  • TomPatton
    XNitroJunkie
    • 279
    • Elida Ohio
    Originally posted by OV10
    That's the difference Gman..........they are talking about the black case 40C 3600's;)
    Those 40C's are short portly buggars. They would be better off running the new 40C 4000........mine fit perfect and 9 min times:Cool:
    That's it...
    What OV10 said...
    Different batteries, those are the ones MRC was gonna trade for if I sent mine back...
    The new 3600's are square and are to high to fit properly...
    Man I'm glad we got that figured out, I was ready to quit drinking tequila...:Silly::Drinks::wacky
    • fieldofdreamsflyer
      Banned
      • Jan 2013
      • 289
      Use these lipos and you dont have to cut anything. After each flight there barely warm. You get 2 of them http://www.ebay.com/itm/2pcs-HRB-4S-...53.m2749.l2649
        • 7387
        Of course, does anyone still use those??LOL
        Seriously, all my 3600's new or old are PRO batteries, my 4000's of necessity, are black case. There had to be a simple explanation, real easy, either go 4000's or PRO 3600s !!
        • Pheonix
          • Aug 2013
          • 670
          I use the 3600 50C in one Cat and they fit well and the CG is right on using my Xicoy CG balancer. For the other one, I use the Graphane 3700, 70-140C. They all fit well.
          • themudduck
            -TMD- Foaming at the Mouth!
            • 1041
            • Burton OH (near Cleveland)
            I had another great flying session yesterday, with the Tigercat and also the A10. I keep these planes under my canopy, out of the sun, and I am disappointed to report that the finish on the Tigercat wing is starting to "gator" in spite of these efforts. This is just from being out in the sun while I am flying (its hard to protect it in the air, LOL). It hasn't been out long - just 5 minutes per flight.
            I'm disappointed because I love the way this plane looks and apparently there's not much we can do to stop this from happening. Any of you have any ideas? Should I refinish it and then fiberglass it or something? Or perhaps the Minwax treatment? Will the Minwax treatment stop this?
            • Pheonix
              • Aug 2013
              • 670
              themudduck
              ​themudduck
              Did you cover your Cat with anything like Minwax or similar products? This should really help.
              • themudduck
                • 1041
                Originally posted by Pheonix
                themudduck
                ​themudduck
                No I haven't used the Polyurethane treatment yet, I wanted to try the plane out and kept it out of the sun thinking I should be OK.
                I can go ahead and do that now, it will make the whole plane glossy. I am wondering if that will help or will it still get hot out in the sun?
                (By the way I'm not out in the desert, its NE Ohio so the intensity of the sun isn't particularly bad.)
                • TomPatton
                  XNitroJunkie
                  • 279
                  • Elida Ohio
                  NW Ohio.... This is what I used, has UV protectant in it. It has been in the sun quite a bit and very minimal effects.....
                  Purchased at Lowe's...
                  • themudduck
                    • 1041
                    Thanks Tom, looks great. I've seen this mentioned much earlier in the thread, I was just resisting because I liked the way the plane looked.
                    But shiny is good too. And shiny without gatoring is much better,
                    hmm... I wonder if this treatment would work inside the cockpit on these models.
                      You could always put on a coat or two of poly, then go over it with something like Testors Dullcote if you still want a flat finish.
                        • 7387
                        You can get Minwax in a satin finish as well as Varathane. With the satin, you can then coat over it with acrylics which are dull by nature.
                        My P-40 is just nasty! Click image for larger version
ID:	89287Click image for larger version
                        I just used a mix of flat black and nutmeg using the craft paints from Wally World and Ace Hardware and a lot of water, even knocks the shine off the plastic spinner
                        • TomPatton
                          XNitroJunkie
                          • 279
                          • Elida Ohio
                          They probably make that in a flat or satin finish, I don't know. That was all Lowes had at the time I was there and have not shopped around. A quick google search would probably answer this. It only came in quart size so I got plenty for awhile.
                          Here are some pictures of my first F-7 that I busted up. It was left out in full sun for a day and a half and this is the results. Very slight effect, so if when out at the field if it is kept out of the sun when not flying it should hold up really well.
                          The picture of the whole plane was the first time it had been outside, and only a few minutes before picture taken to give you an idea what it looked like before sunbathing for a day and a half. If you zoom in you can see the foam texture on the horizontal before it even saw the sun.
                          Also, I applied 3 coats with a 1 1/2" inch foam brush.
                          • RC Oldy
                            Hobby Squawk Pilot
                            • 44
                            • Farmington MN
                            I had the same thing happen kept plane under a canopy and still gatored I did have it coated with minwax poly and still gatored sucks but i guess not much a guy can do besides fly the H out of it
                              • 7387
                              Well, as I've said elsewhere, get Minwax or Varathane with a UV protectant in it, it will help a bit, but the sun will get it one way or another. Dark colors are just that way. My F7F is, to describe it fairly accurately, grey, (see the icon) but the anti glare shield is black and guess where the gatoring is showing up?? There and in the cockpit area. It has been recommended to drill a small hole to allow the heat to escape from the cockpit. Use the shade if you have any, the side of your vehicle or anything and cover the planes. The wife had a great idea and said '"how about using a baby crib mattress cover, it has elastic just like the 'official' plane cover" Which I thought was a great idea.
                              • Tomcat1950
                                • 11
                                Hallo,i have a question.is it possiple to fly the Tigercat with 2x 5 lipos with the original motors or need i the tuning Motors. Thank you for answer.regards. Regards kh
                                • Pheonix
                                  • Aug 2013
                                  • 670
                                  Great photo with Mr. Mueller.
                                    • 8817
                                    If, by "tuning" motors, you mean the "upgrade" motors, those aren't designed to fly on 5s either. Anytime you fly with more cells than is recommended, you are on your own - no guarantees, no warranties, no assurances.
                                    So, is it possible? Well, yes ..................... until something burns up. How long that may be is anyone's guess - maybe 1/2 flight, maybe several flights, maybe many, many flights.
                                    • Budcop
                                      Scale Guy
                                      • Aug 2017
                                      • 4
                                      • Rogersville, Tennessee
                                      Hey Guy's I just ordered the T cat with the recommended admiral 3,000 mah batteries from Motion RC, I see you folks talking about 3600-4000 mah, Have I screwed up???
                                        • 8817
                                        The recommended is what you ordered. Those guys who are using bigger batteries are doing so by their own choice, likely to try and get a little more flight time.
                                        • TomPatton
                                          XNitroJunkie
                                          • 279
                                          • Elida Ohio
                                          Originally when the F-7 came out the recommended battery was the Admiral 3600mah batteries. Then the battery manufacturer changed the 3600 battery dimensions to a square pack and not rectangular and would not quite fit the top tray under the canopy without modifying the canopy slightly. Then Motion started recommending the 3000 packs...
