For all the hardcore Phantom Fans
Indeed he said he did.
Then again, this is not surprising. In my experience, 90% of all models out there require a bit of counter aileron during rudder turns, since most models will want to have a positive bank when the inner wing travels slower than the outer.
Freewing A-10 turbine conversion: http://fb.me/FreewingA10TurbineConversionComment
Finally getting my Phantom together. Had a bad elevator servo but Motion was quick to get me a replacement. Now the nose gear has failed. It cycled once and now refuses to extend. Has anyone had this issue?Comment
No but it worries me so many elevator failures so I will change to hi tec.Comment
That is the first thing I ordered. A HS-5245MG digital servo for the elevator. Will be using a 2/56 rod and DuBro ball links on both ends in a captive system.... Just in Case!!! Great looking birds there guys!Comment
Thank you! That was pre-op. Before the girls got dirty. A-10 is behind me in this photo, on deck for a makeover.Comment
Push on the strut while retracting it. Something may be binding it before it raises all the way.Comment
My AR610 receiver won't power up with the included BEC , tried another receiver and another same type BEC , the receiver light flickers on when first connecting battery but then nothing ... same for two known good receivers .. any ideas ? the BEC output is 5 volts confirmed with meter, trying any port on receiver, polarity in port is correct... thanksComment
Did you re bind the receiver? Tx off, bec plugged in, bind plug in, then connect the battery. Lights should blink rapidly. Then hold the bind button and turn on the Tx. Be at least five feet away and no computer or tablet or phone in between you and the plane...Comment
Just a side note:
My F-4 had a pretty good wrinkle in the fiberglass nose cone. I took it out completely with judicious use of a heat gun.
Also, on the stock decals, the Rescue placard spells "entrance" as "entrane". Just saying. I will be going with Callie graphics anyway.Meridian Aeromodelers, Meridian MSComment
:Cool:Mine is the same. I went with Callie also :Cool:Just a side note:
Same here.....At least that way I know it will all be spelled correctly and in ENGLISH....LOL:):Cool:Comment
I hear that the letter c tends to peel off at mach 2. Just slow down and you will be fine. Kidding. Thanks for the heads up. I might have missed that and had it pointed out by the peanut gallery at the field. ;)Just a side note:
Also, on the stock decals, the Rescue placard spells "entrance" as "entrane". Just saying. I will be going with Callie graphics anyway.Comment
