All my "spares" that come off existing planes are "undesirable". That's why they became spares. The servos in the horizontal stab are 1/2 inside the tail of the fuse. Yanking them out shouldn't damage too much that can be seen. Slide a thin blade (X-acto knife) along all the edges to free up the sides of glue, then try to slide a flat bladed something under the end of the exposed servo to free the underside from the stab. Worse comes to worse, pull out the servo with needle nose pliers and if there's a lump of foam attached, cut that off as flat as you can and glue it back in the hole. The stab is already in a condition you don't like, so a little more "dislike" shouldn't bother you that much more to keep as a spare. If you don't like the way it looks now, will you ever actually use it when you need another replacement?
I know an afterburner is not used in the real jet but I love the RC Geek afterburner: http://thercgeek.com/3d-printed-products-services/ The 80mm afterburner...Comment
Screen mesh sounds like a good idea under that type of condition. It doesn't take much of a pebble to destroy a fan.My YouTube Videos https://www.youtube.com/channel/UCrz...4Q-xrOOtP2C-8wComment
A screen wont work.
Any screen small enough to filter out small rocks, say window screen size, will not pass high speed air, it will act like a solid barrier.
Any screen large enough to pass high speed air will not stop the small debris that will destroy your fan.
A better bet then a screen would be a small plastic deflector in front of the inlet to deflect small rocks kicked up by the front tire.Super Airliner, Corsair, Viper, BAE Hawk, L-39, A-6, PC-21, B-25, T-28, GeeBee, Wildcat, Stinson, F-16, F-4Comment
I've read where people cover that cheater inlet completely and they still fly, so a screen won't be any different and should still let in some air. With the cheater covered, you just need more distance to get up to speed for take off. The deflector is an option but if that cheater sucks like a vacuum cleaner, some debris will still get in.Comment
The plane will still definitely fly with a screen over the cheater or even the cheater completely covered.I've read where people cover that cheater inlet completely and they still fly, so a screen won't be any different and should still let in some air. With the cheater covered, you just need more distance to get up to speed for take off. The deflector is an option but if that cheater sucks like a vacuum cleaner, some debris will still get in.
But I assume the reason the designer put the cheater in in the first place is because the scale inlets do not flow enough air for the fan.
Therefore if you block the cheater in some way, you are probably starving the fan to some extent and loosing some performance.Super Airliner, Corsair, Viper, BAE Hawk, L-39, A-6, PC-21, B-25, T-28, GeeBee, Wildcat, Stinson, F-16, F-4Comment
The other thing that I learned is that the cheater is for sucking more air in during zero to take off speeds, when there is less forward movement. Once moving, the cheater is not that needed due to the ram air effect. In fact, some have said that top speed is not affected with cheaters covered. I've never covered mine, even when I used to run on a gravel runway, so I can't attest to any of this. And yes, the gravel runway beat the crap out of the fan blades.
Therefore if you block the cheater in some way, you are probably starving the fan to some extent and loosing some performance.Comment
They also add it because it contributes to that turbine like sound we all love.The other thing that I learned is that the cheater is for sucking more air in during zero to take off speeds, when there is less forward movement. Once moving, the cheater is not that needed due to the ram air effect. In fact, some have said that top speed is not affected with cheaters covered. I've never covered mine, even when I used to run on a gravel runway, so I can't attest to any of this. And yes, the gravel runway beat the crap out of the fan blades.Comment
Today I was able to use a grass field to fly my L39. Flew 3 times without the screen on the cheater inlet and 3 flights with the screen. I had 3 pilots spotting along the runway to determine the point on liftoff.
There was not enough difference between using the screen or not. It may well effect other EDF's but not the Freewing L39.Comment
And there you have it. I think "cheater holes" help the pilot believe there is an improvement. They may help in the first 10 to 20 feet from the start but after that, most EDFs are moving pretty well. The only EDF where cheaters might actually do something are ones that hover (eg. SebArt Mig 29) where there is little to no air movement past the plane. They fly in dead air some of the time.Today I was able to use a grass field to fly my L39. Flew 3 times without the screen on the cheater inlet and 3 flights with the screen. I had 3 pilots spotting along the runway to determine the point on liftoff.
Using RC Geek Centerburner and afterburner ring from RC Castle. See previous flight for links to items. https://www.youtube.com/watch?v=dkwyWp2kHrQ&t=142sComment
any updates on the 3d cockpit upgrade? Just ordered mine...also looking for the nose strut support...Comment
Here is the link to the L39 nose gear brace on thingiverse. Had a friend print it for me. Should arrive next week and once installed it will be ready for the maiden.
https://www.thingiverse.com/thing:3134218
Warren
yeah I saw that, I do not have a 3d printer though...Here is the link to the L39 nose gear brace on thingiverse. Had a friend print it for me. Should arrive next week and once installed it will be ready for the maiden.
WarrenComment
