    • 4869
    Danger,
    Depending on where you placed your foot troughs, you can easily fit a 'full-bodied' pilot above and on either side of the control rods.
    That's exactly how it worked out for me.
    I did move my Rudder Servo aft of the cockpit, but that was to allow room for the sliding canopy mechanism, additional light wiring, and whatnot.
    Great work, both of y'all.
    Best, LB
      • Nov 2013
      • 2783
      • Cody, WY
      Originally posted by Elbee
      Danger,
      Best, LB
      Thanks for the pics of the foot troughs. there should be a way to make some and put them in,
      Davegee
        • Nov 2013
        • 2783
        • Cody, WY
        EWWWWWW!!!!
        Cool Dave. I was thinking the same thing with the pilot, if I make the foot rails and allow for the control rod throw, it should work out fine. I sure like the idea of having a full pilot in the cockpit.
        I'm off for Sunday and Monday, can't wait to see the little guy.
        Come on over when he's out of the oven!
        (Dangerous Dan)
        Hi Dan: I am going to work on a second pilot today. It takes about 9 hours to print up the body, so that is an overnight job. If I can't make it by your house on Sunday, let's plan on Monday. I'm gearing up to go down to Boca Chica TX on Wednesday to see the Starship 7 launch (hopefully) so I'm starting to get busy getting my camera gear ready to go for it.
        I'll let you know how it comes out and if it is suitable quality for your airplane
        Cheers
        Davegee
          • 7418
          Sounds good Dave
            • 7418
            Got the tail hook off, it was easier than I thought, just press fitted on, no C clips or other PITA's, a little touch up on the paint and she looks good. Probably gained 10 mph
            Tomorrow is pilot day!!!!
            Can't wait to see the little guy!
            Thanks for the picture Elbee, the rail braces look like allan keys, now I have an idea of what to aim for.
            (Dangerous Dan)
              • Nov 2013
              • 2783
              • Cody, WY
              (Dangerous Dan)
              Hi Dan: I've got your pilot completed, sans paint. Otherwise it should be ready to install in your airplane when the time comes. What I did on mine this morning was cut a 1 inch diameter dowel about 1/2 inch thick disc, and then put it on the sander to bevel one side some. I then put the cut dowel with the thicker part forward, like a seat cushion for the pilot. This makes the pilot's legs a little more elevated and they clear the rudder and elevator control rods. Just a thought.
              I should be able to drop by your house tomorrow morning. Does mid-morning work for you? I can drop by about 10 am after I finish at the gym if that is ok. If not, name a time and I can probably make it.
              My wife is painting my pilot now. Acrylic paints seem to cover the natural PLA material that the pilot is made out of, no problem, without using a primer. Should look Much better than the Porcelain Petes we have been saddled with for the past several years!
              Great minds think alike; I also removed the tail hook yesterday with no problems. Now, that's a Marine Corsair!! TRIVIA QUESTION: How much did the tail hook and bar on the Corsair weigh?? ANS: Approximately 48 pounds.
              Cheers
              Davegee
                • 4869
                Thanks for the picture Elbee, the rail braces look like allan keys, now I have an idea of what to aim for.Grossman56(Dangerous Dan)
                Dan, more than welcome, Sir. Best, Steve
ID:	417403 Click image for larger version
                • jetfool
                  • Nov 2022
                  • 1363
                  • Crawfordsville, Indiana
                  Elbee,
                  Do you offer an STL for the F4U-1D Canopy that is in your picture? Preparing for the day I get the Bubble top Corsair. Going to keep the high school industrial class busy printing B-26 parts this semester.
                  Starting to snow here, expecting 4-8" next 2 days. So, hibernating in the workshop. No Honey - Do list at this time.
                  Best Regards, Rex
                    • 4869
                    Originally posted by jetfool
                    Elbee,
                    Best Regards, Rex
                    Rex, that design is from a 1:32 5-view drawing.
                    It is scale to the drawing which is scale to the 1:1 and unfortunately does not fit the FlightLine Corsair.
                    With any model interpretation by a manufacturer, certain 'liberties' are taken for manufacturing as you probably are aware.
                    I was quite surprised that my design from the drawing wasn't even close to fitting the FlightLine model.
                    As a result, I bought a second canopy from MotionRC and designed around that for the sliding canopy feature.
                    I even went so far as cutout the 3D printed frame and resize it to the width and length and it just was not worth the effort to mod to the FlightLine Corsair.
                    In the end, the mod worked, but I went backwards around the block to get there.
                    Best, LB
                    • f4u ausie
                      • 1242
                      • Melbourne
                      You all do an absolutely AMAZING job,, lotsa time effort
                        • 7418
                        Cheers
                        Davegee
                        Sounds good Dave, around ten is fine.
                        Dan
                        • jetfool
                          • Nov 2022
                          • 1363
                          Thanks, Elbee.
                          f4u ausie,
                          Being retired I tell my wife that this is (modeling) my full-time job. After all I'M the boss in my house........when She's not around!
                          Best Regards, Rex
                            • Nov 2013
                            • 2783
                            • Cody, WY
                            Dan
                            Cool, will do Danger Dan. I spent a good part of the day finishing up the 3D printed pilot, with the help of my wife who did the major preliminary painting. I then got into the detailing and adding things like the cords that come out of the headsets to communicate with others.
                            I think the pilot came out pretty well, certainly looks better than the OEM Porcelain Petes. It worked out to make a scale full-body pilot so I didn't have to start hacking off limbs to get him to fit! I"ll attach a few pics of my pilot when I finished it and will be gluing it in tonight or tomorrow. Nor rush as we have plenty of snow to melt off before I can fly again.
                            In trial fittings he slides in very well and his feet don't touch the rudder or elevator wires. Very impressed with doing 3D printing. Tons of potential in modeling!
                            The pilot is supposed to represent Lt. Robert M. Hanson, USMCR, the highest scoring ace in WWII in the Corsair (25 kills). KIA in early 1944 on a strafing mission of a Japanese flak tower, just having attained the age of 23. MOH recipient (posthumously).
                            Cheers
                            Davegee
                            Click image for larger version  Name:	IMG_2540.jpg Views:	0 Size:	76.8 KB ID:	417426 Click image for larger version  Name:	IMG_2539.jpg Views:	0 Size:	90.8 KB ID:	417427 Click image for larger version  Name:	IMG_2538.jpg Views:	0 Size:	81.5 KB ID:	417428 Click image for larger version  Name:	IMG_2543.jpg Views:	0 Size:	67.0 KB ID:	417429
                            • jetfool
                              • Nov 2022
                              • 1363
                              Davegee,
                              You and your wife did a beautiful job on the pilot. Looks great sitting in the cockpit. I need to hire someone to make me a Ken Walsh for my Corsair. Know anybody?
                              Best Regards, Rex
                                • Nov 2013
                                • 2783
                                • Cody, WY
                                Hi Rex: maybe we could effect a trade.I need someone to develop a stronger outer wheel half for my E Flite P-51D that is currently shredding the thin plastic rim with the Robart 3.5 inch tires. Also, I’d like to get a better designed Curtiss electric prop dome for my P-47. Mine is close, but could be slightly improved to look a little smoother and more realistic. Would your students be interested in a challenge like that?. I can print up and paint a Ken Walsh pilot that would fit into your cockpit easily. I’m going over to Danger Dan’s tomorrow with my V2 Corsair pilot to see how he fits into his new birdcage Corsair.
                                Just a thought. Might be a fun trade??
                                Cheers
                                Davegee
                                • jetfool
                                  • Nov 2022
                                  • 1363
                                  Davegee,
                                  We fly at the HS this Sunday afternoon. I'll talk to the teacher and see if they are interested. Might be fun.
                                  I'm going to make a Curtiss Spinner for my P-47 on my lathe from alum.
                                  Rex
                                    • Nov 2013
                                    • 2783
                                    • Cody, WY
                                    Davegee,
                                    Rex
                                    Sounds good. If they don't want to do the project, that's fine.
                                    Cheers
                                    Davegee
                                      • 7418
                                      The pilot looks awesome Dave, So much better than PP's Can't wait to get started on him. I think you'll be impressed at the progress I've made so far.
                                      (Dangerous Dan)
                                        • Nov 2013
                                        • 2783
                                        • Cody, WY
                                        (Dangerous Dan)
                                        Good. I'll be heading over shortly to get there aroun 10 am.
                                        Davegee
                                          • 4869
                                          davegee.
                                          I concur with the consensus, the joint-venture pilot was a success. :tada:
                                          Lookin' good, Ma'am and Sirs.:champagne:
                                          Best, LB
