Umm hmm!!!.
:woozy_face:
Exactly what I thought from the mighty GSM. now I'm a Gentleman. "Let it go in peace" coz they want to see it . You can believe this typed hype. It is getting hot as hell in this American Kitchen and were just beginning to start frying up sht with crisco!!!
They do not want this smoke. Trust! Unlike this bald headed clown Dr from Dresden I can operate a calculator fairly well too.
he's funny because he still reads here too as he's the one directed you here and now mysteriously knows by telepathy that im wrapping now???
FN Pinocchios never change...
Stop typing and turn the damn ignition key on the 20 pole with American windings to the right.
Imma sink the Uboat and bring all the stolen black and gold back to its rightful owners
:no_mouth:
HubertComment
But they got one thing wrong. I do not plan to just wind in peace . I plan to shove the excellent motor windings clear up their jacked asses ever chance I get.
Forget a truce! They did not let me wind in peace for 10 years. and did everything to remove me from the forums. its too late now. A person cant deal with me that is blocked.
He will come back any time I let him because he knows I know my craft and cannot admit it. I'm one of the most capable people that he knows. He could send me that stupid ass 20 pole rotor and stator and i could wind it in a few hours..
Forget peace I want a proxy war with allot of collateral damage!!! Indiscriminate carpet bombing is my muse! I was in here in peace and they came for me...so lets do it....
You got the link to holles efficiency calculator you love... "tata" enter something in it and post it!
Everyone wants peace now how odd after all the epithet etc!!!
:angry:Comment
"You are highly intelligent. Is that why a 20-pin rotor is causing you problems? You don't know that you can cut the magnets in half and then angle them 45 degrees to get a flow-focused 2-axis segment rotor. The wind is already harmoniously clean. What are you worried about anyway? I think that's just an excuse. The machine has never been running. But she looks good in the photo. I know he didn't let them run because he was just winding this latest winding arrangement that I had recently recommended to him from the lock repair shop."
~Clugh 3/13/2025~
then comes this after it wasnt supposed to work for speeding...
Powercroco
User
The full metal jacket bell is the 20 pin though! You "only" get the PAW with 14P.
Although that's not true:
We had the first test at a time when we didn't have the current propellers yet!
Just thrown into the ring:
With the existing multi-blade with 44.5 incline, it only takes 9550rpm for v 80% 550 km/h.
With FAI-compliant 35V load voltage, this is only 270/V at the operating point!
The actuator load is only as high as with a 10P at twice the speed. and > 20,000rpm are known to be no problem at all.
With 10 or 14P, such a low n spec. is rather not sensibly achievable with the necessary power throughput, but with 20P it can work, if I look at the data of the (smaller) 18N20P.
The necessary power throughput should probably be able to be achieved by a 5-600g motor.
So if you feel like it, you are welcome to try it out - from the theory there seems to be nothing against it.
It's too "modern" for me.
Christian Lucas wrote:
I'll continue to do the 12N20P, it's still coming, but it's not at all for your application.
Happy Amps Christian
But he doesn't tell you his 18N20P rotor falls apart.but hes more interested in that than this 12N20pole.. is what he posted earlier.... but now the 12N20P is up on the test stand. I though it "rotated" and he had data already????.That's what he just told Christian and you all read that.powercroco
Registered Users
was a factory winding.
made with 1,32mm wire it is strong enough for 95% of the potential users.
and all "pyro"and "kora" types have the ring just since their beginning!
may be, the shown also was a single case of bad gluing.
beside this pyro: we had 14P motors with spacers or also with 100% magnets inside.
in these sometimes the complete magnet+spacer-ring came loose in one piece, if they were really high loaded.
btw. we found the same effect in 18N20P; when we went to 18N16P all was normal.
"the result were as he expected" is exactly what he said now we gathering data again with adjustable pitch...march 3 2025.
See???
:lying_face:Comment
See?? I read what he says very closely you all don't and also have Alsheimer my memory is excellent still.
:lying_face:Comment
You are a Pinocchio about hobby motors Ralph Okon... simple as that. I catch you every time.
Wenn eure Flitzer also wollen, können sie das, aber ich verstehe das nicht so; die Rentner dort kommen damit klar. Scheint mir eine riesige Zeitverschwendung zu sein, und ich konzentriere mich nur auf .23 Nm Drehmoment. Und das seit 10 Jahren.
Nun liegen weitere 10 Jahre Hörerfahrung mit über 20 Polen mit Standardrotortopologie und verteilter Wicklung vor ihnen, so alt wie die Zöpfe der schwarzen Pharaonen im Kusch.
If the frame size and lower pole 10 or 14 sets a synchronous speed so high that you need too many turns so the wires have to be small to fit thus the cant carry the necessary current for the power delivery you need.. Seems to me you mean the cell count and esc you have cant carry it. The 34 volt class shouldn't have a minimum voltage? so you have to run big current and short coils. 2,3,and 4s lipo paralleled and a esc that can sink 1000s. At 9500 rpm a 500 - 600 gram 10 or 14 motor I doubt very seriously the p800 < 500 grams cant swing something for a speed plane with enuf wire on it for 10 s lipo.. I have a hard time believing it with the right prop anyway.
Ill throw this cobra in the ring. Its got alot of room for improvement in copper fill and an excellent axial cooling. Its 89.00 LOL! so I could invest in a better core very easily with the savings..
12N14P
396 grams
20T Delta.
KV 300
Poorly filled with small wire it will deliver 2 Kw on 10 s lipo.
Eta 95%Comment
One of my 445 gram 4638 24 slot 22 pole neu motor ourunners will certainly deliver power at the 9500 rpm range . They have a synchronous speed of 1 turn to 1000Kv. Off the shelf it can dump over 5kW its 1 to 1 so I'm sure it can dump 5 Nm. 3 turns delta is 333 Kv. Quiet as hell with and excellent signal. My Castle sensor less ESC's drive anything it seems to me.
Where's the improvement with the lap wound 42XX 20 pole? At 36 volts this gurl saturates at 6.44 kW
These wires can definitely carry it. A 4T delta is 250Kv.
Thanks
HubertComment
This is the factory P800 fill in a single layer. 12 Turns of 17 Awg. You can see how much more copper I can add on the other arms. But I'm only putting 7 turns of 15 AWG there for a total 24.09mm ^2 in copper cross section in the slot. That's plenty healthy on copper. You see how much you could get in with a single coil winding with no crossover in the slot. I easily fit 24 turns of 17 AWG for the 24.96 mm^2 ccs in the slot winding single coils like a servomotor.Comment
"The motor carrier shown in the pictureit ("outer cup") does not belong directly to the engine.
It serves as a cooling surface and dissipates the hot air from the winding and the stator carrier to the outside, preventing it from heating up the actuator and battery additionally. They get warm enough even without the additional heating.
There are also individual pieces in which the star points of the YY wiring have been led outwards into the air stream to improve heat dissipation from the winding ("pigtails")."
~Powercroco~
I esp love this detail about the pigtails. But when will you tell your fans the original idea came from me and you used it even since. But you dont post that along with all your mouth. Do You.? is funny a 18N20P Kw is not.86 it is .941.
Luke is still brighter than everybody I hope you didnt think you were making progress with him. If he was hitting on 2 cents you'd see the 12N20P.
Like I said no numbers come with this 12N20P wundermotor. Fallacy always follows real inquiry. It is the same old soap opera. as ususal. 10 more years talking about the 20 pole in my prediction. You all are stupid enough to do it.
A civilized exchange???......not capable with haters.
front row
So what is he talking about? Nothing has been wound. Those skateboard motors come as you see them. He hasn't done a thing and you all are a joke. You do everything but run a motor and capture constants. 😂 Why would a skate board motor benefit from 60 cogging steps.?
Silly and a smooth diversion away from the 12 slot 20 POLE that was introduced for??????Comment
