Congrats on the successful maiden !
A fine setup, similar to what I did on mine when I was running 8ch a lifetime ago! ;)
BTW, great job on the paint! :D
And yeah, maidening with CG at 170mm is a bit extreme... better to start at 160 and slowly work and adjust from there.
When the CG is very aft, you need to push the nose a bit down when the jet is flying slow, but it's not really tail heavy.
This is normal and to be expected. ;)
Yeah, pitch can definitely be a bitch on this jet if badly set up!
Didn't you check for nozzle alignment BEFORE the flight??
As mentioned, the Su-35 usually asks for a little bit of pitch-up trim built in the nozzles to fly level.
And did you remember to separate the nozzles from the trim function so that trimming in flight doesn't change thrustline?
It's a beast of a jet, time to enjoy her! :D
Glad you heeded my call on that one...
Big throws and no expo is a big no-no for this aircraft! ;)
