shortened the base of the spinner cone so that the recessed nut would engage the threads.
        The FMS hub and spinner are black, so I painted them.
        The 4-blade prop pulls a little more but the model is not as fast. I love the look and it flies very realistically.
        Click image for larger version  Name:	20190331_101757.jpg Views:	0 Size:	52.1 KB ID:	241184Click image for larger version  Name:	20190331_101757.jpg Views:	0 Size:	52.1 KB ID:	241185
          TMD ………. No luck required in finding the prop, it is also the same prop assembly that is used on the 1700 Corsair (FMS) that is still in production with parts avail from Horizon or directly from FMS.
          From Horizon:
          The Spinner Blue F4U 1700mm by FMS is a quality built remote controlled airplane accessory. See all our RC product options online at Horizon Hobby!
          The Propeller, 17 x10, 4-Blade: 1700mm F4U by FMS is a quality built remote controlled airplane accessory. See all our RC product options online at Horizon Hobby!
          From FMS:
          http://www.fmsmodel.com/fms-1700mm-f...0-blue-spinner
          http://www.fmsmodel.com/fmsprop002-p...-17-10-4-blade
            • 8205
            I'm not sure if this is helpful or not but I have a 16" 4-blade prop from a Skyraider I bought a few years back to upgrade the FMS Razorback but I never did use it. Just sits collecting dust now. If anyone thinks they can use it just let me know. There's no hub/mounting hardware, just the 4-blade prop.
            • f4u ausie
              • 1229
              • Melbourne
              have my fline parts now from motian ....ailerons working corectly .... thanx to all 4 help advice !!!!! 3.75 robart wheels r cool as heck,,,,, will fly this weekend ,,,,,, and fit them soon that 4 blade does look good ,,,, cya
              • RichJ53
                • Nov 2018
                • 342
                • Southern Oregon
                From Horizon:
                From FMS:
                actually you can still buy this FMS 1700mm plane and all the parts from Horizon. Everything is in stock
                The F4U Corsair Blue PNP, 1700mm by FMS is a quality built remote controlled airplane. See all our RC product options online at Horizon Hobby!
                Rich
                • RichJ53
                  • Nov 2018
                  • 342
                  • Southern Oregon
                  Hey Tom,
                  all parts and the Corsair are available see link
                  • I-fly-rc-aircraft
                    Always learning
                    • Jan 2019
                    • 269
                    • North Augusta, SC
                    Thanks guys, that 4 blade is going to look sweet on mine.
                    Tom
                    • themudduck
                      • 1041
                      Tom
                      Its good to see the parts are listed by Horizon (and FMS) - to repeat, you'll only need the "spinner" (Part# FMMSI310BLU, currently on backorder) and the blades (Part# FMMPROP002, currently in stock).
                      Then a little modification is needed to make it work. You'll find that the hub's hex mounting hole is too big, its too loose on the original prop adapter. So what I did was carefully wrap several layers of masking tape around the hex on the original prop adapter until the hub fit properly. It seems odd but it works because the main nut holds the hub on very tight. (The hex on the prop adapter just stops it from turning when you're tightening down the nut.) Then the second thing that I found was that there wasn't enough of the bolt sticking out for the acorn hub to grab onto. I thinned the back of the hub a little (its very thick), and shortened the skirt of the acorn hub a little, until the acorn nut could grab the threads. If you guys do this mod this will make more sense when you see it! The acorn nut is just a decoration, so installing it finger tight is all you need. I've had no problem with mine... except I painted the hub and acorn silver and the paint keeps rubbing off!
                      • f4u ausie
                        • 1229
                        • Melbourne
                        No flying this weekend. ,, to windy so fit. The robarts instead. ​ ,,, Is there a good way too. Make the raised letters, Goodyear etc;;. White or more prominent!!??? Or just a steady hand and small brush​​​​​​
                        • I-fly-rc-aircraft
                          Always learning
                          • Jan 2019
                          • 269
                          • North Augusta, SC
                          I'mmmmmmm baaaaaaaaaaaaaack.
                          Got it sliding manually.
                          Tom
                          • Beeg
                            • 1335
                            • Texas
                            Tom
                            Great job!
                              • 2693
                              Tom
                              Outstanding!!! Are you hooking a servo up to it by any chance? BTW, when do you have any time to fly with working on all these over the top modifications? You need to change your description from "Always Learning" to "Always Teaching".
                              • I-fly-rc-aircraft
                                Always learning
                                • Jan 2019
                                • 269
                                • North Augusta, SC
                                Hugh:
                                Flying is over-rated LOL and I enjoy this as much as flying.
                                I have 70 mm of travel. IF I'd want to operate it electro-mechanically I'd use something like a servoless retract drive. Then I'd need to open up the bottom of the fuse and come up with a mechanism to attach the sliders to and re-design the aft channels and sliders.
                                I'm retired and a PT school bus driver so I have time to mess with this stuff.
                                I worked 46 years and many 12 hour shifts and 60+ hour work weeks. 23 of those years on swing shift.
                                Never did much tinkering but did build several planes from kits.
                                Raised two boys but an empty nester now.
                                Never stop learning.
                                Tom
                                  • 4820
                                  I'mmmmmmm baaaaaaaaaaaaaack.Got it sliding manually.Tom
                                  Tom, Outstanding work, Sir. Bravo Zulu. Best, Steve
                                    • 2693
                                    Hugh:
                                    Tom
                                    Tom, at least you're thinking about it, sounds like you already have a concept on how to make it work. Just gives me the chills thinking about your Corsair with operational cowl flaps and an operational canopy, wow.
                                      • 8205
                                      Fantastic work Tom! Now if FlightLine can just offer these kinds of amenities out of the box for those like myself who lack the patience and skill then life would be splendid!
                                      • I-fly-rc-aircraft
                                        Always learning
                                        • Jan 2019
                                        • 269
                                        • North Augusta, SC
                                        Hmmmm Maybe I can actuate that canopy The schools are closed for a couple of weeks and I just so happen to have a retract unit lying around. Only thing is the jack screw is too short. Time to design a fix.
                                        Tom
                                        • f4u ausie
                                          • 1229
                                          • Melbourne
                                          folding wings next ,,,,that would a task .. but way coooool looks like we will all have some spare time
