I received my items today. I don’t have a printer either. I’d be willing to bet if you put a request out there, you would find someone willing to print up the items you require. I now have what I wanted to finish the L39. Nose wheel brace, receiver shelf, weapons pylons, two camera mounts for a run cam, and two sets of chalks while parked in the pits for fun. Going to be a fun flying season.
wow those look great!Originally posted by Race 22 Crew View PostI received my items today. I don’t have a printer either. I’d be willing to bet if you put a request out there, you would find someone willing to print up the items you require. I now have what I wanted to finish the L39. Nose wheel brace, receiver shelf, weapons pylons, two camera mounts for a run cam, and two sets of chalks while parked in the pits for fun. Going to be a fun flying season.
You know how they say, "Follow the money"? Well, follow the wiring. Start in the wing and check the connections to make sure they are solid and in the correct polarity and in the correct plugs. Then go all the way to where they plug into the control board. Wiggle them while the plane is powered up. If that doesn't work swap each one to a different plug for the lights. If they still don't work, then you can eliminate the wiring by using extensions to go directly from the first connection in the wing to the board. If that doesn't work, then it could be the board or the lights themselves are dead.Originally posted by Air Y Lee View PostJust finished assembly of L-39. Wing tip & landing lights do not work. Looking for suggested paths to testing and fix.
Never use a servo tester to test lights. It'll burn them out.
The landing lights only work when the gear are down. Have you powered up the airplane and lowered the gear? I’d pull the tip tanks back off and check the connectors are still connected and the polarity is correct. Are your wing ribbon cables attached to the blue box? The lights power through these cables. The Red/Green Nav lights should work any time the battery is connected. With the tanks back off you could also use a multi meter and check for power at the connector on the wing side. If you don’t have power at that point work your way back to the fuselage. If you have power at wing tips, then you do have a tip tank issue.
Sound test flight. Note this jet also has one whistle installed. Hopefully a better test flight tomorrow if the sound distortion of the suspected volume wheel is sorted out.
Strangely I was able to do loops and fast passes also. Hopefully I will show this on the next video when I get the static distortion of the module sorted out...
- Likes 2
Welcome!! You will love the L-39. It flies really well! Glad you are here :Cool: :Cool:Originally posted by flyinhigh042 View PostI just wrapped up assembly of the L-39. I’m really excited to get this thing in the air! But the weather here in Colorado is forcing me to be patient. This is my first post in the group. I just wanted to say hi!
Jeff
