  • Clugh
    • Sep 2023
    • 5212
    Click image for larger version  Name:	104_1997.jpg Views:	0 Size:	148.1 KB ID:	409136
    and i guess for them something is different here with two levels on a dual layer than 2 levels on a single layer for heat mitigation through the copper???
    UFOS! 💩
    4 REAL
    And the latest are plotless from here on out. Correct?
    Click image for larger version  Name:	fetch?id=409041&d=1723836184.jpg Views:	0 Size:	49.5 KB ID:	409138
    YT
    Hubert
    • Clugh
      • Sep 2023
      • 5212
      I can see now this will be fun Chris. Hardheaded amateurs are set up for failure. :tada:
      Click image for larger version  Name:	vector diagrams for 12N10P Design IV.png Views:	0 Size:	81.7 KB ID:	409145
      • Chxpress
        • Aug 2024
        • 142
        Hi Hubert, just let him do his old windings. The Ralph Okon aka Powercroco YY electric motor winding that increases power loss. If someone is so resistant to advice, ignoring harmonics, increasing proximity losses, round wire winding, the pensioner finds himself overwhelmed. 😂 Look, they haven't even had the control electronics improved for their application. Why no Hall probes? Synclos wouldn't be an issue and most coils would even still be alive. There are already enough controllers, e.g. from Kontronik, that detect and switch off errors in the live cables. Plug resistance too high. Winding resistance increases disproportionately compared to the cold connection resistance = switch off, etc. That's no longer rocket science today. The LRK winding with individual coils simply has a higher winding factor = fewer turns with a larger conductor cross section. These are just very simple gifts that you get. They've never heard of boosters with capacitors. Well, that's how the scrap is still used, children are happy. But it is not progress. That they are still docking around with 10 poles instead of 14 or more 20 with winding factor 1 and double frequency. yes, then an overlapping winding is how bad. I'll send you another paper about the booster creators.
        Happy Amps Christian
        • Clugh
          • Sep 2023
          • 5212
          I never did understand how the scorpion king thinks the 3 electrolytics on top a YGE 320 are enough to support the amperage demands if someone else's motor is in the competition Haus besides his boys he wound.🙄 If the YGE is a hybrid drive meaning it opens to six step at wot the LRK will generate less commutation ripple there and allow the faster clocking better. Part load operation is negligible in the first place if anyone agrees full power is seen at WOT. Thin slot wedges or a hybrid wind would reduce load amperages and rotor temperatures significantly. In the published academic studies A six step BLDC power system ( motor and drive) is also going to generate more torque and power than BLAC one.
          Heaven help us.....
          Hubert
          • Clugh
            • Sep 2023
            • 5212
            • Clugh
              • Sep 2023
              • 5212
              And Chris the scrap iron specialist can snatch copper cladded aluminum magnet wire from old open frame washing machine motors. Alot of times they don't waste pure copper in them.
              For the copy shop it is an excellent compromise....
              • Clugh
                • Sep 2023
                • 5212
                Click image for larger version  Name:	3042531-001f6abcf6c2be2d1ca9884999782897.jpg Views:	1 Size:	23.7 KB ID:	409157
                For me this cut you gave me is very interesting because I can implement WELC cooling channel directly into the stator and purge it with cryogenic gas. I wish you would have made this 50mm. But at 125mm with a huge ID im thinking about pancake direct contra drives. And drive it with Talega. You need to send me a blue print of dimension like hole spacing etc. and I can print a very strong lightweight composite bearing housing for it and channel it for whatever cooling a fool wants. I can take the windings well into the negative temperatures but then he needs my cryogenically shock proof thermally conductive material to hold it all together and get the best benefit. But that all requires too much intuitive thought into it so I wont keep suggesting it to Mr November.
                • Clugh
                  • Sep 2023
                  • 5212
                  Click image for larger versionName:	image.pngViews:	0Size:	42.9 KBID:	409162
                  • Clugh
                    • Sep 2023
                    • 5212
                    Give thanks the IEEE and Dr Sariful Islam​​
                    • Clugh
                      • Sep 2023
                      • 5212
                      I hope the Scorpion King look at his data on thermally conductive materials holding the wire to its support
                      • Clugh
                        • Sep 2023
                        • 5212
                        This one might give you a winding reference for your gear pump flow rate​s plus you can feed from the Peltier cooled reservoir for a more dramatic "gimmick"...
                        • Clugh
                          • Sep 2023
                          • 5212
                          I sent you a paper link Chris. Ralph says he doesn't need any gimmicks to fly faster.... so i wont post it here.
                          Enjoy the rest your day​.
                          Use it constructively.
                          P.O.C.B.O.I. would use ferrofluid in the WELC channels wound through the iron and eliminate the necessity of a pump. Hopefully you understand how it would work and be very novel. No one has this in a speed plane Chris. This is a real cooling concept with proven space age reference I guess they cannot understand. it works by curie effect of the suspended iron particles in the oil or water based substrate. The cold ones in cooler fluid will have a stronger magnetic field with the stator and just push the hot ones and fluid out of the way in a continuous loop through a cooled sink. It truly is space age from NASA for moving fuel in a rocket motor.
                          Hubert
                          • Clugh
                            • Sep 2023
                            • 5212
                            Boho1Boho1
                            Today, 01:35 AM​
                            Still here Ralph? LOL.
                            THIS IS IT FOR 90 DAYS!!!
                            I want to see what you and Sebastian do on any of the subject matter in 3 months. See you in November!!!!
                            YT
                            Hubert
                            • Clugh
                              • Sep 2023
                              • 5212
                              Hi Christian,
                              So the motors are going to get bigger than 5050s now...
                              someone's worried and ready to make adjustments looking for more real power... ha ha.... I like that
                              See you in November. The Jaguar will still eat a healthy diet and maintain his lean composite weight.
                              YT
                              Hubert
                              • Clugh
                                • Sep 2023
                                • 5212
                                Click image for larger version  Name:	VC.png Views:	0 Size:	873.9 KB ID:	409217
                                Vicente "Vince" Bortone's Pyro 600 for F3A winding is completed in 18 AWG. 240C* Remington
                                On the 7:1 coax contra with 22 x 20s this motor will turn 28,000-30,000 rpm and see peaks around 4kW in the intended application.
                                All my guys fly ceramic hybrid bearings & thermally coupled windings.
                                After a flight with an ambient temperature of 28C, the motor runs about 65C on the outside of the rotor.
                                The typical consumption for a P25 schedule with this motor on Adams D3 is around 3000 mah.
                                • Clugh
                                  • Sep 2023
                                  • 5212
                                  Brenner Contra Drives once recorded the lowest P25 schedule consumption ever with the 5+5 machine. 2800mah. 800 mah less than the 6+4😛
                                  Consistently 350-500 mah less is one helluva "copy".
                                  Click image for larger version  Name:	b091ce2dd0e23e760335882995543cc6.jpg Views:	0 Size:	35.3 KB ID:	409220
                                  Hubert
                                  • Clugh
                                    • Sep 2023
                                    • 5212
                                    BTW
                                    From '98
                                    Design of PM brushless motors using iron-resin composites for automotive applications
                                    Published in: Conference Record of 1998 IEEE Industry Applications Conference. Thirty-Third IAS Annual Meeting (Cat. No.98CH36242)
                                    Date of Conference: 12-15 October 1998
                                    Date Added to IEEE Xplore: 06 August 2002
                                    Print ISBN:0-7803-4943-1
                                    Print ISSN: 0197-2618
                                    DOI: 10.1109/IAS.1998.732251
                                    Publisher: IEEE
                                    Conference Location: St. Louis, MO, USA​
                                    ​Da weichmagnetische Materialien aus Eisenharz nun für Wechselstrommagnetanwendungen druckbar sind. Diese Materialien, die oft als dielektromagnetische Materialien bezeichnet werden, weisen im Allgemeinen relativ niedrige Permeabilitäts- und Sättigungsinduktionswerte auf, haben jedoch viele Vorteile, wenn sie im Konstruktionsprozess von Motoren richtig verwendet werden. Die relativ niedrigen Werte der ungesättigten Permeabilität sind bei bürstenlosen Permanentmagnetmotoren (PM) kein wichtiger Nachteil. In diesem Fall wird der effektive Luftspalt der magnetischen Struktur durch die Länge des Magneten bestimmt, der praktisch eine relative Permeabilität von eins hat. Ein Elektroautolüfter, der aus einem herkömmlichen PM-Gleichstrommotor mit einem mechanischen Kollektor besteht, wurde ausgewählt, um die Leistung der Motoren mit diesen neuen weichmagnetischen Materialien zu veranschaulichen und die Konstruktionsmethoden des Autors für bürstenlose PM-Motoren zu validieren. Es werden zwei Prototypen von bürstenlosen PM-Motoren mit einem dielektromagnetischen Material vorgestellt, die den herkömmlichen Gleichstrommotor vorteilhaft ersetzen können. Diese Prototypen haben konzentrierte Wicklungen anstelle von verteilten Wicklungen, um das Kupfervolumen zu minimieren. Die magnetische Struktur des ersten Prototyps ist mit kleinen Zähnen ausgestattet, die zwischen den Hauptpolen angeordnet sind. Die experimentellen Ergebnisse zeigen, dass mit dieser speziellen Anordnung das gleiche Drehmomentverhalten erreicht wird, wie mit klassischen Strukturen mit verteilten Wicklungen.
                                    Click image for larger version  Name:	fetch?id=388664&d=1697416337&type=large.jpg Views:	0 Size:	163.2 KB ID:	409239
                                    • Chxpress
                                      • Aug 2024
                                      • 142
                                      Hi Hubert,
                                      thanks for the papers. I'll read them over the next few days.
                                      In the last post the iron powder resin mixture is quite interesting. I know from the Flyware model that Andreas Wehrle was developing very similar versions. At Andreas Motoren, the windings were previously completely manufactured as pure air coils and used in a die-casting device. Then the powder/resin mixture was injected, with high pressure and quite high temperature. This means that even highly filled mixtures can be pressed cleanly into a mold using pressure. Due to the high temperature, the resin is quite thin and, on the other hand, hardens very quickly. There are no air spaces in such a stator; these stators are completely filled with magnetically conductive material. Thanks to clever design of the geometries, the stators are filled with iron particles and are magnetically very usable. Andreas did this with the company PMDM at the time, but then did not carry it out further for model making. Excellent slot filling wedges can be made with such materials. We have manufactured such stator slot fillers from thin 0.2 mm silicon iron wire in molds. They also worked very well, but are more complex to produce, etc.
                                      PMDM is since 2006 the Company , https://www.minebeamitsumi.eu/produk...triebssysteme/
                                      Happy Amps Christian​
                                      • Clugh
                                        • Sep 2023
                                        • 5212
                                        Hi Hubert,
                                        Yes but this is nothing to see. No way it can compare....
                                        Just wait till you see what the "Artist" and The Scorpion King produce 90 days from now. 4 years wasn't enuf time for the OP to wrap 12 arms of a hybrid Christian? There is a level of dishonesty where you have to say wow that's a sickness.
                                        Sich diesen ganzen Unsinn anhören zu müssen, dass seine Daten verwendet werden, um eine Debatte zu beginnen, ist genau der Punkt. Warum zum Teufel hat er den Thread überhaupt gestartet? Für unverdiente Aufmerksamkeit? Wirklich ärgerlich. Er hat nie etwas geschossen, um Daten zu sammeln. Haben Sie einen Hybridmotor von ihm gesehen? Sie oder Ralph? Dies ist ein Grund, warum Foren, in denen jeder frei reden kann, egal, was er wirklich weiß, für mich nicht kritisch sind. Es ist äußerst schwierig, genaue Informationen weiterzugeben, wenn ständig gefälschte Leitartikel im Umlauf sind. Warum jemand so etwas tun würde, ist mir schleierhaft.
                                        Das ist beängstigend
                                        Die Frequenz, die Rennsemmel ausstrahlt, lässt mir die Nackenhaare zu Berge stehen.
                                        • Clugh
                                          • Sep 2023
                                          • 5212
                                          The empty stator arms lead to beliefs like these:Warum so angefressen? Liegts an der fehlenden Stunde heute Nacht?
                                          Das Ergebnis ist sicher interessant und angesichts des Starttermins für diesen Threat, ist die Schlussfolgerung naheliegend.​
                                          Exactly what we are trying to dispel. Non belief. It hurts the cause of posting the new winding technology tremendously.
                                          If a person doesn't want to fuel dispute would you not agree that starting an entire thread about it certainly wont be effective for that cause? Why not be quiet and just stay all the way out of the topic and let the "disputers" do the posting on the subject matter as a way to not fuel anything?
                                          See my problem?
                                          90 Tage Nichtstun werden Ihnen viel über diese beiden Unruhestifter im GSM zeigen
                                          Thank you for your time and patience.
                                          Hubert
