Originally posted by Ryan@Motion/ryramZ View Post
Hey Tony. I set the timer for 5 minutes of hard flying and still come down at between 30 and 40% or around 3.8 a cell. If I take it easy and just scale fly and stay in the pattern shooting landings I can safely get 8 minutes and have the same results. Super efficient!
Can you tell me the weight of the 5000 lipo and where did you place it, almost forward, middle? Is it possible to use heavier packs, Thank you
Originally posted by franky View PostThe reason i'm asking that because i'm planning to order some 920 gr. lipos and i don't know if this will influence the CG.
This is the one he uses in the video (Admiral 5000mah), if yours is 920g its almost double the 5000. What brand is that? Seems very heavy. The Admiral Specs are below,
Weight 482g / 1lb, 3.80oz Length 155mm / 6.10in Width 46mm / 1.81in Height 30.25mm /1 .19in Wire Gauge 12 ESC Connector XT60 Connector
Originally posted by Plastic_Aviator View PostPulled this video from someone on the RCGroups pages for this bird. The pilot really tones down the flight for a sweet scale appearance. Enjoy!
Watching these two videos Ryan has his Admiral 5000's all the way forward. As you can see on the first video there is PLENTY of room to move a heavier battery aft if it's needed.
Watch this video at 00:00:52
FlightLine RC’s 1600mm wingspan Spitfire Mk.IXc is approximately 1/7 scale and an entirely larger beast with all the bells and whistles we’ve come to expect ...
Watch at 00:05:20
- Likes 2
Originally posted by MesRcPilot View Post
Hello Antony and thanks , I have never seen/flown a Spitfire in this category so far ... stall testing and the RC pilot is impeccable ;)
Oh I see!
Originally posted by xviper2 View PostDon't want to be a picker of nits but...
hahaha LOL:):Cool:
In all seriousness though, you are correct in that it is not much over. I wasn't telling him he couldnt, just passing along the Admiral info. Apologies if it came across that way, Franky :spitfire
Video is called Grass field ops and stall tests. https://www.youtube.com/watch?v=eaSRaPTpIsI&t=17s
Too late
hahaha LOL:):Cool:
although the 5000 flighttimes are nice. I'm only doubting about the width cause idon't want to cut the foam. Anyway thanks for support.
